MQA and MQA ready DACs
Re: MQA and MQA ready DACs
Unread post #151 by BityaBit » Thu Jun 01, 2017 7:21 am
Unread post #152 by Dr Pan K » Sat Jun 10, 2017 2:12 pm
H PS Audio ετοιμάζεται να μπει δυναμικά στο MQA
PS Audio is proud to announce availability of the revolutionary Huron Operating System upgrade for the DirectStream and DSJ DACs. Since the release of the Torreys OS last year, digital guru Ted Smith has worked painstakingly to not just improve sonic and measured performance of both DACs, but to also prepare the Bridge II network card for MQA and Tidal. The Huron OS for both DACs will soon be followed by a new OS for the Bridge II.
https://parttimeaudiophile.com/2017/06/ ... ming-soon/
Unread post #153 by Dr Pan K » Thu Jun 22, 2017 4:34 pm
Gold on black box.jpeg (365.14 KiB) Viewed 2250 times
Fresh from receiving the ‘Golden God’ Icon Award at this year’s Metal Hammer Golden Gods , Black Sabbath are proud to announce ‘The Ten Year War’ – a limited edition vinyl box set, released September 29th via BMG, that brings together their eight Ozzy fronted albums, plus a swathe of other rarities, all housed within exclusive artwork created by renowned street artist, graphic designer and activist Shepard Fairey.
For MQA fans - this includes a Crucifix shaped Black Sabbath USB stick, exclusive to this box set, which can be worn round the neck and contains MQA high definition audio of the first eight Black Sabbath albums.
Unread post #154 by BityaBit » Fri Jun 23, 2017 8:53 am
Καλή φάση φάση αλλα 250 για το σταυρουδάκι είναι πολλά.. Κρατάω το οτι αυξάνονται και πλυθήνονται οι επανεκδόσεις αγαπημένης μουσικής στο κοινό σε MQA και πλέον ξεφεύγει η όλη φάση απο την niche audiophile σφαίρα.
Unread post #155 by Dr Pan K » Fri Jun 23, 2017 12:39 pm
Όντος αυξάνονται οι τίτλοι, βγήκε και το Purple Rain του Prince .
http://tidal.com/album/75206892
Unread post #156 by BityaBit » Thu Jun 29, 2017 5:14 pm
Ενα πολυ ενδιαφερον αρθρο αρκετα τεκμηριωμενο θα ελεγα σχετικο με την διαφορα μεταξυ software/hardware decoding αλλα και τον βαθμο αναπλασης του πρωτοτυπου hires υλικου απο την μεθοδο αυτη κωδικοποιησης.
http://archimago.blogspot.gr/2017/02/co ... g.html?m=1
Unread post #157 by Dr Pan K » Fri Jul 07, 2017 8:59 pm
Νέες προσθήκες στον κατάλογο των Tidal Masters. Έχει και κλασσική.. [thumbup]
http://tidal.com/playlist/b2c94789-14d4 ... a96b952900
Unread post #158 by Dr Pan K » Sat Jul 29, 2017 12:51 pm
Επισημα θεση εναντιον του MQA πήρε η Ελβετική εταιρία Dar Tzeel παραπέμποντας στο παρακάτω άρθρο από το open-source
Just say NO to MQA.
It is non-sense, no improving what is already, natively high res.
Here is a simple, straight, clear and smart explanation:
https://opensource.com/life/16/9/whats-wrong-with-mqa
Το οποίο παραπέμπει με την σειρά του στο γνωστό paper της Benchmark όπου ο Siau εξηγεί γιατί δεν έχει νόημα το MQA.
https://benchmarkmedia.com/blogs/applic ... is-mqa-doa
Βρίσκω την κίνηση της Dar Tzeel ενδιαφέρουσα καθώς αυτή τη στιγμή όλοι όσοι έχουν εμπορικό ενδιαφέρον φοράνε το Mqa όπως πριν λίγο καιρό όλοι έτρεχαν πίσω από το DSD (πρακτικά νεκρό κατ' εμέ).
Unread post #159 by BityaBit » Sat Jul 29, 2017 1:10 pm
Παντως στατιστικα αντιδορυν στο MQA μικροι hi end κατασκευαστες σε συντριπτικη πλειοψηφια..
Unread post #160 by Dr Pan K » Sat Jul 29, 2017 6:53 pm
Δεν έχει και τόση σημασία αν αυτοί που αντιδρούν στο MQA είναι μικροί ή μεγάλοι. Σημασία έχει ότι κάποιοι βγαίνουν και το κράζουν ανοιχτά, κάτι πρωτόγνωρο στον χώρο. Σε άλλες περιπτώσεις στο παρελθόν οι κατασκευαστές κρατούσαν απλά επιφυλακτική θέση, δεν έβγαιναν να δηλώσουν δημόσια πόσο ενάντιοι είναι σε ένα νέο φορμάτ.
Θυμάμαι πχ μια συζήτηση που είχα με τον Καλμετε της Jadis επάνω στο DSD πριν μερικά χρόνια. Είχαν μόλις βγάλει νέο ψηφιακό και ανέβαινε μέχρι 24.192 ενώ όλοι φόραγαν DSD και οποίος δεν ακολουθούσε έχανε αγορές. Μου είχε πει ότι θα περιμένουν μέχρι να καθιερωθεί σαν φορμάτ, κάτι που τελικά δεν έγινε ποτέ και ούτε πρόκειται να γίνει. Είχε δίκιο λοιπόν..
Κατ' εμέ αυτοί που τώρα τρέχουν πίσω από το (πάντα κατ' εμέ) dead on arrival Mqa το κάνουν για να μην χάσουν πωλήσεις και όχι επειδή προσφέρει κάτι.
