"CG - 10M" is a master clock generator that sends 10 MHz clock signal useful for further improvement of sound quality.
The clock signal is the basis of all its functions in digital signal processing. For example, a digital signal obtained by dividing a time axis into hundreds of thousands of times per second as data such as a PCM signal and converting the data into digital data, if the basic time axis is fluctuated at the time of D / A conversion, an accurate analog signal It can not be returned to. Furthermore it is even more in the DSD audio signal whose time axis operates at MHz speed. Therefore, by making the master clock which is important for high-resolution sound source reproduction high precision, it becomes possible to obtain reproduced sound faithful to the original sound.
OCXO (Oven Controlled Crystal Oscillator) with a high stability of oscillation with a thermostatic chamber was adopted as the crystal part corresponding to the heart. In addition, the analog meter that stands out on the front panel always displays the oscillation stable state inside the OCXO which can not be confirmed generally, so the stable operation state of the OCXO can be confirmed.
"CG - 10M" is a master clock generator that maximizes the performance of all 10 MHz clock input compatible products such as USB - DAC, network player, and CD player that perform high - resolution playback of high sampling rate.
Features
Equipped with a TEAC Reference OCXO crystal oscillator with thermostat capable of highly stable transmission
Accurate specifications with frequency temperature characteristics within +/- 3 ppb and frequency accuracy within ± 0.1 ppm
A total of 4 systems of 10 MHz clock output terminals (gold-plated BNC terminals)
By completely separating and separating the circuit configuration, interference between each system can be eliminated without limit
Large capacity toroidal core power transformer that supplies stable current
OVEN STATUS meter (with illuminance adjustment function) to display OXCO internal outgoing stable status all the time
3 point support pin point foot which can easily and reliably pinpoint grounding
Aluminum that is resistant to radio noise is adopted for the front, top and side panels
Official Page
