Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #141 by Dr Pan K » Wed Jun 14, 2017 8:20 pm
Daniel Hertz
M11 integrated amplifier
Active DSP crossovers for bi-amplification
High current stereo operation mode.
200W/8 W; 400W/4 W x 4 channels or stereo.
24-bit wireless connectivity
3 analog inputs with 1 megohms input impedance so source units operate with virtually no load.
3 x 24 bit digital inputs: 192kHz USB input, 192kHz coax input, and 48kHz wireless input
Daniel Hertz speaker connectors and speaker connector tool (all made in house).
Intelligent modular design.
MSRP: 30.000 euro
Unread post #142 by Dr Pan K » Fri Jun 16, 2017 10:13 pm
Tidal
Camira DAC
pure discrete designed 24 bit non-oversampling R2R ladder DAC without pre-ringing and post-ringing
proprietary USB-to-I²S interface directly into the I²S interface of the ladder DAC without detouring USB-to-SPDIF > SPDIF-to-I²S > I²S-to-DAC
proprietary ASRT Analog Signal Remediation Technology: Field Programmable Gate Array for most precise timing informations for and between the left and right channel incl. timing correction and remediation processing of 44.1 KHz signals
true balanced output concept without any sound-changing inverted signal generation
20 ultra low noise voltage supplies.
2 x digital input AES (XLR)
2 x digital SPDIF (coaxial BNC, cinch RCA)
1 x asynchronous USB class 2 input for PCM and DSD/DXD audio formats
up to 384 KHz sampling rate
384 KHz/24 bit PCM and up to DSD256 over USM
DSD by DoP and native over ASIO interface for Windows
0,01% tolerance precision resistors
femto clock ultra low noise oscillator (-169 dB)
fully discrete Class-A output amplifier
ultralow-ESR organic capacitors
Weight: 24 lbs. / 11 kg
camira front.png (357.03 KiB) Viewed 2673 times
camira back.png (418.41 KiB) Viewed 2673 times
camira inside.png (648.07 KiB) Viewed 2673 times
Ferios power amp
pure silver hollow conductor EMI transformers
regulated active power supply with 2 x 800VA non-noise toroid transformers, completetly magnetical shielded and mechanical decoupled
linear voltage power supply for ripple-free voltage and current stabilization for the two amplifier modules
410.000 µF stabilisation capacity, ultra fast response with high-grade-long-life-capacitors
in-house made multilayer PCB (printed circuit board) with 105 µm copper per layer
hand selected transistors, measured and matched with a precision better than 1%
DC-coupled input circuit, without coupling capacitors or relay in the signal path from the input to the output
ultralow impedance capacitors directly at the transistors for most shortest connection
TIDAL APM System is an isolated and completely autarkic system to manage and control the power amps safety: output current in relation to output-voltage, short circuit current, DC- offset, under-voltage and over-voltage
optional: fully autarcic working active crossover LPX-monomodule for active amping to control the bass section of TIDAL reference speakers, perfectly matched in phase and frequency, different frequencies and level adjustable to trim bass response perfectly to each room and/or taste
intelligent softstart system, remote power on/off by TIDAL pre amplifiers via RJ45 ethernet cable
rated power output at 8 ohm: 1 x 300 watts continuous rms power
rated power output at 4 ohm: 1 x 580 watts continuous rms power
rated power output at 2 ohm: 1 x > 700 watts continuous rms power
bandwith: 1Hz - 400 kHz (-3 dB), measured with impedance load
dimensions: 17.3" x 12.4" x 17,3" / 44 cm x 31 cm x 40 cm
power consumption: < 1 W in stand-by mode
ferios front.png (338.25 KiB) Viewed 2673 times
ferios back.png (517.3 KiB) Viewed 2673 times
ferios inside.jpg (64.28 KiB) Viewed 2673 times
Unread post #143 by Dr Pan K » Wed Jun 21, 2017 8:52 am
Pass Labs
XP-12 Phono stage
Power consumption 50 Watts
Gain 9.3dB Balanced
Balanced and RCA inputs & outputs
Frequency response: +/- 0.05 dB 10Hz to 20KHz
-1dB @ 100KHz
Crosstalk > 100dB
Residual Noise 15uV 10 – 30Khz THD < 0.001 @ 1V 1Khz
Double shielded low noise toroid
MSRP approx 6000 euro
Unread post #144 by Dr Pan K » Sat Jun 24, 2017 9:44 pm
Air Tight
ATM-3211mono power amps
1st stage: differential circuit of 12AX7, 2nd stage: 12BH7
Cathode-follower 12BH7 parallel
A-class operation up to 30W
AB-class operation for more than 30W
Rated output: 120W (6Ω/THD2%)
High and low 2-compositions Tamura transformers ensure instantaneous power supply and prevent power interference.
High grade capacitors and resistors are employed for the key locations learned in years’ development
15mm thick aluminum front panel is scraped out by hand workWBT input and speaker terminals
Hand soldered
Power consumption: 550VA
Weight: 44kgs each
MSRP $80.000
Για περισσοτερες πληροφοριες Aurion Image & Sound
Unread post #145 by Dr Pan K » Wed Jun 28, 2017 11:52 pm
Boulder
1160 Stereo Power Amp
Continuous power, 8, 4, 2 OHMS: 300W
Peak power, 8 ohms: 300W
Peak power, 4 ohms: 600W
Peak power, 2 ohms: 1200W
THD, 8 ohms, 300W: 20-2 kHz: 0.0009%, 20 kHz: 0.0048%
THD, 4 ohms, 300W: 20-2 kHz: 0.0016%, 20 kHz: 0.0071%
THD, 2 ohms, 300W: 20-2 kHz: 0.002%, 20 kHz: 0.0130%
Equivalent Input Noise (EIN), 20 kHz BW: 1.5 μV
Magnitude response, 20 to 20 kHz: +0.00, -0.04 dB
Magnitude response, -3 dB at: 0.015 Hz, 150 kHz
Voltage gain: 26 dB
Signal-to-noise ratio (RE: 300W/8Ω): -127 dB, unweighted, 20 to 22 kHz
Input impedance: Balanced: 100k ohms, unbalanced: 50k ohms
Common mode rejection (balanced only): 60 Hz: 90 dB, 10 kHz: 70 dB
Input connectors: 3-pin balanced XLR
Output connectors: Two sets of 6 mm / .250-inch wingscrews
Crosstalk, L to R or R to L: Greater than 120 dB
Weight: Amplifier, 140 lbs. (63.5 kg); Shipping, 220 lbs. (99.8 kg)
Power requirements: 100, 110-120, 220-240 VAC, 50-60 Hz
Power consumption: 15W Standby, 240W Nominal, 3600W at Maximum output
MSRP $28.000
http://boulderamp.com/new-release-1160- ... amplifier/
Unread post #146 by Dr Pan K » Sat Jul 01, 2017 10:18 pm
VPI
Cliffwood belt drive tunrtable
Machined Aluminum Platter
600 RPM AC Motor - 2 speed pulley
Machined Aluminum Gimballed 9 inch arm
VPI/Grado Green Cartridge
Fully upgrade-able
MDF Vinyl wrap "Black Truffle" finish
Περισσότερες πληροφορίες στην Audio Soul Ultra/ South Sounds
Cliffwood Lifestyle-001.jpg (395.26 KiB) Viewed 2592 times
Unread post #147 by Dr Pan K » Mon Jul 03, 2017 7:03 pm
Stromtank
S 2500
High-power battery pack
Integrated pure-sine wave converter power supply
600VA continuous power supply
Harmonic distortion <2%
100 Ah nominal capacity LiFePO4 batteries
https://stromtank.com/s2500/
Unread post #148 by Gojakla » Tue Jul 04, 2017 12:27 am
Γνωριζουμε κοστος;
Unread post #149 by Dr Pan K » Tue Jul 04, 2017 12:34 am
Gojakla wrote:Γνωριζουμε κοστος;
To S5000 έχει 30Κ οπότε το 2500 να μην εχει 15.000 ευρω;
Unread post #150 by Gojakla » Tue Jul 04, 2017 12:44 am
Να εχει. Γιατι να μην εχει;
:mrgreen:
