Page 1 of 1
Benchmark DAC1 (original rack mount version, μαύρο)
Posted: Thu Feb 15, 2018 11:01 am
by angpsi
Πωλείται Benchmark DAC1 πρώτης γενιάς (όχι USB), rack mount version, μαύρο, σε άψογη λειτουργική κατάσταση. Μπορεί να χρησιμοποιηθεί και σαν ενισχυτής ακουστικών (με 2 εισόδους) ή να οδηγήσει ενεργά monitor ηχεία.
Τιμή συζητήσιμη, στα €430.
Κριτικές εδώ κι εδώ.
Specs:
  • Two Channel, 24-bit, 192-kHz, D-to-A Conversion
  • Plays 192-kHz with 52-kHz analog bandwidth
  • Direct connection to powered monitors
  • Total jitter immunity via UltraLockTM technology!
  • 116 dB signal-to-noise ratio @ 48-kHz, A weighted
  • THD+N = -107 dB (0.00045%) measured at -3 dBFS, any sample rate, any test frequency
  • AES, S/PDIF, and Toslink inputs
  • Digital input source-selection switch
  • Variable or preset output level controls
  • Balanced Low-Z XLR outputs
  • Unbalanced RCA outputs
  • Automatic de-emphasis for 44.1, 48, and 96-kHz when pre-emphasis bit is set
  • Headphone amp = 0.0003% THD into 60 Ω
  • Output-off switch position for headphone-only use
  • Front panel power and error indicating LEDs
  • Internal low-radiation toroidal power supply
  • International 120 - 240 input voltage range
  • 1/2 wide, 1RU high chassis
  • Machined aluminum front panel
  • Rack mount
Re: Benchmark DAC1 (original rack mount version, μαύρο)
Posted: Fri Feb 23, 2018 11:53 pm
by angpsi
Πτώση τιμής στα €380.
Posted: Tue Mar 13, 2018 1:33 pm
by angpsi
Το Benchmark πουλήθηκε, ευχαριστώ για την φιλοξενία!
