- jpeg.jpeg (24.76 KiB) Viewed 14116 times
Synergistic Research NEW PowerCell 12 UEF:
The PowerCell 12 UEF directly applies UEF technology to both the PowerCell’s ground plane and as a separate filter inside the PowerCell’s internal Electromagnetic Cell while an Ultra Low Frequency Field -or- ULF Generator re-clocks the (6) EM Cells with a rich low frequency harmonic making 60-cycle noise a thing of the past. Combined UEF Filter technology, and ULF Field Generation make this our most effective and musical PowerCell to date.
Developed exclusively for the PowerCell 12 UEF, the ULF Field Generator directly connects to the PowerCell's (6) EM cells to lower your system’s noise floor by re-clocking AC with a rich low frequency harmonic that overrides noise and hash found in common 60 cycle AC.
The New PowerCell 12 UEF is the culmination of years of research into electromagnetic cell design and represents the apex of AC line filtration with nothing in the signal path and absolutely no current on demand limiting.
The New PowerCell 12 UEF is the first PowerCell to utilize Graphene a near super conductor at room temperature to dramatically increase EM Cell efficiency. Components plugged into the new PowerCell 12 UEF actually draw more current than they do when connected to directly to the wall due to the new EM Cell topology acting like a Super Capacitor to deliver peak current on demand that surpasses available wall current. Test measurements show components connected to the new PowerCell to have a 2db drop in the noise floor and increased dynamic headroom.
- jpeg.jpeg (601.45 KiB) Viewed 14116 times
PowerCell 12 UEF 230V Models and Pricing PowerCell 12 UEF - MSRP $5050.00
6 Tesla Plex Duplex
Includes UEF Black 10 Awg AC Power Cord
12awg wiring
PowerCell 12 UEF SE - MSRP $6050.00
6 UEF Black Duplex
Includes Atmosphere PowerCell Level 3 AC Power Cord
10awg and 12awg wiring
PowerCell 12 UEF SE w/ Glass Top - MSRP $6550.00
6 UEF Black Duplex
10awg point-to-point wiring
Unique features to the PowerCell 12 UEF over all previous PowerCell models Internal power supply for biasing EM Cells - no more MPC's plus higher performance over Galileo MPC's
Internal ULF Generator to bias AC to the Earth's Schumann Resonance for a dramatic drop in a system's noise floor
10 awg. Mil Spec Silver Clad Wire (standard on top tier models only)
2 each SR Power Transformers
8 each SR Quantum Capacitors in EM Cell power supply and ULF field generator
Metal chassis is more durable and in keeping with the same look as other components in a system
New Quantum BLACK Duplex and Shuko outlets dramatically outperform TeslaPlex SE outlets
12 outlets are better than 10
New 6 EM Cell topology acts like a 'Super Capacitor' to increase peak current on demand allowing components to draw more current than when connected directly to the wall for added dynamic headroom
Top tier models come standard with a special 10-gauge Atmosphere Level 3 Active power cord that does not require a separate MPC, just plug and play like standard non-active power cords- no extra wires!
PowerCell 12 UEF specs: Construction: Aluminum/Carbon Steel Dimensions:
Height 5.5″ x Width 17.5″ x Depth 13.5″
Weight: 19 lbs.
Internal Active UEF EM Horizontal Plane Cell area: 640 square centimeters
5 x Internal Active UEF EM Folded Carbon Fiber Cell area: 2343.15 square centimeters total
Connector Input: 1 each Neutrik 32 amp PowerCon
2 Isolated Output Banks; can be used to isolate analog from digital components
Connector Output US: 12 each SR Black Outlets (Two stage Quantum Treatment)
Connector Output Euro: 12 each SR Black Schuko outlets (Two stage Quantum Treatment)
2nd Generation FEQ transmitter/antenna array to bias AC to the Earth's Schumann Resonance
Pure Silver Ground Strap 62 square centimeters of 99.995% pure silver
Power Cable: Atmosphere Level 3 optimized for PowerCell 12 UEF (standard on top tier models only)
2 each SR Power Transformers 8 each SR Quantum Capacitors
Voltage and current Rating: Input Rating: 32 amp/250v
US Version: Rating is limited by the US Outlet rating of 20amp/125v
Euro Version: Rating is predicated upon the Schuko Outlet rating of 16amp/250v
