Page 2 of 34
Nime Black Diamond Sub woofer
Posted: Mon Jun 20, 2016 9:46 pm
Nime
- nime sub1.jpg (35.45 KiB) Viewed 11471 times
- nime sub2.jpg (25.74 KiB) Viewed 11471 times
Images courtesy of Matej @ Mono & Stereo
http://www.nimeaudiodesign.com/index.html
Lyra Etna SL
Posted: Thu Jun 23, 2016 1:36 am
Lyra
Etna SL
Limited Edition single coil low output (0.25mV) cartridge
$9.995
- LYRAETNASL.jpg (235.59 KiB) Viewed 11460 times
http://lyraanalog.com/etna-sl/
Cessaro Qian Long Field Coil Speakers
Posted: Fri Jun 24, 2016 11:27 pm
Cessaro
- cessaro1.jpeg (668.54 KiB) Viewed 11448 times
- cessaro2.jpeg (837.32 KiB) Viewed 11448 times
Reflector Audio Bespoke speakers
Posted: Sun Jun 26, 2016 4:04 pm
Reflector Audio
Bespoke 2-way open baffle speaker
Frequency Range: 18 Hz-20 kHz
Max continuous Sound Pressure Level: 105 dB @ 18 Hz, 125 dB (40 Hz-20 kHz)
Sensitivity: 105 dB 1W/1m
X-over frequency: 550Hz
Price: TBA
http://reflector.audio/index.html
Sonus Faber SF16 Lifestyle speaker
Posted: Wed Jun 29, 2016 10:18 pm
Sonus Faber
SF16
Lifestyle speaker
8000euro
Ten drivers, arrayed in a push-push configuration for the down low and using “field shaping” tech trickling down from the flagship Aida, the table-top wonder is — like everything Sonus Faber — absolutely gorgeous to see and touch.
Oh, and yes, those “arms” for the mid and tweeter are telescoping. Heh heh.
Source is preferably Wi-Fi (via DTS Play-Fi, for up to 24bit/192kHz streaming), but there are digital and analog inputs too. DSP controlled, and with enough pro-audio class-D amps to generate 1400 watts, the SF16 is hand-made in Italy, and will have a limited production run/capacity of only 200 units per year.
https://parttimeaudiophile.com/2016/06/ ... redefined/
- wom-sardinia-4249.jpg (129.55 KiB) Viewed 11413 times
- wom-sardinia-82411.jpg (78.36 KiB) Viewed 11413 times
Devialet Phantom Gold
Posted: Wed Jun 29, 2016 10:37 pm
Devialer
Phantom Gold
$2.990
- gold-phantom-background-rose-gold.jpg (100.37 KiB) Viewed 11409 times
- gold-phantom-side-view.jpg (49.94 KiB) Viewed 11409 times
- gold-phantom-the-packaging.jpg (101.2 KiB) Viewed 11409 times
– EXTREME POWER: Maximum volume of 108db SPL – equivalent to a live rock concert – enabled by 4,500 Watts of power – equivalent to 8 regular PHANTOMs and an unmatched THD (Total Harmonic Distortion) level of .0005%;
– EXTREME JUBILATION: Physical impact of the deepest basses ever reproduced (14Hz) and the unmatched precision of a new titanium tweeter, up to 27kHz, both driven by a new core ADH® (Analog Digital Hybrid amplification);
– EXTREME SOPHISTICATION: 22 kt Rose Gold-finished exterior highlights
Gold PHANTOM now represents the highest-end of the acclaimed range of Devialet PHANTOM audio products, including the original White PHANTOM (750 Watts, $1,990) and Silver PHANTOM (3,000 Watts, $2,390).
Gold PHANTOM will be available at a retail price of $2,990
McIntosh MP 100
Posted: Sun Jul 03, 2016 11:35 am
McIntosh MP 100
Phono stage with 24/96 ADC
Devialet Phantom compatible (toslink digital output)
$2000
- MP100.jpg (15.62 KiB) Viewed 11389 times
Jadis Diapason integrated amplifier
Posted: Sun Jul 10, 2016 9:47 pm
Jadis Diapason
4 x 6L6, 2 x 12AU7/ECC82, 1 x 12AX7/ECC83 tubes
15W/8Ohm
optional USB input
2000 euro
- jadis diapason.jpg (405.4 KiB) Viewed 11373 times
Re: Straight Outta Factory!
Posted: Tue Jul 19, 2016 11:57 am
by Gojakla
MrSpeakers Ether FLOW
- Cropped_ETHER_Flow_Side.jpeg (855 KiB) Viewed 11358 times
ETHER Flow is MrSpeakers new flagship open-backed headphone. ETHER Flow uses TrueFlow
technology to improve the performance of the critically acclaimed ETHER headphone,
delivering sumptuous planar magnetic bass and dynamics, with near-electrostatic resolution.
Designed, built and tested in San Diego, CA, ETHER Flow includes a 2 year warranty for parts and labor.
ETHER Flow includes a DUM (Distinctly Un-Magical) cable with termination of your choice and
a backpack-friendly hard-shell carrying case.
$1,799.99 – $1,849.99
Posted: Tue Jul 19, 2016 3:24 pm
Nagra Classic INT amp
2x100Watt/8Ohm
10Watt in class A
-110dB SNR
$19,450
- NagraCLASSIC-INT.jpg (183.71 KiB) Viewed 11350 times
Following the design of the Classic Amp as much as possible and featuring exactly the same power supplies and output stage, with a completely new preamplifier design, literally “integrated” into the power amplifier’s input stage.
The Nagra Classic INT also comes in the same chassis as the Classic Amp. The preamplifier section offers 1 x XLR balanced input as well as 4 x RCA unbalanced inputs. Each input’s sensitivity can be adjusted to match the sources output level. It can even accommodate symmetrical professional signal levels to be used in a mastering studio for instance. The front panel features an LCD screen, similar to the Classic DAC, so each input can be named. An intuitive menu allows access to custom settings as well as operating time. All functions are accessible via remote.
In terms of specifications, the Classic INT has the same qualities as the Classic Amp, an impressive 110 dB signal-to-noise ratio, a generous 100 W into 8 Ohms (RMS), an ambitious hybrid power supply, linear and PFC (power factor corrector), and 10 Watts of class A preamplification.
