Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #201 by Dr Pan K » Thu Mar 22, 2018 12:56 pm
Phasemation
T-2000 Step up transformer
Best Cartridge's Output Impedance 14 ohms
Load Impedance 47k ohms
Step-up Ratio ( voltage gain ) 26dB
Frequency Response 10 - 100kHz (±2dB)
Dimensions W : 214mm H : 118mm D : 265mm
Weight 4.9kg x2 units
Input/Output Terminals: FURUTECHRhodium plated terminals
The cartridge that can be used has an output impedance of 1.5 – 40 ohms
phasemation T-2000.png (416.35 KiB) Viewed 5245 times
http://www.phasemation.com/product/t-2000.html
Tους οποιους δεν μπορω να τους καταλάβω, οι κεφαλές της Phasemation βγαζουν 4Ohm και τα step up τους ειναι για κεφαλες 14Ohm...
Unread post #202 by Dr Pan K » Tue Mar 27, 2018 12:45 pm
Cambridge Audio
50 years anniversary
Edge series
A integrated amplifier 2x100/8, 2x200/4 Ohm
NQ pre-amplifier with network player
W power amplifier 2x100/8, 2x200/4 Ohm
Unread post #203 by Dr Pan K » Mon Apr 09, 2018 3:06 pm
Jico
Seto Hori MC cartridge
出力: 2mV
出力バランス: <1.5dB1KH
針圧: 2.0g
Boron cantilever
Micro ridge diamond tip
チャンネルセパレーション: 25dB/1kHz
周波数特性: 15-32,000Hz
出力インピーダンス: 130ohms/1kHz
MSRP approx 800 euro
jico seto hori.jpg (14.77 KiB) Viewed 5192 times
seto hori box.jpg (13.49 KiB) Viewed 5192 times
Η Jico την ειχε φέρει πέρυσι στο Μοναχο και την ακουσα λιγακι (με ενα εισαγωγικό Audio Tekne phono stage). Δείχνει ενδιαφέρουσα περιπτωση.
Unread post #204 by Dr Pan K » Fri Apr 13, 2018 10:06 pm
Audio Research
Ref160M mono power amplifier
2 matched pairs of KT150
POWER OUTPUT: 140 watts continuous from 20Hz to 20kHz. 1kHz total harmonic distortion typically 1% at 140 watts, below 0.04% at 1 watt. (Note that actual power output is dependent upon both line voltage and “condition” i.e.: if power line has high distortion, maximum power will be affected adversely, although from a listening standpoint this is not critical)
POWER BANDWIDTH: (-3dB Points) 5Hz to 70kHz.
FREQUENCY RESPONSE: (-3dB points at 1 watt) 0.5Hz to 110kHz.
INPUT SENSITIVITY: 2.4V RMS Balanced for rated output. (25.5 dB gain into 8 ohms).
INPUT IMPEDANCE: 200 k ohms Balanced.
OUTPUT POLARITY: Non-inverting. Balanced input pin 2+ (IEC-268).
OUTPUT TAPS: 16 ohms, 8 ohms, 4 ohms
OUTPUT REGULATION: Approximately 0.6dB 16 OHM LOAD TO OPEN CIRCUIT (Damping factor approximately 14).
OVERALL NEGATIVE FEEDBACK: 14dB
SLEW RATE: 13 volts/microsecond
RISE TIME: 2.0 microseconds.
MSRP 30.000$
Unread post #205 by Dr Pan K » Sun Apr 15, 2018 1:10 pm
Sumiko
New MM and MC cartridges
MC: Songbird - Starling
MM: Rainier - Olympia - Moonstone - Amethyst
Lifestile - Olympia.jpg (138.63 KiB) Viewed 5132 times
Unread post #206 by Dr Pan K » Thu Apr 19, 2018 10:23 am
CS Port
Analog disc player LFT1
4 Unit design
Base JIS 0 class granite surface plate base
Platter Air float 27 kg High inertia stainless steel platter
Drive system Quartz-follow No feedback motor drive XFD method
Rotation transmission method Yarn drive (four-fiber aramid)
Drive motor DC coreless low noise motor
Rotation speed 33 1/3 and 45 rpm Switch switching With rotation fine adjustment
Speed accuracy ±0.3%
Wow and flutter Wow 0.2% , Flutter 0.04% less
Tangential tonearm
Method Air float type linear tracking arm
Arm lifting mechanism Manual operation with lever
Azimuth / arm length adjustment Adjustment with fixing screw
Compliant cartridge weight 20g-40g (Including shell)
Compatible stylus pressure 1.5-5g
Adjustment of needle pressure Static balance
Output terminal DIN 5P
LFT Price : ¥ 3,780,000 (Tax excluded)
Player board (option) Price : ¥ ¥78,000 (Tax excluded)
Also available TAT1 turntable
slide01 tat.jpg (310.3 KiB) Viewed 5102 times
https://www.csport.audio/en/products/products-lft1.html
Unread post #207 by Gojakla » Thu Apr 19, 2018 5:58 pm
iFi xDSD
Specifications
USB Input: up to PCM768kHz & DSD512 (24.6/22.6MHz)
S/PDIF Coaxial and Optical Input: up to 192kHz/24Bit
Dynamic Range: > 113dB (A)
Volume Control: -101dB…0dB in 1dB steps
Output power:
> 2.82V/500 mW @ 16 Ohm
> 3.7V/270mW @ 50 Ohm
> 3.8V/48 mW @ 300 Ohm
> 3.8V/24 mW @ 600 Ohm
Line out Level: > 2.1V @ 0dBFS (& 0dB Volume)
THD &N (1V/16R): < 0.005%
Output Impedance: < 1 Ohm
Battery: 3.8V/2200mAh
Dimensions: 95 (l) x66.5 (w) x19 (h) mm
Weight: 127g (0.28 Ibs)
Warranty period: 12 months
https://ifi-audio.com/portfolio-view/x-xdsd/Official Site
Unread post #208 by Dr Pan K » Thu Apr 19, 2018 9:55 pm
Μαθαίνω οτι το φινίρισμα του iFi xDSD ειναι πολυ καλο, δειχνει σαφώς πιο premium απ'οτι στο rendering.
Unread post #209 by Dr Pan K » Sun Apr 22, 2018 7:01 pm
Επεσα επανω σε μια νεα Ολλανδικη εταιρια, λανσαρει προ, τελικο, ολοκληρωμένο και εχει και συνέχεια. Το όνομα αυτης EXTRAudio, τα σταδια εξόδου ειναι σε ταξη D με την προενισχυση απο λάμπα σε ταξη Α. Δείχνουν πολυ προσεγμένα αν κρίνω απο τα κουτια, βύσματα και γενικότερο design.
Extraudio
X250 Integrated amplifier (Orange Version)
Phono input
2x200 @8Ohm, 2x250 @4Ohm
THD+N: 0,008% @ 1W (8 Ohm, 1Khz)
Orange version: > 112db
Chromed version: > 121db
18Kgr
https://www.extraudio.com/integrated-am ... -class-ad/
Unread post #210 by Dr Pan K » Thu Apr 26, 2018 11:11 am
Η SAEC ξανακυκλοφορει βραχιονα μετα απο σχεδον 30 χρονια. Η εταιρια που τις τελευταιες δεκαετιες ειχε στην παραγωγη μονο μερικα (πολυ καλα) καλωδια ξαναλανσαρει τους γνωστους βραχιονες της που αποτελουσαν σημειο αναφορας στην Ιαπωνικη αγορα και ηταν βασικος εξοπλισμος για ολα τα μεγαλα Micro Seiki της εποχης. Κορυφαία ποιοτητα κατασκευής, παρα πολλες ρυθμισεις. Η τιμη του "νεου" 4700 θα ειναι πανω απο 8.500 ευρω οποτε μου φαίνεται λογικο να δούμε και μια σημαντική αύξηση στις τιμες των μεταχειρισμένων. Εγω πούλησα τον δικο μου πριν μερικούς μήνες..
SAEC
WE 4700 tonearm
Double Knife Edge Bearings
Ceramic headshell
MSRP 8500-9500$
