Straight Outta Factory!
Kuzma Safir 9 tonearm
Unread post #331 by Dr Pan K » Fri Mar 18, 2022 1:18 am
NEW KUZMA SAFIR 9 TONEARM
After five-years of concerted research and development, an effort that has refined our existing designs and practices as well as introducing entirely new and unique materials, the revolutionary SAFIR 9 tonearm is finally ready for launch.
The Safir 9’s most obvious feature and the heart of the design is its conical sapphire arm tube. This provides the cartridge with unprecedented stability, delivering optimum electro mechanical performance from the generator. Extremely rigid, this tube is stiffer and offers a higher resonant frequency than any arm tube ever previously used. It's first break-up mode occurs at over 5KHz, providing the cartridge motor with a true mechanical ground.
Due to the use of a sapphire tube, this is a high effective mass tonearm!
The bearings are a further development of our own, proprietary 4Point design, the four contact spikes being located in sapphire/ruby receptacles. These ensure rigid, friction-free coupling of the tonearm to its mount, allowing the headshell to move, freely and precisely on the optimum path across the record.
The sapphire tube and bearings are fitted into massive solid aluminium and brass blocks, whose inert support helps dissipate the mechanical vibration generated during playback. The double brass counterweight (with locking mechanism) allows extremely precise application of VTF, while azimuth can also be precision adjusted in small, repeatable increments with zero play. The use of the sapphire armtube makes this an high effective mass tonearm, suitable for low compliance cartridges only.
The tonearm is mounted to the turntable's arm board using the Kuzma arm base. Arm height is adjusted with a fine VTA screw which controls the height of the tonearm's pillar in the arm base, allowing allows precise and repeatable adjustments whenever required.
The internal wiring uses special silver alloy wires that run, unbroken from the cartridge pins via a 1.5 m long tonearm cable to the silver RCA connectors.
SAFIR 9 reveals the ultimate potential of your cartridge, revealing musical detail, nuance and expression previously hidden in your record's grooves. Move up to the SAFIR 9 and you suddenly discover not just a whole new record collection, but that the music and musicians you've always loved are even better than you realized!
Technical data:
Effective length: 229 mm (9 inch)
Mounting distance: 212 mm
Offset angle: 23 deg
Effective mass: 60 g (Suitable for cartridges with CU below 25)
VTA adjustment: yes
Azimuth adjustment: yes
Bias adjustment: yes
Cables: silver (Kondo)
Arm mount: Kuzma arm base 212 mm
Mass: 1250 g
Informative price: 20.000 EUR
Re: Straight Outta Factory!
Unread post #332 by angpsi » Sun Jul 09, 2023 12:34 pm
Jony Ive designs limited edition Sondek LP-12 for Linn
Για τα 50 χρόνια του ιστορικού Sondek LP-12 η Linn ήρθε σε συνεργασία με την εταιρεία σχεδιασμού LoveFrom για να σχεδιάσει σε περιορισμένα κομμάτια μια νέα εκδοχή του πικαπ. Η LoveFrom αποτελεί σύμπραξη μεταξύ δύο φίλων, του Marc Newson και του Jony Ive, που και οι δύο αποτελούν από μόνοι τους δύο από τα μεγαλύτερα brand names στον χώρο του design (ο Jony Ive είναι ο άνθρωπος πίσω από τη σχεδιαστική γλώσσα της Apple από την εποχή του χρωματιστού iMac και μετέπειτα, συμπεριλμβανομένου και του iPhone). Το ενδιαφέρον είναι ότι ο Ive είναι fan της Linn και ήρθε ο ίδιος σε επικοινωνία με την εταιρεία για να συζητήσει την πιθανότητα συνεργασίας μεταξύ τους―μάλιστα ο CEO της Linn Gilad Tiefenbrun πίστεψε πως η αρχική επικοινωνία ήταν spam (!) και παρα τρίχα η συνεργασία να καταλήξει στα σκουπίδια πριν καν συζητηθεί (βλ. https://www.linn.co.uk/blog/the-story-b ... ek-lp12-50).
Η τιμή για το μοντέλο λίγο αλμυρούτσικη από £50,000 και πάνω, ανάλογα με τα φινιρίσματα, αλλά πρόκειται για συλλεκτικό μοντέλο σε περιορισμένα κομμάτια και μάλλον θα πουληθεί εύκολα σε συλλέκτες τέχνης και φετιχιστές της Linn.
Από το site της Linn: https://www.linn.co.uk/turntables/lp12-50
"Sondek LP12-50 marks the fiftieth anniversary of the most iconic product in hi-fi history. This limited edition turntable was designed with our friends at the creative collective LoveFrom.
Sondek LP12-50 produces the best vinyl playback performance Linn has ever achieved, alongside the immediately recognisable and iconic design language of Sir Jony Ive and his team at LoveFrom, applied in key visual and tactile interfaces.
The sonic improvement comes by way of Linn’s all-new Bedrok™ plinth technology; formed of orthogonal layers of beech placed under extreme pressure to create an entirely new, solid and massive material. The consequent ultra-dense wood has negligible resonance and offers a superior isolating housing for the turntable’s mechanism.
LoveFrom has applied their design expertise to the new, precision-machined power/speed control button and hinges – providing delightful and precise interaction with the turntable. Further aesthetic refinements to the classic Sondek LP12 form have been made with deep respect for the quality and integrity of the product.
The combination of performance, usability, and aesthetic improvements result in an historic piece with unrivalled sonic quality and beauty. Only 250 of these limited edition Sondek LP12-50s will ever be produced – with each bearing an embossed aluminium plaque celebrating this landmark collaboration with individual numbering. "
Unread post #333 by MILES » Sun Jul 09, 2023 10:19 pm
Η κατάσταση στο χώρο μας έχει ξεφύγει πια ανεξέλεγκτα.
Αν είναι δυνατόν ένα Sondek LP12, όσο καλό/επετειακό και να είναι, να κοστίζει £50,000 και πάνω!!!!
Σαν μία BMW X3. Μα είμαστε σοβαροί :shock: :shock:
Unread post #334 by pankon » Tue Jul 11, 2023 2:18 pm
MILES wrote:Η κατάσταση στο χώρο μας έχει ξεφύγει πια ανεξέλεγκτα.
Νομίζω ότι θα βρεθούν αρκετοί να αγοράσουν το επετειακό LP12, ειδικά όταν ακούσουν ΄ότι το έχει επιμεληθεί σχεδιαστικά ο Jony Ive.
Δεν θα μου κάνει εντύπωση αν αποφασίσουν να βγάλουν μια "βελτιωμένη" (ακριβή) έκδοση του LP12 με βάση την επετειακή.
Unread post #335 by MILES » Tue Jul 11, 2023 4:17 pm
Το ότι θα βρεθούν αρκετοί να το αγοράσουν δεν έχω καμμία αμφιβολία.
Για τη σοβαρότητα του όλου θέματος λέω. Ένα πικάπ Linn είναι στο τέλος-τέλος.
Πόση τεχνολογία και κόστος έρευνας/παραγωγής έχει για να το πουλάνε £50,000 και πάνω (το και πάνω μου άρεσε :-D ).
Γι' αυτό λέω ότι η κατάσταση στο χώρο μας έχει ξεφύγει πια ανεξέλεγκτα.
Unread post #336 by angpsi » Wed Jul 12, 2023 1:09 am
MILES wrote:Πόση τεχνολογία και κόστος έρευνας/παραγωγής έχει για να το πουλάνε £50,000 και πάνω (...)
Αν διαβάσεις προσεκτικά, θα δεις ότι το καπάκι έχει έναν προσεκτικά σχεδιασμένο μεντεσέ από machined aluminum (ή μήπως aluminium;) για να παραμένει σταθερό σε κάθε θέση.
(η παραπάνω φράση χρειάζεται τη φωνή του Jony Ive και περπατημένα Apple fanboys για να γίνει αμέσως κατανοητή ως αστείο)
:lol:
Unread post #337 by Dr Pan K » Wed Jul 12, 2023 10:30 am
Οι της Apple εχουν κανει και αλλες δουλειες με εταριες ηχου.. Η παρακατω ειναι σαφως ανωτερη (σχεδιαστικά, ποιοτικά, σε θεμα κοστολογισης) αλλα αν καποιος δεν τα υπολογιζει γιατι να μην τα δωσει για μια "συλλεκτικη" εκδοση πικαπ. Εχετε εικονα που εχουν φτασει οι τιμες καποιων ρολογιων? κατι τσαντακια γυναικεία?
https://parttimeaudiophile.com/2019/06/ ... -end-2019/
Unread post #338 by pankon » Wed Jul 12, 2023 11:19 am
Όταν ο Jony Ive σχεδιάσει το καινούργιο Roksan, θα το σκεφτώ. Ή ακόμα και ένα Lenco. Λες να βάλει χέρι και στα Garrard, γιατρέ;
Unread post #339 by Dr Pan K » Thu Jul 27, 2023 12:57 pm
Οτι σχεδιασει ο οποιοσδηποτε απο αυτους θα το αγορασω με κλειστα ματια και ανοιχτο πορτοφολι. Μην σου πω και 2 απο το καθενα. Εχω ηδη βαλει παραγγελια για το Linn καθως παντα ημουν οπαδος των χαλαρων και αργων χαμηλων καθως και της ασαφειας.
Unread post #340 by pankon » Sat Jul 29, 2023 8:55 am
Dr Pan K wrote:...παντα ημουν οπαδος των χαλαρων και αργων χαμηλων καθως και της ασαφειας.
Ντροπή! :lol:
