Isotek Evo3 Sirius πολυμπριζο-φιλτρο!
SouthKops
Unread post #1 by SouthKops » Fri Dec 29, 2017 6:19 pm
Isotek Evo3 SIRIUS πολύμπριζο 6 θέσεων, λίγων εβδομάδων, στο κουτί του.
Τιμή λιανικής 689 ευρώ , Προσφέρεται στα 400 ευρώ.
http://www.isoteksystems.com/products/p ... o3-sirius/
Sirius is a high-performance, multi-award-winning power bar, which protects and improves your precious audio components. A special wall bracket system allows Sirius to be mounted discretely behind your audio system.
Removes Common Mode and Differential Mode mains noise.
RFI reduction 40dB.
Independent outlets – no outlets are connected together, stopping Differential Mode mains noise cross-contamination.
Unique Inductive Resistance Gate© optimises the isolation between each of the six outlets.
KERP© (Kirchoff's Equal Resistance Path) ensures equal resistance and equal power delivery across all outlets. No outlet gets power before the next, a common problem with other power products which daisychain outlets together.
22,500A of instantaneous protection, featuring IsoTek's unique sequential protection system.
Internal wiring; multi-strand silver plated OFC copper with PTFE dielectric.
Maximum power, continuous 2,300W.
Πληροφορίες: 2103839399
