MQA and MQA ready DACs
Re: MQA and MQA ready DACs
Unread post #211 by Dr Pan K » Thu Feb 08, 2018 12:34 am
alpha dac.png (122.76 KiB) Viewed 3813 times
H Berkeley πρόσθεσε MQA rendering στο Alpha DAC! Τημ μιση δουλεια καλείται να την κανει το streamer/ software, την αλλη μισή το DAC. Ενδιαφέρουσα προσθήκη για οσους θελουν MQA (και έχουν 20Κ ζεστά ζεστά)
When Berkeley researched MQA and decided to add MQA to its products, Berkeley planned from the start to build an outboard device that would perform the MQA Core unfolding step outside the DAC chassis. Although the Alpha DAC Reference Series had enough spare memory and processing power to incorporate full MQA decoding within the chassis, Berkeley wouldn’t compromise the Alpha DAC Reference Series’ performance by adding this computationally intensive step. Berkeley planned to build its own Core unfolding device because at the time, MQA insisted that all MQA-compatible DACs be full decoders that perform all unfolding and rendering steps in the DAC. But in January, 2017 MQA changed course and allowed the Core unfolding in music-player software. This obviated the need for Berkeley to build its own outboard Core unfolding device.
That left Berkeley with the job of implementing MQA rendering in the Alpha DAC Reference Series in a way that wouldn’t add noise and compromise the oscillator performance. All MQA licensees are given the rendering code by MQA in a computer language called C++, which the licensee incorporates into its product. Pflaumer, however, rewrote the MQA code in assembly language to reduce the number of processor cycles required. In the process of rewriting the code and incorporating MQA’s rendering software with its own code, Pflaumer went back to first principles and rewrote the entire software. He used the opportunity to take a fresh look at every aspect of the code and discovered ways to make the Alpha DAC Reference Series even better sounding. (Thus the reason for my Picasso quote that begins this review.) As you can read in the review, this new software for the Alpha DAC Reference Series not only adds MQA rendering, it realizes an astonishing improvement in the sound of conventional PCM sources.
http://www.theabsolutesound.com/article ... ies-2-mqa/
Unread post #212 by Dr Pan K » Sun Feb 11, 2018 12:17 pm
Νέο, προσιτό DAC απο την Mytek, φυσικα με δυνατότητα MQA. Τιμη στα 995$, στο Thomann η τιμή θα είναι 918 ευρώ χωρις μεταφορικά.
Mytek Liberty DAC
CONVERSION: Up to 384k, 32bit PCM, native DSD. Up to DSD256, DXD, 127dB Dynamic Range.
MQA HI-RES DECODER: Βuilt-in certified hardware MQA™ decoder.
DIGITAL INPUTS: USB2 Class2 (OSX, Linux driverless, all formats), AES/EBU (PCM up to 192k, up to DSD64 DOP), 2x S/PDIF (PCM up to 192k, up to DSD64 DOP), Toslink/ADAT 2x S/PDIF (PCM up to 192k, up to DSD64 DOP).
ANALOG OUTPUTS: One pair of unbalanced RCA, one pair of balanced TRS, TRS to XLR. Metropolis cable can be added as option.
HEADPHONE AMPLIFIER: Reference high current, high transient Headphone Amp, 300mA, 3 Watts, single unbalanced headphone jack, designed to drive hard-to-drive headphones, 0.1 Ohm impedance.
CLOCK GENERATOR: Low noise with 10ps of jitter.
FIRMWARE: Upgradable via USB via Mytek Control Panel app for Mac and PC.
OPTIONAL DC/BATTERY POWER INPUT: 12VDC
DIMENSIONS: W x D x H = 5.5x8.5x1.74 inches / 140 x 216 x 44 mm
WEIGHT: 3 lbs., 1.5kg
Grandpa
Unread post #213 by Grandpa » Thu Feb 15, 2018 3:47 pm
Αν (...) τυχον σχεδιαζετε συγκριτικο dacs με mqa (ή και χωρις ή θελετε μονον γι αυτο), ευχαριστως να σας στειλω το m2tech young mkiii
Unread post #214 by Dr Pan K » Fri Feb 16, 2018 8:57 am
Grandpa wrote:Αν (...) τυχον σχεδιαζετε συγκριτικο dacs με mqa (ή και χωρις ή θελετε μονον γι αυτο), ευχαριστως να σας στειλω το m2tech young mkiii
Ευχαριστούμε πολύ για την ευγενική πρόταση! Το M2tech Young III τον είχαμε για αρκετές ημέρες στην κατοχή μας αλλά να πω την αλήθεια η χρήση του MQA περιορίστηκε στον απλο έλεγχο της σχετικής λειτουργίας καθώς κατ' εμέ το φόρματ είναι αδιάφορο αν όχι ήδη νεκρό. Απ όσο είδα δε δεν υπαρχει και τόσο μεγάλο ενδιαφέρον απο την κοινότητα οπότε η ιδέα συγκριτικού πάγωσε.
Επειδή κάποιες συγκρίσεις τις έκανα με το Mytek Brooklyn Dac + νομίζω ότι οι οποίες διαφορές οφείλονται περισσότερο στο remaster και το roll off παρά σε κάποια ουσιαστική (και ανυπόστατη) βελτίωση της αρχικής ηχογράφησης.
Grandpa
Unread post #215 by Grandpa » Fri Feb 16, 2018 2:11 pm
Συμφωνω απολυτα περι mqa!
Σαν ντακ τι εντυπωσεις αφησε;
Unread post #216 by Dr Pan K » Fri Feb 16, 2018 2:24 pm
Grandpa wrote:Συμφωνω απολυτα περι mqa!
Θα γράψω ένα hands on το συντομότερο.
Unread post #217 by Dr Pan K » Tue Mar 20, 2018 10:11 pm
MQA Live.jpg (78.3 KiB) Viewed 3707 times
Live απο MQA..
MQA recently debuted “MQA Live”, a new way for fans to connect to musicians. Jake Isaac and his band performed from London's Rocket Studios – the first time a live performance has been streamed in real time using MQA's technology. The performance was listened to live in an Austin home on a variety of devices to recreate everyday listening environments.
Unread post #218 by Dr Pan K » Sun Mar 25, 2018 11:15 am
Unread post #219 by BityaBit » Mon Mar 26, 2018 1:04 am
Το ειδα και συμφωνώ με την στάση του. Οντως δεν ειναι το MQA ικανό να πείσει τον σκληροπυρηνικό audiophile που εχει επενδύσει χρονο χρημμα και εμπειρια για να πετύχει καποιο συγκεκριμενο αποτελεσμα που η ολη deblurring διαδικασία μπορει να επηρεάσει, επισης σαφως και δεν καλύπτει σε απολυτο βαθμό τα αυστηρά στάνταρ που το χομπι δημιουργεί στο μυαλό των πωρωμενων χαιφιντελαδων.
Απο την αλλη ειναι ηδη too good to be true για το 99,9% όσων θα το ακούσουν και δεν εννοω τους Audiophiles αν καο συμπεριλαμβάνω ενα πολυ σημαντικο αριθμό τους, ενω παραμένει απιστευτα βολικό και εύκολο στην χρηση αλλα και την κατανόηση και του πιο άσχετου.
Συνεπώς οχι δεν ειναι το «φάρμακο του καρκίνου» απο την αλλη ουτε ο διαβολος επι της γης. Η ψηφιακή αναπαραγωγή ήχου εχει δει και πραγματικα άσχημα φαινόμενα οπως τον ηχο του δημοφιλέστατου redbook μεχρι πριν απο μια σχεδον δεκαετία. Προσωπικα το βλεπω σαν ενα βημα προς την σωστή κατεύθυνση αρκεί να καταφέρει ποτε να γινει πραγματικα δημοφιλές δηλαδη να υιοθετηθεί και απο καποιον πραγματικα μεγαλο πάροχο streaming.
Η ικανότητα του να παρέχει ηχο πραγματικα υψηλών στάνταρ χωρις την αναγκη θεωρητικά τουλαχιστον πανάκριβου niche εξοπλισμού στις μάζες μονο κακο πραγμα δεν μπορει να θεωρηθεί.
Unread post #220 by BityaBit » Fri Mar 30, 2018 1:10 pm
Καλά νέα για όλους τους χρήστες συσκευών ντάκ της Ifi και Fan του ΜQA.
Παρακάτω το link με την ενημέρωση firmware που ενεργοποιεί την δυνατότητα Hardware decoding MQA σε όλες τις αντίστοιχές συσκευές απο το 2013 και μετά!... Θυσιάζει την δυνατότητα αναπαραγωγής DSD512 επιτρέπει μόνο μέχρι DSD 256.
Για όσους δεν προτιμούν το MQA ή ακούν μέσω software DSD upsampling παραμένει διαλέσιμο firmware χωρίς την δυνατότητα αυτη αλλά και χωρίς τον περιορισμό της αναπαραγωγης DSD στο DSD 256 για όσους διαθέτουν ντάκ της εταιρίας που φτάνουν εώς DSD 512.
https://ifi-audio.com/audio_blog/mqa-firmware/
