Cayin iDAC-6
Cayin iDAC-6
Unread post #1 by Gojakla » Wed Jun 15, 2016 12:46 pm
Official Site
FEATURES
D/A conversion by a pair of 32-bit AKM AK4490 "Verita" chips operating in dual-mono mode.
XMOS USB input implementation capable of handling single and double-rate DSD as well as PCM up to 32-bit/384kHz.
5 digital filters.
Selectable tube or solid state outputs via the system menu controlled by the volume knob.
Analog output stage based around the Texas Instruments OPA604 and OPA2604 FET opamps.
4 x 6N1B tubes as an additional buffer stage.
Built-in Phase selection to ensure perfect playback.
Extensive Mute protection and noise control, minimise pulse noise when Power on/off, and noise generated at changing of operational stages such as UNLOCK.
LCD display which shows all manner of useful info (eg. active input, incoming sample rate, PCM or DSD, etc.)
Solid aluminum alloy chassis with sand blast finishing.
SPECIFICATIONS
Output Level
Line Out RCA:2.2V RMS
BAL:4.4V RMS
Pre Out RCA:2.2V RMS (Max.)
BAL:4.4V RMS (Max.)
Frequency Response
20Hz~30kHz (±0.5dB,Fs=192kHz)
THD+N
Tube: ≤0.8% (Fs=192kHz)
Transistor: ≤0.004% (Fs=192kHz)
S/N
Tube: ≥105dB (A-weighted)
Transistor: ≥110dB (A-weighted)
USB
DSD: support DSD64 DSD128
PCM: support up to 32Bit/384kHz
AES/EBU, Coaxial, Optical
PCM: support up to 24Bit/192kHz
Max. Power Consumption
30W
Dimensions
240mm x 252mm x 69mm (WxDxH)
Weight
3.8kg
GALLERY
Re: Cayin iDAC-6
Unread post #2 by Gojakla » Wed Jun 15, 2016 12:47 pm
Κόστος στα $999.
Βλέπω ότι στέκεται ακριβώς απέναντι στο Teac UD-503 και μάλιστα με ίδιο chip.
Θα ήμουν πολύ περίεργος να το ακούσω.
Υπόψιν πως δεν δίνει την δυνατότητα για οδήγηση ακουστικών.
Είναι pure DAC.
Re: Cayin iDAC-6
Unread post #3 by Dr Pan K » Wed Jun 15, 2016 3:08 pm
Gojakla wrote:Υπόψιν πως δεν δίνει την δυνατότητα για οδήγηση ακουστικών.
Είναι pure DAC.
Και πολύ καλά κάνει.
ΥΓ Δύσκολη κατηγορία αυτή των <1000 €. Το Teac 503 πολύ καλό και υποψιάζομαι ότι κι αν ο Κινέζος δεν θα είναι καθόλου άσχημος. Αναμένουμε δε και νέα πρόταση από την Audiobyte
Re: Cayin iDAC-6
Unread post #4 by Gojakla » Wed Jun 15, 2016 5:37 pm
Dr Pan K wrote:Αναμένουμε δε και νέα πρόταση από την Audiobyte...
[bart]
