Kαί η MSB MQA..
http://www.monoandstereo.com/2016/10/mq ... ducts.html
MQA and MQA ready DACs
Re: MQA and MQA ready DACs
Απο την στιγμη που ολοι πια ξέρουν οτι το ΜQA ειναι απολεστικο format το τροπάριο εχει αλλάξει. Προσπαθούν να υποβαθμίσουν τα digital downloads σαν ύποπτα ενω τονίζουν οτι το MQA θα ειναι εγγυημενο. Το σημαντικό ειναι οτι η Warner ετοιμάζει ολόκληρη την μεχρι τωρα παραγωγή της σε MQA και ο Bob ελπίζει οτι και οι αλλοι δυο κολοσσοι (Sony, Universal) θα ακολουθησουν
http://www.stereophile.com/content/mqa- ... real-scoop
Please explain this notion of authenticity, or, as Stuart put it, "the definitive thing."
"Say I can go to a store and buy a 192 of this album," Stuart said. The file you end up with may not be—in fact probably isn't—the "flat" master the label signed off on. "We could go to stores today and find a lot of 96k content, and this is often or usually not the original master, because what labels are inclined to do is to produce a real master, and then they'll produce something from that from which they cut vinyl and then they'll make a separate deliverable for iTunes." A record company may ultimately deliver up to 50 different formats, Stuart said. "The iTunes spec means that a lot of the 96k [files] around that are at least one generation away from the masters."
Files may also be manipulated after they're released. "You can go to stores like HDTracks or High-Res Audio and you say, I'd like this bit of music, and you find it's available in DSD, quad DSD, DXD, 192, 96, or 48. And you think, 'OK, I'll buy the one with the biggest number.' But what we go for is the authentic one. Because typically what's happening is these retailers are sent a file, they could be sent an [88.2kHz version], and then they make all the DSD out of it because they can charge more for it." With MQA you can have confidence that the file was produced from the master the label or artist prefers. If the file is manipulated post-release, the MQA light won't shine.
Οταν βρωμισει ο τοπος απο δαυτο ολοι θα εχουν μια καλη κουβεντα να πουν ακομα και οσοι το θαβουν. Οσο για τους audiophiles. Αφου δεχτηκαν το Cd και το Lp καποτε μην εχοντας αλλη επιλογη το ιδιο θα κανουν και με το MQA αν επικρατησει και γιατι να μην το κανουν; Οσες αναμενομενες γκρινιες να υπαρχουν δεν μπορει να ειναι τρελοι ολοι οσοι rrviewers το εχουν ακουσει και το βρηκαν εξαιρετικο (γιατι εγω να τω δεχτω πως ειμαι δεν εχω κανενα προβλημα).
Θετικό βήμα για το MQA, τα λειτουγικα Linux το υποστηρίζουν. ΠΧ το MoOde στην εκδοση 2.7 http://moodeaudio.org/
Anotherone bites the dust..
Δυναμικά μπαίνει και η Μytek στην αγορά των υπερφορητών ντάκ ενισχυτών ακουστικών για αναβάθμιση της on the go ποιότητας απο smartphone.
To Μytek Clef θα υποστηρίζει ως 24/192 DSD128 και όπως είναι αναμενόμενο και MQA μιας και η Mytek ανήκει στον σκληρό πυρήνα κατασκευαστών που υποστηρίζουν αυτό το αμφιλεγόμενο αλλα και πολλά υποσχόμενο φορμάτ απο τα γεννοφάσκια του.
Θα έχει ενισχυτή ακουστικών που θα παρέχει ισχύ διπλάσια απο οποιαδήποτε smartphone και παραδοσιακά για mytek θα τρέχει με τσιπάκι της Εss, το 9018.
Ιδιαίτερα ενδιαφέρουσα η δυνατότητα ασύρματης σύνδεσης με φορητές συσκευές μέσω Bluetooth AptX ή AAC σύνδεσης σε iPhone 7 που είναι και το βασικό feature που θα το κάνει να ξεχωρίσει κατα την άποψη μου.
Αναμένεται να πρωτοπαρουσιαστέ στην CES του 2017 σε λίγες μέρες και στην αγορά το δεύτερο μισό του 2017 με τιμή στα 300 δολλάρια.
To Mytek Clef θα είναι μια παταγώδης αποτυχία. Οτι πιο άσχημο εχω δει ποτε σε φορητή συσκευή, κοντραρει στα ισια το LH Labs Geek V2 και αυτο λέει πολλά. Ο μέσος χρήστης iPhone που αγοραζει κινητο για το design του λειτουργικου και της συσκευης δεν θα γυρισει καν να το κοιταξει. Ελεος, ουτε οθόνη δεν έχει. Και πραγματικα το οτι παιζει MQA με αφήνει παγερα αδιάφορο (ποσο μαλλον τους χρηστες iPhone) μια που ακόμα δεν εχουμε δει τίτλους ενω το hype ξεφούσκωσε οταν επιβεβαιώσαμε οτι ειναι απολεστικο format.
Ενα μαύρο φλασκι για ουίσκι, μάλλον μεθυσμένος ηταν ο Πολωνός όταν το σχεδίασε.
Κατι αρχιζει να κινειται.. http://tidal.com/gr/masters
Αντρεα νομιζω οτι και το δικο σου ντακ υποστηριζει MQA σωστα;..
