Straight Outta Factory!
Re: Straight Outta Factory! Wilson Audio Autobiography
Unread post #351 by Dr Pan K » Fri Apr 24, 2026 9:22 am
Wilson Audio
Autobiography
Autobiography Red Rock Sunset Front 3-4-2.JPG (1019.96 KiB) Viewed 83 times
At the core of Autobiography lies a completely new driver complement. This is a five-way loudspeaker configured in an M(MTM)M array, with every transducer making its first appearance in this system. Each driver was conceived specifically for Autobiography, not developed as an isolated component, but as part of a unified acoustic architecture.
The vertical arrangement consists of a 7-inch midrange at the top and bottom of the gantry, followed by a symmetrical MTM crescent framed array composed of dual 2-inch midrange drivers flanking the CSLS front-firing tweeter. This assembly creates a mirror structure that reinforces coherence through the critical vocal and instrumental regions. Low frequencies are handled by two dissimilar woofers, a 12-inch unit and a 15-inch unit, developed exclusively to operate together. Completing the driver lineup is a rear-firing ambient tweeter designed to enrich
spatial information.
MSRP $788.000
Autobiography Red Rock Sunset MTM Alingment Assembly Tweeter.JPG (1.04 MiB) Viewed 83 times
Autobiography Red Rock Sunset Upper Side 2.JPG (974.36 KiB) Viewed 83 times
Unread post #352 by Dr Pan K » Fri Apr 24, 2026 9:24 am
Autobiography Alingment Scale.JPG (835.7 KiB) Viewed 83 times
Autobiography Ethereal White Central Nervous System Gantry Binding Posts.JPG
Autobiography Ethereal White Central Nervous System Gantry Binding Posts.JPG (1.75 MiB) Viewed 83 times
Autobiography Ethereal White Copper Heat Sinks.JPG (1012.2 KiB) Viewed 83 times
Autobiography Ethereal White Front 3-4 1-2.JPG (1019.91 KiB) Viewed 83 times
Unread post #353 by Dr Pan K » Fri Apr 24, 2026 9:30 am
Autobiography NZ Black Sand.jpg (426.55 KiB) Viewed 82 times
Autobiography Crowned Rose Red Grille.JPG (1.11 MiB) Viewed 82 times
