Straight Outta Factory!
HiFiMan Edition 6 and EF1000 amp
Unread post #111 by Dr Pan K » Tue Feb 14, 2017 7:22 pm
HiFiMan
Edition 6 Planar Magnetic headphones and
EF1000 headphone amplifier
MSRP: $5995 x Edition 6!
hifiman edition 6.jpg (684.66 KiB) Viewed 8200 times
edition 6 EF1000.jpg (193.81 KiB) Viewed 8200 times
Just across the aisle, HiFiMAN set up shop with their wide and ever-growing catalog of products. Among them was the brand new flagship Edition 6 prototype (est. $5,999). This headphone has been a bit of a flashpoint in the conversation about flagship pricing over on Head-Fi.org, and moderators were eventually forced to lock the thread, in spite of their best efforts to keep things civil. It's probably a bit too early to judge based on this early prototype, but I didn't find the sound to be particularly special, given the gaudy asking price. While it was exceptionally neutral and clear, it didn't possess the visceral dynamism of the Abyss AB-1266, the musicality of the Audeze LCD-4, the superb refinement of the Focal Utopia or the detail of Stax SR-009. If the Edition 6 is going to succeed, it's going to need to find a real identity in future iterations.
Η τιμη εχει εξοργίσει αρκετούς γιατι τελευταία η HiFiMan εχει αρχίσει να δέχεται κριτικές για την ποιοτητα κατασκευής της. Οπως και να εχει μολις κυκλοφορήσει θα είναι το ακριβότερο stand alone ακουστικό του κόσμου, ξεπερνώντας το Abyss για $500. Το Stax 009 φαντάζει πια φτηνό στα 3.500
http://www.enjoythemusic.com/CanJam_NYC_2017/
Apurna
Unread post #112 by Dr Pan K » Wed Feb 15, 2017 6:40 pm
Apurna
Made in France high end amplifiers
Every aspect of our monophonic amplifier has been considered down to the finest detail, even incorporating aerospace components. You’ll find 24-carat gold finishes on certain mechanical and electronic components, and 6-layer printed circuit boards.
The chassis is of aluminium, formed as one single part to ensure reliability and freedom from vibration.
Bandwidth: DC to 430KHz (+0 ; -3dB) or DC to 80KHz (+0 ; -0,1dB)
RMS output power: 200W (8 Ω) ; 400W (4 Ω)
Dimensions: 400x400x245 mm
Weight: 47.5 kg for a standard trim
Inputs available :
2 XLR sockets (1 in Bypass mode)
3 RCA sockets (1 in Bypass mode)
2 Phono level RCA sockets (MM & MC)
WBT speaker outputs
apurna power.jpg (217.19 KiB) Viewed 8193 times
apurna amp.jpg (405.05 KiB) Viewed 8193 times
http://www.apurna-france.com/en/accueil-en/
Re: Straight Outta Factory!
Unread post #113 by Dr Pan K » Wed Feb 15, 2017 9:37 pm
Channel Islands Audio
PEQ 1 MKII MM/MC Phono stage
RIAA Accuracy: +/- 0.2 dB
THD + Noise: < .002% (1kHz Unweighted/45dB gain/10mV)
IMD: < .002% (SMPTE)
Crosstalk: > 108dB
Cartridge Loading:
Resistance: 47KΩ • 10KΩ • 1Ω • 100Ω
Capacitance: 100pf • 270pf • 370pf
Gain: 45dB • 60dB
Subsonic Filter: -3dB @ 18Hz
Output Impedance: 100 ohms
Operating Voltage: 120V AC Input • 14V AC Output (Standard Supply)
Power Consumption: < 4.0 Watts
Dimensions: 8.50″W x 2.75″H x 6.50″D
Weight: 6.5 lbs. (actual), 7.0 lbs. (shipping)
Retail Price $995
Esoteric Grandioso K1 SACD player
Unread post #114 by Dr Pan K » Thu Feb 16, 2017 10:04 pm
Esoteric
VRDS-NEO VMK-3.5-20S transport mechanicsm
Toroidal power supply for the driver
AKM 4497 DAC and Muses 03 Op Amps
35-bit D/A Processing
32bit/384KHz and Dual DSD
MSRP $27.000
http://www.esoteric.jp/products/esoteric/k1/indexe.html
Unread post #115 by Dr Pan K » Fri Feb 17, 2017 11:36 pm
NIME
Elite Two speaker
Enclosure Type Woofer: Closed box
Woofer: 22 cm Hard Paper Cone
Tweeter: 3 cm Ceramic Dome
Sensitivity: 92 dB @ 1W @ 1m @ 1k
Nominal Impedance: 4 ohms
Minimum Amplifier Power: 20 Watts per channel
Frequency Response: 34 Hz – 20 kHz +/- 3 dB
Enclosure Dimensions: Height: 118 cm, Width: 50 cm, Depth: 70 cm
Weight: 40 Kg each
Price: 18,000€
Unread post #116 by Dr Pan K » Mon Feb 20, 2017 8:47 pm
ΕΑΜ
102i integrated amplifier
100 + 100 Wrms 8 ohm
180 + 180 Wrms 4 ohm
4 single-ended input via RCA
1 balanced input via XLR
Dual mono circuitry
THD+N>108dB
18Kgr
EAM 102i.jpg (53.63 KiB) Viewed 8145 times
EAM 102i inside.jpg (66.71 KiB) Viewed 8145 times
Unread post #117 by Dr Pan K » Sun Feb 26, 2017 1:10 pm
Tannoy
Legacy series speakers
Based on Dual Concentric HPD technology from the '70s
Eaton stand-mount sensitivity 87.5dB
Cheviot two-way floorstander 89dB
Arden floorstander 91dB
tannoy legacy.png (223.35 KiB) Viewed 8124 times
Tivoli Audio Model One Digital
Unread post #118 by Dr Pan K » Wed Mar 08, 2017 8:32 pm
Tivoli Audio
Model One Digital
Spotify ready
MSRP $300
tivoli digital.jpg (89.4 KiB) Viewed 8104 times
Unread post #119 by Dr Pan K » Thu Mar 09, 2017 8:37 pm
Densen
CAST streamer/ integrated amplifier/ DAC
Output power: 2 x 60 W 8 Ω / 2 x 120 W 4 Ω
Power supply: 400 VA and 20.000 uF
9 individual powersupplies
5 volt trigger for remote control, when used as pure poweramp
Upgradeable DAC
Controllable via GOOGLE CAST AUDIO
Available in both Albino silver and black
MSRP 3500 euro
Trafomatic Audio Evolution series
Unread post #120 by Dr Pan K » Tue Mar 14, 2017 4:33 pm
Trafomatic Audio
Evolution series
complete line with
pre-amplifier
power amplifier
integrated
phono stage
