Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #121 by Dr Pan K » Wed Mar 22, 2017 7:06 pm
Linnenberg Audio
Allegro power amplifier
Input sensitivity: 1,5 V rms
Gain: 22,8 dB
Power output: 55W/8Ω, 90W/4Ω, 105W/2Ω
Peak output voltage: 68 V pp
Peak output current: +/- 20A continuous 1 : 10 cycle
Frequency range: 0 ... 350 kHz with filters, 0 ... 1MHz without filters
Full power bandwidth: 0 ... 300kHz
Rise time: 700ns
Damping factor: > 500
Signal to Noise ratio (SNR): 116dB linear BW = 30kHz 120 dB (A)
Distortion and noise (THD+N): 0,004%
Screen Shot 2017-03-16 at 22.24.04.jpg (39.82 KiB) Viewed 8682 times
Unread post #122 by Dr Pan K » Fri Mar 24, 2017 7:01 pm
MSB
Reference DAC
2 box design
MSRP 40.000 euro
msb_technology_reference_dac_review_matej_isak_mono_and_stereo_2017_2018 - 4-1.jpg
msb_technology_reference_dac_review_matej_isak_mono_and_stereo_2017_2018 - 4-1.jpg (528.79 KiB) Viewed 8667 times
Unread post #123 by BityaBit » Fri Mar 24, 2017 10:09 pm
.....πάρε κόσμε...
Unread post #124 by Dr Pan K » Mon Mar 27, 2017 9:18 pm
Avid
CELSUS PRE/POWER &
SIGSUM INTEGRATED AMPLIFIERS
Alps RK50 volume pot
Prices TBD
AVID HIFI CELSUS & SIGSUM PRODUCTS.jpg (182.05 KiB) Viewed 8647 times
Lab12 Noyra
Unread post #125 by Dr Pan K » Tue Mar 28, 2017 10:00 pm
Lab12
Noyra power conditioner/ distributor
2 low filtering outputs
4 high filtering outputs
Common and differential mode filters
Overvoltage protection
Total output 3500W
Star design ground, phase, neutral
High current switch
OFC high grade cables
Anti-resonance construction
http://www.lab12.gr/
noyra in.jpg (787.14 KiB) Viewed 8639 times
noyra back.jpg (331.58 KiB) Viewed 8639 times
Unread post #126 by Dr Pan K » Sun Apr 02, 2017 1:17 pm
Weiss
DAC 502
DSD & DXD capable
Roon Ready
MQA support
Room Equalizer
Headphone output
MSRP TBD
Unread post #127 by Dr Pan K » Fri Apr 07, 2017 12:26 am
Wyred 4 Sound
DAC 2v2
ESS Sabre 9028PRO 32 bit DAC chip
W4S proprietary discrete output stages for optimum sonics
ESS Time Domain Jitter Eliminator®
Automatic oversampling for precise output filtering
Asynchronous USB input and balanced I²S​ input support up to 32-bit 384kHz PCM and up to DSD256
US$2299
DAC 2v2 SE
ESS Sabre 9038PRO 32 bit DAC chip
Custom Vishay Z-Foil resistors (0.1% tolerance and a +/-0.5ppm/°C)
Femto Grade Clock (82 fSec phase jitter)
Ultra-low noise discrete regulators (100+ times quieter and faster than the stock regulator)
Ultra-fast recovery Schottkey diodes
Premium grade inductors
Upgraded fuse
US$3799
Unread post #128 by Dr Pan K » Mon Apr 10, 2017 7:09 pm
Goldmund
Telos 1000 NextGen,Telos 2500 NextGen και Mimesis 22 NextGen amplifiers
new input board
stronger power supply
added filtering capacitance
http://www.goldmund.com/en
Unread post #129 by Dr Pan K » Wed Apr 12, 2017 12:48 am
Playback Designs
Dream Series
MPD-8 DAC and MPT-8 Digital Music Transport
Sampling rate up to Quad DSD
Discrete converters
Optional incorporated music server (Syrah)
MSRP $22.000 DAC, $14.000 SACD, $20.000 including streamer
Info @ Aphrodite's Vision
playback designs dream.png (235.56 KiB) Viewed 8565 times
Unread post #130 by Dr Pan K » Thu Apr 13, 2017 12:44 am
Audio Analogue
AAcento integrated amplifier
100Watt/8Ohms
Zero feedback
MM/MC Phono stage
Quality headphone output
MSRP 3250 euro
