Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #131 by Dr Pan K » Mon Apr 17, 2017 6:21 pm
Pass Labs
XA 25 power amp
2x 25 Watts Class A @ 8 ohms
2x 50 Watts Class A @ 4 ohms
2x 100 Watts Class A/AB @ 2 ohms
Distortion: 0.1% @ 25 Watts, 8 ohms, 1 KHz, 0.1% @ 50 Watts, 4 ohms, 1 KHz
Freq. Response: DC to 200KHzdB @ 3dB
Gain: 20 dB gain
Noise: Output 100 uV unweighted 20 to 20 KHz
Damping Factor: 200
Slew: 100 V/uS
Input Impedance: 47 Kohm
Peak Current: 10 Amp output (200 Watts into 2 ohms) Independent of loudspeaker load phase.
Protection: Shutdown at 10 amps output
Idle Power draw: 200 Watts total.
Dimensions: 17” W x 17.4” D x 6” H
Weight: 46 pounds/21 kilograms
MSRP: $4,900
https://passlabs.com/amplifier/xa25
Unread post #132 by Dr Pan K » Tue Apr 18, 2017 3:25 pm
Avid HiFi
Reference Subwoofer
140 Kgr!
1200Watt Class D amp
2x12" woofers
DSP room correction
MSRP 20.000GBP
AVID_Sub with Ref4.jpg (285.67 KiB) Viewed 9336 times
Unread post #133 by Dr Pan K » Thu Apr 20, 2017 11:47 pm
Dan D'Agostino
Progression stereo power amplifier
2x300/8, 2x600/4, 2x1200/2 Ohm !
Super Rail circuitry
3000VA power transformer
400.000 mF filtering capacitance
57Kgr
MSRP $22.000
OPPO UDP-205 Audiophile Universal Player
Unread post #134 by Dr Pan K » Sun Apr 23, 2017 12:07 pm
2x ES9038PRO DAC
dedicated stereo output
7.1-channel analog audio output
768 kHz PCM and DSD 512
MSRP $1299
https://parttimeaudiophile.com/2017/04/ ... rettyPhoto
Metaxas & Sins Sirens
Unread post #135 by Dr Pan K » Mon Apr 24, 2017 10:26 pm
Metaxas & Sins
Sirens
3 way speakers?
MSRP TBD
sirens 1.jpg (47.48 KiB) Viewed 9284 times
sirens 2.jpg (37.66 KiB) Viewed 9284 times
Pro Ject Sgt. Pepper Limited Edition
Unread post #136 by Dr Pan K » Fri Apr 28, 2017 9:09 pm
Pro Ject Audio Systems
Sgt. Pepper’s Lonely Hearts Club Band 50 years anniversary turntables
Essential III Sgt. Pepper‘s Drum fitted with Ortofon OM-10 @ 499 euro
and
2Xperience SB Sgt. Pepper Limited Edition @ 1399 euro
Limited @ 1000 units per design
Nordost Q-Kore grounding box
Unread post #137 by Dr Pan K » Tue May 02, 2017 9:09 pm
Nordost QKORE
The QKORE is a parallel grounding device, which provides an artificial, “clean” earth for hifi audio systems using both an electrical and mechanical approach. This unique product combines Nordost’s patented Mono-Filament technology with purpose-built, Low-Voltage Attractor Plates (LVAPs), constructed with a proprietary metal alloy and a passive electronic circuit, in order to draw stray high frequency noise and voltage-generated magnetic fields to a manufactured earth point, leaving a clean reference behind.
Περισσότερες πληροφορίες στο Orpheus Audio
Unread post #138 by Dr Pan K » Fri May 05, 2017 10:23 pm
Marten
Coltrane Tenor 2
3 way speaker
Ceramic drivers by Accuton
MSRP TBD
more info @ Aphrodite's Vision
coltrane tenor 2.png (190.39 KiB) Viewed 9243 times
Black Cat Indigo IC
Unread post #139 by Dr Pan K » Tue May 09, 2017 11:46 am
Black Cat
Indigo interconnect cable
99.999% silver over copper
Teflon dielectric
MSRP $9.495
Unread post #140 by Dr Pan K » Thu May 11, 2017 10:13 pm
Magico
M6 3 way, 5 driver speaker
Aluminum and Carbon fiber cabinet
Tweeter: 1.10" Diamond-Coated Beryllium Dome (x1)
Midrange: 6” XG Nanographene Cone (x1)
Bass: 6” XG Nanographene Cone (x1)
10.5” XG Nanographene Cone (x3)
Sensitivity: 91dB
Impedance: 4 ohms
Frequency Response: 22Hz – 50 kHz
Minimum Recommended power: 30 Watts
MSRP $172.000
Άραγε να παίζει και καθόλου μουσική ??
