APHRODITE'S Vision
Audiohub Mod Team
Contact:
APHRODITE'S Vision
Unread post #1 by Audiohub Mod Team » Mon Jul 18, 2016 6:43 pm
Official Site
FROM THE ARTIST'S SOUL TO THE LISTENER'S EMOTION
Since 2005, Aphrodite’s vision represents in GREECE and CYPRUS leading sound equipment brands of
international reputation. All equipment is covered by technical assistance.It is 10 years already
that we are offering our extended experience and know-how providing our customers with our
recommendations and the most suitable tailor-made solutions, depending on their needs.
Award-winning brands such as NAGRA, AAVIK, ANSUZ, RAIDHO ACOUSTICS, DARTZEEL,
YG ACOUSTICS, AUDIENCE, BAT, BRINKMANN, ROKSAN, THALES TONEARM, MARTEN DESIGN, MODWRIGHT,
ACCOUSTIC ARTS, PLAYBACK DESIGN, WHEST AUDIO, VIBEX, PSI, AUDIOPHILE BASE, LEWITT, SCANSONIC, EMT
among others, share our philosophy which consists of merging cutting-edge
technology with values of the past, always in full respect both of the artist and of the listener.
“Music restoration” rather than “music reproduction”, defines in a few words our approach towards
achieving our objective, namely the perfect harmony between the sound system, realism and
musicality while avoiding auditory fatigue.
Contact:
Aphrodite's Vision (GREECE)
Sokratous 2, 152 32 Chalandri
tel.: 210 68 13 773
fax: 210 68 33 760
mobile: 6944 753108
e-mail: info@aphroditesvision.com
Aphrodite's Melody (FRANCE)
http://www.aphroditesmelody.com
tel: (+33) 06 03002124
fax: (+33) 01 46268490
e-mail: info@aphroditesmelody.com
Aphrodite's Factory
http://www.aphroditesfactory.com
tel.: 210 68 13 773
fax: 210 68 33 760
mobile: 6944 753108
e-mail: info@aphroditesfactory.com
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Re: APHRODITE'S Vision
Unread post #2 by Audiohub Mod Team » Mon Jul 18, 2016 7:05 pm
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Nagra @ Montreux Jazz fest
Unread post #3 by Audiohub Mod Team » Tue Jul 26, 2016 10:41 pm
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
YG Sonja 1.2 @ Newport 2016
Unread post #4 by Audiohub Mod Team » Sun Aug 07, 2016 11:30 am
Some gear in this price range leans toward being “audio jewelry” where the perceived appeal may go beyond its music-making ability. But while both the MSB and YG Acoustics components are fine-looking items, they don’t appear to have been built primarily as eye candy. Instead, the emphasis clearly is on exceptional music-making. For discriminating audiophiles undeterred by the price tags, ownership could be a very rewarding experience. For the rest of us … well, that lottery money has to go somewhere.
https://parttimeaudiophile.com/2016/08/ ... the-metal/
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Nagra HD Amp
Unread post #5 by Audiohub Mod Team » Mon Aug 22, 2016 1:30 pm
It all started from our customers who could not use Nagra amplifiers, like the acclaimed Nagra MSA, in their bigger systems because they needed more power to accommodate demanding speakers or a very large room. They were frustrated to mix and match Nagra sources, such as the HD DAC, with other brands for amplification.
Early in the development stage, we realize that we could push the limits of what is possible to achieve in an amplifier, if we allowed ourselves to have a larger chassis. We took inspiration from the world-acclaimed Nagra VPA amplifier and designed elegant tower-shaped monoblocks.
The power supply goes to extremes to make sure the amplifier is stable and can deliver high power at any time. It is built around a 1600 VA transformer. In Nagra’s own tradition it is followed by a multiple diode stage and a very complex dual PI filter. This allows the amplifier voltage rails to be extremely stable. In addition, the current draw from the HD AMP is not polluted by impulse signals. So the rest of the set-up can perform at its best. The dual Pi filter acts like a protection shield between the HD AMP and the mains.
Each Nagra HD AMP unit features a bank of 264 mF of custom-made Mundorf condensers. They are the reference in their category and you rarely meet them in this quantity because most manufacturers consider them too expensive. We have chosen them after many hours on the test bench and numerous critical listening sessions.
The Nagra HD AMP audio amplification stage is relatively simple in its conception; this is in part what makes it so transparent and direct. Actually, each stage has been tuned to reach striking results. The driver stage for instance features numerous decoupling capacitors of different technologies. It has a very low output impedance to make the most of the power MOSFETs that follow.
Like all its famous predecessors in Nagra range, the HD AMP, uses MOSFET, field effect transistors. They are the closest thing to a valve triode and you can definitely feel its sonic character: direct, fast and musical. The HD AMP has precisely matched clusters of MOSFET, to insure the purest reproduction.
Power 250 W RMS per channel into 8 Ω
30 W pure class A
1000 W RMS on lower impedance
http://www.nagraaudio.com/hd-amp/
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
YG Acoustics CARMEL 2 review @ High Fidelity Pl
Unread post #6 by Audiohub Mod Team » Wed Aug 31, 2016 9:50 pm
The smallest model in YG Acoustics range offer a perfect make&finish, is based on a solid engineering and made in a truly hi-tech production process. Equally important, however, is that they communicate with us “above” the technological level, beautifully conveying emotions stored in the recordings.
http://highfidelity.pl/@main-688&lang=en
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Aavik U-300 review @ TAS
Unread post #7 by Audiohub Mod Team » Fri Sep 23, 2016 1:00 am
To answer my own question, I believe the U-300 offers enormous value, even at $30,000. When considering the combined cost of separates that are truly competitive with the Aavik, the U-300 is a relative bargain in today’s high-end scene. To my way of thinking, the U-300 is a game-changer in the high-end industry. It is now possible to think about state-of-the-art performance for all necessary electronics in a single, very stylish box. The U-300 welcomes with open arms almost any speakers, not just monitors or high-sensitivity models. I hope some of you take or make the opportunity to audition the U-300. I think you’ll be impressed.
http://www.theabsolutesound.com/article ... amplifier/
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Thorens @ APHRODITE'S Vision
Unread post #8 by Audiohub Mod Team » Mon Sep 26, 2016 6:03 pm
Η αντιπροσωπεία της θρυλικής Thorens τώρα στην Aphrodite's Vision!
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Tara Labs @ APHRODITE'S Vision
Unread post #9 by Audiohub Mod Team » Wed Sep 28, 2016 6:12 pm
tara labs air forte.jpg (120.17 KiB) Viewed 8017 times
H κορυφαία εταιρεία high end καλωδίων Tara Labs θα διαθέτει τα προϊόντα στην Ελλάδα της μέσω της Aphrodite's Vision!
Πλήρης γκάμα καλωδίων χαλκού με 99.9999999% καθαρότητα και χαρακτηριστικό παραλληλεπίπεδο προφίλ διατομής, μονωμένα με teflon, κατασκευασμένα στο χέρι στο Ορεγκον (USA).
Για περισσότερες πληροφορίες
http://www.aphroditesvision.com/el/
http://www.taralabs.com/
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Sugden Audio @ APHRODITE'S Vision
Unread post #10 by Audiohub Mod Team » Thu Oct 13, 2016 11:13 pm
Sugden 1976.jpg (55.09 KiB) Viewed 8000 times
H Aphrodite's Vision ειναι στην ευχάριστη θέση να ανακοίνωσει την αντιπροσώπευση των εξαιρετικών Αγγλικών ενισχυτών της Sugden. Ο James Sugden ειχε σχεδιάσει τον πρώτο εμπορικό ενισχυτή με τρανζίστορ σε καθαρή ταξη Α πριν απο 4 δεκαετιες και σήμερα η εταιρία συνεχίζει να παράγει κορυφαία ηχητικά μηχανήματα βασιζόμενη στις ιδιες αρχές (less is more σχεδιασμός, ταξη Α).
Sugden history.jpg (59.28 KiB) Viewed 8000 times
Sugden masterclass.jpg (79.89 KiB) Viewed 8000 times
Διαχειριστική ομάδα
Return to “Αντιπρόσωποι & Κατασκευαστές”
