Χωρητικότητα καλωδίων
Unread post #1 by Dr Pan K » Sat May 31, 2025 3:13 pm
Η χωρητικότητα (capacitance) ενός καλωδιου επηρεάζει την ηχητική του υπογραφή και συνήθως οι κατασκευαστές προσπαθούν να την διατηρήσουν χαμηλή. Οι περισσότεροι επιμένουν ότι όσο πιο χαμηλή τόσο πιο καλά. Σε κάποιες εφαρμογές όπως τα καλώδια βραχίονα για κεφαλές Moving Magnet έχει τόσο σημασία ώστε να υπολογίζεται για το ματσαρισμα με το phono stage.
Re: Χωρητικότητα καλωδίων
Unread post #2 by Dr Pan K » Sat May 31, 2025 3:15 pm
To **diminish the capacitance of a cable**, you can take several approaches based on the factors that determine capacitance. The capacitance of a cable (especially a coaxial cable or twisted pair) is generally determined by the formula:
C = \frac{2\pi \varepsilon}{\ln(D/d)}
Where:
* $\varepsilon$ is the permittivity of the dielectric material between the conductors.
* $D$ is the distance between the centers of the conductors or the inner diameter of the outer conductor.
* $d$ is the diameter of the inner conductor.
### Ways to Diminish Capacitance:
1. **Use a Dielectric with Lower Permittivity ($\varepsilon$)**:
* Choose insulating materials with a lower dielectric constant (e.g., air, Teflon, or polyethylene instead of PVC or rubber).
* Lower permittivity reduces the cable’s ability to store electrical energy, thus reducing capacitance.
2. **Increase the Spacing Between Conductors (Increase $D$)**:
* In coaxial or shielded cables, increasing the diameter of the shield (outer conductor) relative to the inner conductor reduces capacitance.
* For twisted pair cables, increasing the twist pitch or separating the wires more increases distance, lowering capacitance.
3. **Use Smaller Diameter Conductors (Decrease $d$)**:
* Thinner conductors can reduce the capacitance by increasing the ratio $D/d$ (though this may increase resistance, so it’s a tradeoff).
4. **Reduce Cable Length**:
* Capacitance is directly proportional to cable length. Use the shortest possible cable for your application.
5. **Use Shielding Wisely**:
* Shields close to the conductor increase capacitance. If shielding is necessary, use materials and geometries that maximize distance from the core conductor or use differential signaling to reduce sensitivity to capacitance.
6. **Change the Cable Type**:
* Use cables specifically designed for low capacitance, such as **low-capacitance coaxial cables** or **twisted pair cables with foamed insulation**.
### Summary of Practical Changes:
| Method | Effectiveness | Practicality |
| Lower-ε insulation | High | High (select appropriate cable) |
| Increase conductor spacing | High | Medium (custom cables) |
| Thinner conductors | Moderate | Medium (watch for resistance) |
| Shorter cable length | High | High |
| Change cable type | High | High (use specialized cables) |
Οπότε ο ChatGPT μας λέει πως για να πέσει η χωρητικότητα υπάρχουν κάποια βασικά βήματα.
Να μειωθεί το μήκος του καλωδίου, να μειωθεί η διάμετρος των αγωγών (αλλά Sommovigo), να απομακρυνθουν οι αγωγοί μεταξύ τους και μεταξύ του μπλενταζ (Signal Projects και Skogrand πχ), να μπει κατάλληλο διηλεκτρικο (Teflon με ή χωρίς κενό αέρα όπως στα Nordost).
Unread post #3 by Dr Pan K » Sat May 31, 2025 3:22 pm
for **audio applications**, especially analog signals (like from microphones, instruments, or line-level sources), cable capacitance can significantly affect **tone and signal clarity**, particularly over long distances or with high-impedance sources.
Here’s how to **minimize capacitance in audio cables**:
### ✅ 1. **Use Low-Capacitance Audio Cables**
* **Look for cables** that specify low capacitance, typically:
* **< 30 pF/ft (100 pF/m)** is good.
* **< 20 pF/ft (65 pF/m)** is excellent.
* Brands like **Mogami, Canare, Belden**, and others offer low-capacitance models.
### ✅ 2. **Shorten Cable Runs**
* Use the **shortest cable length possible**.
* Capacitance adds linearly with length:
E.g., 20 pF/ft × 20 ft = **400 pF**.
### ✅ 3. **Choose the Right Cable Type**
* For **guitar/instrument cables** (high-impedance):
* Capacitance affects **treble roll-off** most.
* Use **low-capacitance coaxial cables** made for guitars.
* For **balanced audio (XLR or TRS)**:
* It’s less sensitive, but low capacitance still helps maintain clarity over long runs.
### ✅ 4. **Match Impedance Where Possible**
* While typical analog audio is not impedance-matched like RF, avoid **very high source impedances**, which make capacitance effects worse.
### ✅ 5. **Use Good Shielding (But Not Too Close)**
* Shielding is essential to block EMI, especially for long runs.
* However, **tight shielding** (foil or braided) close to the conductor increases capacitance.
* Prefer **spiral shielding** or **conductive plastic** layers if ultra-low capacitance is needed and shielding isn’t critical.
Unread post #4 by kostas6a3 » Sun Jun 01, 2025 9:33 am
Unread post #5 by Dr Pan K » Sun Jun 01, 2025 10:18 am
Δεν μου ανοίγει κάτι Κωστα
Unread post #6 by kostas6a3 » Sun Jun 01, 2025 11:35 am
Είναι ένα βίντεο στο FB από τη σελίδα του hxosplus.gr με το Μάμαλο.
Αν δεν ανοίγει διέγραψε το. Δεν ξέρω πως αποθηκεύεις βίντεο από το FB.
Unread post #7 by kostas6a3 » Sun Jun 01, 2025 12:18 pm
Αυτό :lol: :lol: :lol:
Παραιτούμαι (σβήστα όλα Παναγιώτη).
Ποτης
Unread post #8 by Ποτης » Sun Jun 01, 2025 12:36 pm
Είδα το βιντεο.Ο κατασκευαστής παρουσιάζει την τεχνολογία του και δικαιώνεται βάσει των μετρήσεων.
Unread post #9 by Dr Pan K » Sun Jun 01, 2025 2:16 pm
Το μισοειδα (από την ψαροταβέρνα.. ) και πρέπει να ομολογήσω πως έχει ενδιαφέρον. Βέβαια θα προτιμούσα να μου εξηγήσει κάποιος σε ποια αρχή πατάει το σχέδιο. Φαντάζομαι κάποιο drain από το μπλενταζ αλλά μπορεί να κάνω και λάθος
Unread post #10 by angpsi » Mon Jun 02, 2025 12:06 am
Με μπερδεύει τελείως στο σχόλιο για το κουτί: "είναι παθητικό κύκλωμα αλλά μπαίνει στην πρίζα για να φαίνεται ότι είναι σε λειτουργία".
Η πρώτη μου αντίδραση είναι ότι μου θυμίζει το σύστημα γείωσης GRUN της ATLAS Cables, για το οποίο ο Marc Phillips στο PTA λέει τα καλύτερα.
https://www.atlascables.com/atlas-techn ... round.html
https://pt.audio/2021/06/27/atlas-cable ... em-review/
