the Active Side of the Moon!
Re: the Active Side of the Moon!
Unread post #11 by Gojakla » Tue Mar 14, 2017 3:44 pm
Audioengine A5+
Audioengine A5+.jpg (523.43 KiB) Viewed 4961 times
Overview:
With custom Kevlar woofers, silk dome tweeters, and hand-built cabinets, the Audioengine 5+ includes a remote control, dual audio inputs and enhanced thermal management. You can charge your iDevice via the USB power port and also add a subwoofer to the variable output. Connect Audioengine 5+ to your computer's headphone jack or pair with a USB DAC to achieve an even higher level of sound quality. The Audioengine 5+ works with any computer and there's no software to install or settings to change.
Built-in power amplifiers save space and eliminate the need to connect Audioengine 5+ to a stereo receiver or external power amp. Simply plug the left speaker into an AC outlet and connect the included speaker wire from the left to right speaker. All internal components of the A5+ are tuned together, providing a more efficient system requiring less power than passive speakers and amplifiers. With superior stereo separation and incredible imaging, A5+ has a clear sonic advantage over boomboxes or all-in-one systems.
Specs:
Type
2.0 powered (active) bookshelf-style speaker system
Power Output
150W peak power total (50W RMS / 75W peak per channel), AES
Inputs
3.5mm stereo mini-jack, RCA L/R
Outputs
RCA variable line-out, USB (power/charge)
Input Voltages
115/240V, 50/60Hz manually switchable
Amplifier Type
Dual Class AB monolithic
Drivers
5" Kevlar woofers, 3/4" silk dome tweeters
SNR
>95dB (typical A-weighted)
THD+N
<0.05% at all power settings
Crosstalk
-50dB
Frequency response
50Hz-22kHz ±1.5dB
Input impedance
10K ohms unbalanced
Dimensions (HxWxD)
Left Speaker: 27cm x 18cm x 23cm
Right Speaker: 27cm x 18cm x 20cm
Weight
Left Speaker: 7 kg
Right Speaker: 4.4 kg
Finish options
Satin Black
Hi-Gloss White
Solid Carbonized Bamboo
Power Consumption
Idle: 10W
Mute: 6W
Sleep: 4W
Materials & Construction
13mm thick MDF cabinets
130mm Kevlar woofers with advanced voice coils
20mm silk dome tweeters with neodymium magnets
Torroidal power transformer
Τα απανταχού reviews είναι σχεδόν διθυραμβικά τόσο για το ζεύγος Α5+ όσο και για το μικρότερο αδερφάκι τους, το Α2+. Δεν κρύβω πώς αν αναζητούσα desktop ηχεία για τον υπολογιστή μου θα ήμουν μεταξύ των Α2+ και των Fostex PM0.4d.
Unread post #12 by Gojakla » Tue Mar 14, 2017 4:00 pm
Συνέχεια στα ενεργά desktop ηχεία με τα
JBL LSR305
JBL LSR305.jpg (379.37 KiB) Viewed 4958 times
Overview:
5" Two-Way Powered Studio Monitor
Bi-amplified
Magnetically-Shielded 5” Low Frequency Transducer & 1” Soft-Dome High Frequency Transducer
Image Control Wave Guide
Class-D 41 Watt RMS Amplifier for LF, and 41 Watt RMS Amplifier for HF
Balanced XLR and TRS Inputs with Detented Level Control
JBL’s Patented Slip Stream™ low frequency port design
Selectable Input Sensitivity
LF Trim and HF Trim for both the Low and High Frequencies
Specs:
Frequency Range
43Hz - 24kHz
Max Peak SPL
108dB SPL C-Weighted
Max Peak Input
+23 dBu
Driver Dimensions
LF Driver Size: 127mm
HF Driver Size: 25mm
Amplifier
LF Driver Power Amp: 41W Class D
HF Driver Power Amp: 41W Class D
Trim Control
LF Trim Control : +2 dB, 0, -2 dB
HF Trim Control : +2 dB, 0, -2 dB
Input Types
1 x XLR
1 x TRS Balanced
AC Input Voltage
100-240 VAC +/- 10% 50/60Hz
Dimensions (H x W x D)
298mm x 185mm x 251mm
Weight
4.6kg
Unread post #13 by Dr Pan K » Wed Mar 15, 2017 8:51 pm
Και κατι που θα κανει πάταγο (εξω) και ισως να το δούμε και Ελλάδα. Μετα το πικάπ Runwell (που σκίζει) η Shinola λανσαρε και ενεργά ηχεία, τιμή στα 1500$ και φινίρισμα σε Oak και Black Ash (60W RMS class D amp, soft dome tweeter και 5.25" woofer)
shinola speakers.jpg (417.72 KiB) Viewed 4943 times
black ash.jpg (155.36 KiB) Viewed 4943 times
https://www.shinola.com/audio/speakers/ ... black.html
Unread post #14 by Dr Pan K » Mon May 01, 2017 11:26 am
Ενδιαφέρονάρθρο του Doug Schneider για τα ενεργά ηχεια που σιγα σιγα αρχίζουν να κερδίζουν περισσότερους φιλους και οι εταιρίες τα προωθούν πια και σε show. H αλήθεια ειναι οτι στις εκθεσεις βλεπουμε σχετικα λιγα καθως βγάζουν εκτος παιχνιδιου ενισχυτές και καλώδια, καποια ακομα και πηγές.
Στο αρθρο δινετε έμφαση στα νεα ενεργα της Bryston, λογικο βημα καθώς η Καναδικη εταιρια ειχε τους ενισχυτες ετοιμους και εδω και λιγα χρονια λανσαρε και ηχεια. Το μεγαλο ενεργο Τ active μαζι με εξωτερικό ψηφιακό crossover BAX-1 και τρικαναλο εξειδικευμένο ενισχυτή θα ξεπερνά τα $15.000 και οπως ειναι προφανες δεν θα ειναι καν all in one box. Θυμιζει καπως τις μεγαλες λυσεις της ATC και σύμφωνα με τα πρωτα Feedback απο την εκθεση της Axpona το ενεργο Bryston επαιζε καλύτερα απο το ομοσταυλο παθητικό. Δυστυχώς η Bryston επέλεξε ψηφιακο DSP crossover ενω προσωπικά θα προτιμούσα ενα αναλογικό.
Unread post #15 by Dr Pan K » Sat May 13, 2017 10:35 pm
Ποιος ειπε οτι τα ενεργά ηχεία πρεπει να ειναι άσχημα? Arteluthe ! (μόνο που δεν ξέρω αν κυκλοφορούν ακομα, δεν μπορώ να βρω πρόσφατα στοιχεία για την Καναδική εταιρία Gaboury Laboratoires)
arteluthe close.jpg (50.31 KiB) Viewed 4901 times
Unread post #16 by Dr Pan K » Mon Jul 24, 2017 4:18 pm
Πολύ σοβαρή νέα πρόταση από την Backes & Mueller, Prime 12 δλδ τριδρομα ενεργά με DSP και πενταενισχυση. Και όμορφα..
Assembly: 3 x DMC2.0(TM)-regulated 7" bass chassis
mid-tone calotte chassis
1"-Ring radiator HT with solid aluminium waveguide
DSP: FIRTEC(TM) equalisation with time-aligned radiation, FPGA-DSP
Room Adaptation: 6 x User filters via PPG hardware (level programming device)
delay, panorama
Performance: Bass 3 x 150 W + mid-range 1 x 150W + high frequency 100 W
Frequency Range: < 30 - 24000 Hz (+/- 3 dB)
Analogue-In:
Input Sensitivity XLR-symmetric,
up to 10 dBu
Digital-In XLR-AES3-input: 192KHz-24Bit for direct connection to the digital source
Measurements: W × H × D 0,28x1,30x0,40m
http://www.backesmueller.de/en/products ... me-12.html
Unread post #17 by Gojakla » Thu Aug 10, 2017 1:28 pm
Bang & Olufsen Beolab 50
Official Site
BeoLab 50.jpg (241.45 KiB) Viewed 4810 times
Specs
EFFECTIVE FREQUENCY RANGE
15 - 43,000 Hz
WIRELESS INPUT (MASTER AND SLAVE SPEAKER)
Wireless Power Link (24 bit / 48 kHz)
WiSA (24 bit / 96 kHz)
DIGITAL INPUT (MASTER AND SLAVE SPEAKER)
Digital Power Link (24 bit / 192 kHz)
ANALOGUE INPUT (MASTER SPEAKER)
Power Link RCA
DIGITAL INPUT (MASTER SPEAKER)
USB Audio (24 bit / 192 kHz)
S/P-DIF (24 bit / 192 kHz)
Optical (24 bit / 96 kHz)
SPEAKER DRIVERS
Tweeter
1 x 3/4-inch - double motion Acoustic Lens Technology
Midrange
3 x 4-inch
Woofer
3 x 10-inch
AMPLIFIERS
For tweeter
1 x Bang & Olufsen ICEpower 300 watts
For midranges
3 x Bang & Olufsen ICEpower 300 watts
For woofers
DIGITAL SIGNAL PROCESSOR
DSP type
1 x Analog Devices ADSP-21489 - 400 MHz
Sampling rate
192 kHz fixed
WEIGHT
61 kg
Unread post #18 by BityaBit » Thu Aug 10, 2017 1:35 pm
Πώπωωω λιγώθηκα.. ποια να είναι η τιμή του άραγε..
Unread post #19 by Gojakla » Thu Aug 10, 2017 1:44 pm
Αν δεν κάνω λάθος, ένα 40ρι.
Unread post #20 by BityaBit » Thu Aug 10, 2017 2:06 pm
Ωραία ότι πρέπει για το Dolby Atmos που θελω να φτιάξω για το Home Cinema.. :roll:
