Network Players/Streamers
Clones Audio the Host
Unread post #11 by Dr Pan K » Mon Jul 18, 2016 12:38 pm
Νεος streamer απο την Clones Audio:
THE HOST
The HOST is the first digital music server of CLONES audio. Equipped with a high performance USB digital audio output, Ethernet port, solid-state drive for music storage, full linear power supply with the super low noise regulator modules. Providing the solid foundation to the high performance playback. The great solution for playing and storing high resolution digital music collections.
Custom Linux OS with the ROON Server for the best performance. Also providing the DAPHILE as the difference choice for the user.
The HOST also is the platform for audiophiles to make his own PC based Computer Audio System.
• SHAAR USB gateway for the clean and high performance USB audio class 3.0 output.
• Full linear power supply.
• Double POWER STATION regulator supply the SSD/SHAAR and the Main processor board separately
• 256GB/ 500GB/ 1TB/ 2TB internal storage option
• Machined aluminum case, same structure as the ASHER DAC
• Gigabit Ethernet LAN Port for network connectivity
Specification
• 322mm(W) X 260mm(D) X 90mm(H)
• Weight: 7kg
• Mucic Storage: 256GB/ 500GB/ 1TB/ 2TB
• Digital Output: 2 - USB
• Other I/O: Gigabit Ethernet, USB Port X 4
• 2 YEARS WARRANTY
Price: Starting from HKD11,799*
*Solid-state hard drive and ROON licence are excluded
clones front.png (519.35 KiB) Viewed 6211 times
clones back.png (422.71 KiB) Viewed 6211 times
clones int.png (668.46 KiB) Viewed 6211 times
Στην ουσία δινει δυνατότητα επιλογής για Roon ή για Linux Daphile αλλα με ενα lifetime Roon και 2Τ SSD η τιμη ανεβαινει στα 2400 ευρώ. Το Daphile δεν το πολυεμπιστευομαι γιατι στο παρελθόν κατα τις δόκιμες που ειχαν γίνει παρουσίαζε μεγαλη αστάθεια απο εκδοση σε έκδοση. Φαινετε να εχει ομως πολυ καλη τροφοδοσία και προσεγμένη εξοδο USB ειδικα μελετημενη για ηχο.
Στέλιος Π.
Re: Network Players/Streamers
Unread post #12 by Στέλιος Π. » Mon Jul 18, 2016 1:49 pm
Ενα ASRock J3710-itx
http://www.skroutz.gr/s/8972278/Asrock-J3710-ITX.html
Με εναν ssd Samsung EVO 2Tb
http://www.skroutz.gr/s/7197498/Samsung ... o-2TB.html
Ξεχωριστο USB for audio interface που το παιρνει προφανως απο τους headers του mobo
και "κυριλε" τροφοδοτικο... σε συμπαθητικο περιτυλιγμα...
[shrug]
Unread post #13 by Dr Pan K » Mon Jul 18, 2016 1:59 pm
Καμια αντιρρηση αλλα δεν ζηταει πολλα. Εξηγω, motherboard 120e, SSD 650e, τροφοδοσια + μετασχηματιστής να μην ειναι αλλα 150? Κουτι και USB interface αλλα 200 (ομορφο κουτάκι κοστιζει), συνολο >1100 σε υλικα. Το πουλάει 2400 ετοιμο, Plug n play, το βρισκω πολυ λογικό.
Αλλο να μου πεις, οτι περαν του SSD σκληρου που ειναι ακριβος, μπορεις να εχεις το ιδιο αποτέλεσμα και με <200 ευρω με Raspberry Pi2/3.. Αλλα πρεπει να ασχοληθεις, να διαβάσεις λιγο και φυσικα δεν εχεις κανενα support ή ονομα.
Θα δουμε και αλλα να βγαίνουν γιατι σε λιγα χρόνια θα ειναι η μόνη πηγη μας (και μεχρι να παμε τα παντα στο cloud), προς το παρόν βέβαια το Auralic Aries και το Aurender παραμένουν αχτύπητα.
Baetis Reference 2 Music Server
Unread post #14 by Dr Pan K » Wed Aug 10, 2016 2:17 pm
betis R.png (163.05 KiB) Viewed 6161 times
Baetis® Audio is pleased to announce the new Reference 2 music server. We just raised the bar, again. We left the Baetis proprietary daughter-board unchanged, as well as the critical HD audio codec on the motherboard. But the rest of the Baetis Reference components were improved:
The Reference 2 utilizes the latest 6th generation of Core i7 Intel CPU and its associated chipset (“Skylake”) and motherboard (“MB”). CPU speed is increased slightly, but RAM speed is increased by 35%. Since all audio formats (and video for those who use it) are played through RAM on a Baetis, this RAM speed boost is quite significant in improving audio.
The internal wiring (sending the SPDIF signal through our proprietary daughter-board, then the resulting AES and SPDIF signals to the connectors on the rear panel) have been upgraded using cryo-treated pure silver digital cable, fully shielded, made for us by Revelation™ Audio Labs. This is a world’s first inside any music server or any computer, so far as we know, and the impact is obvious.
The external PSU (ac/dc converter) has been upgraded to the new HD-Plex™ linear PSU putting out 300 watts. This immediately increases presence without waiting for burn-in, along with greater detail. This is the first linear PSU we have found that a) has sufficient wattage to power everything that a Baetis can do, and b) doesn’t get too hot to the touch when doing certain things (such as playing hours of DSD transcoded to PCM for a world-class DAC, or several Blu-ray concerts in a row).
The DC cable connecting the PSU to the Baetis computer is now made especially for us by Revelation™ Audio – a cable made of cryo-treated pure silver that imparts as much audio improvement as the new PSU itself! [You can buy the new PSU with its new cryo-silver DC cable for ANY previous Baetis with a Neutrik® Powercon™ DC connector on the server’s chassis.]
Even the ATX DC distributor inside the Baetis has been upgraded to an HD-Plex model that is fed 19v of DC power from the PSU instead of 12v. Another “detail” that our competitors do not worry about.
Baetis Reference 2 ($17,200)
To εντυπωσιακό (για streamer) εξωτερικό τροφοδοτικό... Και ιεροσυλία, εχουν high end καλωδιώσεις σε streamer..
baetis ref 2 ps.png (349.11 KiB) Viewed 6161 times
Sonore microRendu
Unread post #15 by Dr Pan K » Sun Aug 28, 2016 9:00 pm
To Sonore microRendu ειναι ενα σχετικά απλο στην σύλληψη αλλα πολυ βολικό Ethernet to USB streamer. The microRendu utilizes a proprietary printed circuit board with only the essential components.
Προσφέρει μεγαλη γκαμα τρόπων χρήσης, μοναδική ισως σε ευρος επιλογών.
Mode #1 - SqueezeLite Output - This output works with any Logitech Media Server and compatible controllers. This output supports true gapless playback of PCM and DSD/DoP.
Mode #2 - ShairPort Output - This is an AirPlay emulator that utilizes streams sent to it from a compatible source. This output supports true gapless playback of PCM.
Mode #3 - MPD/DLNA Output:
Mode #3a - DLNA Output - This output utilizes streams from UPNP/DLNA servers and controllers. This output can be configured as an OpenHome renderer. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #3b - MPD Output - This output is intended to work with a SMB mount. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #4 - HQ Player NAA Output - This output utilizes streams from Signalyst's HQ Player running on your computer. Digital signal processing is performed by HQ Player and then asynchronously streamed to the Network Audio Adapter (NAA) output. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
Mode #5 - RoonReady Output - This output utilizes streams from Roon. This output supports true gapless playback of PCM, DSD/DoP, and native DSD.
http://www.microrendu.sonore.us/
Και ενα review απο τοAV Rev
Τιμή στα $640 χωρις τροφοδοτικό ενω με το πολύ καλό iFi iPower στα $690
Unread post #16 by DomieMic65 » Mon Aug 29, 2016 10:08 am
έχει γίνει πολύ ντόρος για αυτό σε πολλά φόρουμ....
Unread post #17 by Dr Pan K » Mon Aug 29, 2016 1:05 pm
To MicroRendu ειναι μια λυση με πολλες δυνατότητες οποτε δεν μου κανει εντύπωση Μιχαλη. Υπάρχουν αρκετοί που επιμένουν στο Squeezelite (βολικό) και τους δινει έτοιμη λύση ενω για τους πιουριστες υπάρχει και MPD.
Unread post #18 by DomieMic65 » Mon Aug 29, 2016 2:07 pm
Dr Pan K wrote:To MicroRendu ειναι μια λυση με πολλες δυνατότητες οποτε δεν μου κανει εντύπωση Μιχαλη. Υπάρχουν αρκετοί που επιμένουν στο Squeezelite (βολικό) και τους δινει έτοιμη λύση ενω για τους πιουριστες υπάρχει και MPD.
Ναι σίγουρα δεν κάνει εντύπωση!
Είναι μάλλον αυτό που λείπει από ένα computer based σύστημα για να κάνει την πηγή high end
Πόσο μάλλον με ένα καλό τροφοδοτικό...
Φτηνό δεν το λες! (για high-end δεδομένα ούτε ακριβό βέβαια)
Unread post #19 by Dr Pan K » Mon Aug 29, 2016 2:22 pm
Στο "φτηνο" θα ήθελα να σταθώ, κατ εμε ειναι ακριβό. Στα $640 χωρίς τροφοδοσία (+50 για το iFIi) το βρίσκω απαράδεκτα τσιμπημένο Μιχάλη. Ενα Raspberry 2-3 με γραμμικό και κουτάκι παει κάτω απο 200 ενω με το iFi iPower που βγαίνει και για Raspberry (δική μου πρόταση στην iFi..) το κοστς ειναι κατω απο 100 ευρω. Το τελευταίο Volumio κανει παπάδες και το στήσιμο δεν ειναι και τοσο σύνθετο (το ιδιο με το MicroRendu).
Για να μην αναφερθώ στο πολυ καλο Auralic Aries mini που κοστίζει τα ιδια (ισως και λίγο λιγότερο) και αποτελεί την καλύτερη λύση για affordable streamer (και με Sabre DAC ενσωματωμένο).
Unread post #20 by DomieMic65 » Wed Aug 31, 2016 10:47 am
Για εμένα είναι ΠΑΝάκριβο απλά μίλησα με το πως έχουμε συνηθίσει να λέμε φτηνά ή ακριβά τα προϊόντα του High-End!!!
