Straight Outta Factory!
Sakura Systems 47 Labs Amplifiers
Unread post #101 by Dr Pan K » Sun Jan 29, 2017 2:48 pm
47 Lab
Kaname/Fudou Amplifier system
Kaname pre amp
Resistor relay attenuator
4 power supplies
complete dual mono layout
MSRP $12.000
Fudou power amp
2x45W/8Ohm, 2x70/4Ohm
2 power supplies
MSRP $10.000
47 labs.jpg (15.22 KiB) Viewed 8444 times
After 20 years since shocking the audio world with "Gaincard", Junji Kimura delivers the new 47 Laboratory reference amplifier.
With improved ergonomics and speaker drivability, while maintaining the well-known lively sound with natural details of 47 Lab amplifiers, "Kaname/Fudou" combination opens a new page of 47 Lab history
http://www.sakurasystems.com/reference/ ... fudou.html
Mr Speakers Aeon
Unread post #102 by Dr Pan K » Mon Jan 30, 2017 4:49 pm
Mr Speakers
Aeon Planar Magnetic headphones
All new planar magenetic driver with V-Planar and Trueflow technologies
NiTinol "memory metal" headband with hing-free design
Dyed-through leather headband
New DUMMER 1/4" and 3.5mm dual-tip fabric covered headphone cable
MSRP $799
aeon side.jpg (1012.67 KiB) Viewed 8427 times
https://mrspeakers.com/aeon/
Denon AH-D7200
Unread post #103 by Dr Pan K » Mon Jan 30, 2017 10:14 pm
Denon AH-D7200
Closed back, over ear dynamic headphones
50mm Nano- Fibre Free Edge drivers
7N copper cables
American walnut cups
MSRP $999
DENON-AH-D7200_exploded_ view.png (669.46 KiB) Viewed 8419 times
https://usa.denon.com/us/product/portab ... ar/ahd7200
Ballfinger PS 2
Unread post #104 by Dr Pan K » Thu Feb 02, 2017 12:01 am
Ballfinger
PS 2 Direct drive turntable
Microprocessor controlled unique radial/tangential tonearm
+/-0.03 Wow
-85dB A weighted rumble
14.5Kgr
http://www.ballfinger.de/turntable-ps-2
Amphion Argon 7LS
Unread post #105 by Dr Pan K » Thu Feb 02, 2017 7:30 pm
Amphion Argon 7LS
MTM design with passive radiators
Crossover @1600Hz
Fine tuned for home use
MSRP 2250 euro
http://us6.campaign-archive1.com/?u=316 ... 4eb79c207c
Sonus Faber Homage Tradition speakers
Unread post #106 by Dr Pan K » Thu Feb 02, 2017 10:38 pm
Sonus Faber
Restyled Homage Tradition line of speakers
Amati, Guarneri, Vox, Serafino
Available in Red and Wenge finish
amati tradition.jpg (583.73 KiB) Viewed 8385 times
amati posts.jpg (419.12 KiB) Viewed 8385 times
Phasemation PP 500
Unread post #107 by Dr Pan K » Mon Feb 06, 2017 9:54 pm
Phasemation PP-500
MC phono cartridge
4 Ohm impedance
Compliance: 8.0 µm/mN
Frequency Range: 10Hz to 30kHz
Separation: 30dB or more (1kHz)
Channel Balance Within: 1dB (1kHz)
Stylus Chip Diamond: (line contact / curvature 0.03×0.003mm)
Cantilever: Pure Boron φ0.26
Magnet: Samarium Cobalt Magnet
Magnetic Circuit Composition Material: Permendur
Base Machined duralumin: (Diamond Like Carbon processing)
Phasemation PP 500.jpg (33.18 KiB) Viewed 8371 times
http://www.phasemation.com/product/pp-500.html
BMC M3 Mono and CS3 integrated amplifiers
Unread post #108 by Dr Pan K » Wed Feb 08, 2017 8:17 pm
BMC M3
Mono power amplifier
Load-Effect Free (LEF) Amplifier
No overall negative feedback loop
2x200/8 Ohm, 2x380/4
2KW toroidal transformer
BMC M3 inside.jpg (863.21 KiB) Viewed 8350 times
BMC CS3
2x200/8 Ohm, 2x350/4
http://bmc-audio.com/
Etsuro Urushi Cobalt Blue MC cartridge
Unread post #109 by Dr Pan K » Thu Feb 09, 2017 8:05 pm
Etsuro
Urushi Cobalt Blue
Moving Coil cartridge
Frequency response: 15-50,000Hz
Output voltage: 0.25mV/1kHz
Output balance: <0 .5db
Channel separation: 33dB/1kHz
Tracking weight: 2gr
Impedance: 3Ω/1kHz
Trackability: >70μm/2gr
Stylus shape: 80μm microline diamond
Cantilever: 0.4φsapphire pipe
Cartridge base: Extra super duralumin(A7075)
Cartridge housing: Extra super duralumin(A7075)
Housing processing: Urushi handmade
Cartridge weight: 8.1gr
Etsuro_Urushi_Cobalt_Blue MC.jpg (55.22 KiB) Viewed 8336 times
TotalDAC d150 speakers
Unread post #110 by Dr Pan K » Fri Feb 10, 2017 12:07 am
TotalDAC
d150 Horn speakers
98dB/1W/1m sensitivity.
40Hz-20KHz frequency bandwidth (25Hz-20KHz with the subwoofer option).
150Hz crossover frequency
860mm diameter wooden horn made of 100m thick wood.
5inch bass driver, paper cones
8ohm impedance, 7ohm minimum impedance
1.45m heigh, 0.86m diameter round horn, 0.72m max depth
each part is less than 60kg for an easy handling
MSRP 38.000 euro
d150 subwoofer
18 inch paper cone driver from AESPEAKER -25Hz-50Hz pre-set filter embedded in the d150 speaker.
8ohm impedance.
recommended amplifier: >200W
0.48m wide , 0.29m deep, 1.9m heigh.
weight: 65kg
MSRP 6000 euro
