Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #151 by Dr Pan K » Thu Jul 06, 2017 6:17 pm
McIntosh
MA 9000 stereo integrated amplifier
2x300 Watt
2 balanced, 6 unbalanced inputs plus 1 Moving Coil & 1 Moving Magnet phono inputs
2 coax, 2 optical, 1 USB and 1 MCT input for the DA1 Digital Audio Module
32bit/384KHz, DSD256 capable
Home Theater passthrough
MSRP $10,500 USD VAT excluded
MA9000 Angle Right background.jpg (460.41 KiB) Viewed 7418 times
MA9000 Back Angle background.jpg (580.98 KiB) Viewed 7418 times
Unread post #152 by Dr Pan K » Fri Jul 07, 2017 11:12 am
Goebel
Divin loudspeakers
MSRP 300.000 euro
Unread post #153 by Dr Pan K » Sun Jul 09, 2017 3:39 pm
Meridian
857 Reference power amplifier
Low negative feedback design
250W/ 8Ohm, 500/ 4Ohm both channel driven
Bridged 1500W/ 4Ohm
1-100kHz frequency response -/+ 2dB
Fan assisted operation
WBT terminals
32Kgr
https://www.meridian-audio.com/en/produ ... rence-857/
Unread post #154 by Dr Pan K » Tue Jul 11, 2017 6:54 pm
Goldring
E series MM cartridges
V Magnet design
Model Variations
Model name: E1 E2 E3
Product code: GL0054 GL0056 GL0058
Colour:
 Red Green Violet
Cantilever:
 Carbon A Aluminium Aluminium
Stylus profile: Spherical Spherical Elliptical
Stylus radius: 0.6 mil 0.6 mil 0.3 x 0.7mil
Replacement stylus: GL0055 GL057 GL059
Load resistance: 47 kΩ
Load capacitance: 100 – 200 pF
Internal inductance: 400 mH
Internal resistance: 410 Ω
Frequency range: 20 Hz – 20 kHz
Channel balance: 1.5 dB at 1 kHz
Channel separation: >20 dB at 1 kHz
Sensitivity: 3.5 mV (1 kHz @ 5 cm/sec
Static compliance: 20 mm/Nm
Vertical tracking angle: 20°
Cartridge mass: 6.9 g
Fixing centres: 12.7 mm (0.5 in)
Playing weight: 1.5 g – 2.5 g
 (2.0 g recommended)
MSRP approx 70 euro E1, 100 euro E2, 130 euro E3
Unread post #155 by Dr Pan K » Wed Jul 12, 2017 10:41 pm
SimAudio
600i V2 integrated amplifier
2x125/8Ohm, 2x250/4Ohm
Dual mono power supply
Input Impedance 23.7KOhm
Freq Response 10Hz - 100kHz +0/-0.1dB
Crosstalk @ 1kHz -100dB
THD (20Hz - 20kHz @ 1 watt) 0.015%
THD (20Hz - 20kHz @ 125 watts) 0.04%
Intermodulation distortion 0.02%
Shipping weight 48 lbs / 21 Kgs
MSRP $9000
http://www.simaudio.com/en/product/15-i ... ifier.html
Unread post #156 by Dr Pan K » Tue Jul 18, 2017 9:42 pm
Zweimann
USB DSD tube DAC
Dual mono AKM DACs
USB Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96KHz, 176.4KHz, 192KHz, 352.8KHz, 384KHz and DSD 2.8MHz, 5.6MHz, 11.2MHz, 6.144MHz, 12.288 MHz
S/PDIF Sampling Rates: 44.1KHz, 48KHz, 88.2KHz, 96, 176.4KHz, 192KHz, 352.8KHZ, 384KHz
Maximum Sampling Rate: 32-bits
Bit Resolution: 16-24-bits
Power output Headphone: max 140mW x 2 @ 32 ohm
THD+N: 0.005%
SNR = 123dB
Power supply ripple suppressed more than 100dB
Voltage ripple in heating are limited to 700uVpp.
Frequency range in Tubed section is 0.3 Hz to 800 kHz.
Channel separation 1kHz 2.2Vpp (full scale DAC) better that -95dB
Dimensions: 440 mm W, 300 mm D, 90 mm H
Weight: 9 Kg
Unread post #157 by Dr Pan K » Wed Jul 19, 2017 10:36 pm
MUTEC
Empyreal Ref 10
10 MHz reference clock generator
Oven-controlled oscillator (OCXO) made in Germany
individually switchable BNC clock outputs with 50 and 75 Ω impedance for maximum compatibility with clocks and DACs
Low noise power supply
MSRP 3598 euro
mutec ref 10.jpg (32.7 KiB) Viewed 7332 times
https://www.mutec-net.com/product_ref_10.php
Unread post #158 by Dr Pan K » Thu Jul 27, 2017 3:53 pm
Naim
Unity Atom
All in one solution
2x40Watt class AB integrated amp
Burr Brown DAC
5" LCD display with proximity sensor
Aptx HD, streamer, Bluetooth
Android & iOS app
MSRP approx 2000 euro
Για περισσότερες πληροφορίες Orpheus Audio
https://www.naimaudio.com/product/uniti-atom
Unread post #159 by Dr Pan K » Sun Jul 30, 2017 5:58 pm
Jeff Rowland
535 stereo power amplifier
2x250W/8Ohm 2x500/4
1x850W/8Ohm in bridged mono
Class D operation
T6 aluminium chassis
Frequency Response: 5 Hz – 70 kHz, -3 dB
Output Noise: 40 Microvolts A weighted
Input Impedance: 40k ohms
THD + Noise: < 0.05%, 20 Hz -20 kHz
>1000 damping factor @1KHz
Weight 10kgr
MSRP 5900$
image1 copy.JPG (336.61 KiB) Viewed 7308 times
Unread post #160 by Dr Pan K » Fri Aug 04, 2017 4:28 pm
PTP Audio
Blok20 integrated amplifier
2x20W Minimalist Integrated Solid State Amplifier.
Built around the LM1875 amplifier chip.
Minimal parts count (the amplifier circuit is 1 chip and 3 resistors).
Non PCB, point-to-point wired amplifier section
Extremely short signal path.
3x line level input.
50k input impedance.
Ultra fast recovery rectifiers.
Huge 300VA toroidal transformer.
All wiring is high purity silverplated copper with teflon insulation.
4mm Aluminium backpanel with integrated heatsink.
170(H)x175(W)x200(D)mm solid Corian housing to minimise resonances.
A wide range of colours to choose from.
230V and 115V versions available.
8kg.
Price €2250.- (for black or white, other colours available on request)
http://www.ptpaudio.com
