Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #161 by Dr Pan K » Fri Aug 11, 2017 10:49 pm
Thales
Statement tonearm
tangential pivoted tracking properties.
Optimized mechanical energy flow and new materials for more dynamic sound
Armtubes and headshell made of special aluminium alloy with the strength of steel but 10 times higher internal damping
Arm tubes curved for maximum rigidness
Bearing unit comp letely capsuled to increase the mechanical rigidity up to 100x
Elliptic shaping of base parts to increase critical contact surfaces
Diamond coating on bearing and base parts to increase the damping properties
Optimized electrical shielding properties
All arm parts golden(for gold version) or rhodium coated (for silver version)
New bearing technology to ensure low impedance connection points from base to head
New fine adjustment mechanism for more preciseness
Fine adjustment device for VTA with 1/10mm scale
Fine adjustment device for Azimuth with 1/3° scale
Advanced clamping mechanism inside installation ring to allow on fly adjustment
Για περισσότερες πληροφορίες Aphrodite's Vision
Unread post #162 by Dr Pan K » Tue Aug 29, 2017 4:56 pm
Pathos
AmpliD power amplifier
Balanced Class D operation
2x70W/8Ohm, 2x130/4
Frequency response:1 Hz – 100 KHz
THD: < 0,04%
Dumping factor: 50
S/N Ratio: 98dB
Input impedance: 47 KOhm
Analog inputs: 1 stereo balanced XLR, 1 stereo unbalanced RCA line
Weight 5Kg
Made in Italy
amplid back.jpg (879.34 KiB) Viewed 7945 times
Για περισσότερες πληροφορίες Orpheus Audio
Unread post #163 by Dr Pan K » Wed Sep 06, 2017 9:31 pm
B&W
700 S2 speaker series
Aerofoil-Profile bass drivers
Solid Body tweeter
Carbon Dome Tweeter
Continuum Cone, decoupled Midrange
MSRP from approx 1000 to 3600 euros
http://www.bowers-wilkins.com/Speakers/ ... 700-Series
Unread post #164 by BityaBit » Thu Sep 07, 2017 11:31 pm
Φαίνεται νοσταλγήσανε τις εποχές που η σειρά 800 είχε φυσιολογικές τιμές και πουλάγανε τουλάχιστον τα μικρά σαν ζεστά ψωμάκια..
Πάντως δεν μπορώ να μην χαίρομαι για την κίνηση αυτή σαν φανμπόης της εταιρίας ιδίως με τις ιδιαίτερα ανταγωνιστικές τιμές δεδομένης της τεχνολογίας και τεχνογνωσίας που παίρνει κανείς σε αυτήν την νέα σειρα..
Unread post #165 by Dr Pan K » Wed Sep 13, 2017 6:24 pm
McIntosh
MA7200 Integrated Amplifier
2x200Watt/8Ohm
8 analog connections (5 unbalanced, 1 balanced and 1 each of Moving Coil and Moving Magnet)
6 digital (2 each of coaxial and optical plus 1 USB and 1 proprietary MCT for use with our series of SACD/CD Transports)
PCM 32-bit/384kHz and DSD256
MA7200 Angle Left high background.jpg (344.95 KiB) Viewed 7882 times
MA7200 Back Angle background.jpg (524.57 KiB) Viewed 7882 times
Unread post #166 by Dr Pan K » Fri Sep 22, 2017 5:54 pm
Zesto Audio
Allasso step up transformer
4 gain settings of 17dB, 21dB, 23dB and 26dB and the step up ratios of 1:4, 1:6, 1:8 and 1:12
10 load positions for each setting allowing for 40 adjustments in Stereo and 40 in Mono.
The Mono switch is a unique feature which takes one input and sends it to both outputs. Mono cartridge lovers have the added benefit of listening in either the Mono or Stereo.
Unread post #167 by Dr Pan K » Thu Sep 28, 2017 11:38 pm
Parasound
JC 3 JR phono stage
Cartridge options for both MM and MC
Variable MC Loading from 50 Ohms to 550 Ohms
Mono switch
Circuit boards designed by Carl Thompson
Balanced and single-ended outputs
Low-level circuitry housed in isolated sub enclosures
RIAA Accuracy within 0.2dB
Signal-To-Noise Ration up to 94 dB
THD < 0.02%
Selectable Gain of 40dB, 50dB, 60dB unbalanced
Selectable Gain of 46dB, 56dB, 66dB balanced
Torroid Transformer, Vishay-Dale resistors in the audio path,
High-speed, soft-recovery bridge rectifiers
MSRP $1495
Unread post #168 by Dr Pan K » Sat Sep 30, 2017 2:12 pm
KL Audio
KD-ARM-MP12 tangential tonearm
MSRP $8.500
kd-arm mounted.jpg (53.1 KiB) Viewed 7808 times
http://klaudio.com/index.php?route=prod ... ry&path=62
Burson Play : Straight Outta Factory!
Unread post #169 by Dr Pan K » Sun Oct 01, 2017 11:00 pm
Burson
Play headphone amplifier/ DAC
2W per channel into 16ohm
70W power supply
Opamp rolling
ESS9018 DAC chip
Xmos USB receiver
Capable of DSD256, DXD, 32bit / 384khz
PLAY can also be used as a pure Class-A remote controlled preamp
PC Connection Cable Set
5 Year warranty
MSRP starting @ $300 depending on Opamps
Για περισσότερες πληροφορίες South Sounds
Unread post #170 by Dr Pan K » Mon Oct 02, 2017 8:52 pm
Spectral
DMA 500 Refrence Anniversary power amp
high speed RF circuits
@ 8 ohm - 350 Watt RMS
@ 4 ohm - 540 Watt RMS
@ 2 ohnis - 750 Watt RMS
Output Current: 90 Amps Peak
Frequency Response: ± 0.1 dB, DC -150 KHz, ± 1 dB, DC - 1 MHz, ± 3 dB, DC - 1.8MHz
Rise time: Less than 225 nanoseconds
5lew rate: 1200 volts / microsecond
Static distortion: Less than 0.015% DC to 100 KHz, typical: 0.009% @ 350 W RMS / B ohm
Weight: 34 kg
spectral 500.jpg (49.07 KiB) Viewed 7776 times
spectral 500 back.jpg (78.55 KiB) Viewed 7776 times
Mου τρέχουν τα σάλια...
http://www.spectralaudio.com/
