Network Players/Streamers
Re: Network Players/Streamers
Unread post #171 by Chris1967 » Tue May 09, 2023 12:51 pm
Νέος παίκτης στην φτηνή κατηγορία αλλά με εντυπωσιακά χαρακτηριστικά.
Eversolo DMP-A6 Streamer
https://www.eversolo.com/Product/index/ ... 3D%3D.html
eversolo-dmp-a6-streamer-2xes9038q2m-wifi-dlna-airplay-2-roon-bluetooth-50-aptx-hd-32bit-768khz-dsd512-mqa (1).jpg
eversolo-dmp-a6-streamer-2xes9038q2m-wifi-dlna-airplay-2-roon-bluetooth-50-aptx-hd-32bit-768khz-dsd512-mqa (1).jpg (39.7 KiB) Viewed 3064 times
eversolo-dmp-a6-streamer-2xes9038q2m-wifi-dlna-airplay-2-roon-bluetooth-50-aptx-hd-32bit-768khz-dsd512-mqa.jpg
eversolo-dmp-a6-streamer-2xes9038q2m-wifi-dlna-airplay-2-roon-bluetooth-50-aptx-hd-32bit-768khz-dsd512-mqa.jpg (39.01 KiB) Viewed 3064 times
Specs
ModelEVERSOLO DMP-A6
Display6" LCD touchscreenInternal
Memory4GDDR4 +32GeMMCDACES
9038Q2M*2Audio Processor
XMOS XU316
Op-amp ChipOPA1642
Power SupplyLow noise, high quality switching power supplies
HDD BayM.2 NVME 3.0 2280 protocol, up to 2TB
USB-A PortUSB3.0*2
EthernetRJ-45(10/100/1000Mbps)
WiFiWiFi 2.4G+5G dual bandPlayback and
DAC DecodingSupport up to stereo DSD512, PCM 768KHz 32Bit,
MQAMusic ServiceTidal, Qobuz, Highresaudio, Amazon, WebDAV, UPnPStreamingAir Play, DLNA, Roon Ready, Spotify, Tidal Connect, Qobuz Connect etc.Bluetooth Audio InputBLuetooth BT5.0, support SBC/AAC/aptX/aptX LL/aptX HD/LDACUSB-C Audio InputUSB Audio Compatibility: Windows (7, 10), Mac, Android, IOS
Support up to stereo DSD512, PCM 768KHz 32Bit, MQA
Optical/Coaxial Audio InputSupport up to stereo PCM 192KHz 24Bit, DSD64 Dop, MQAOptical/Coaxial Audio OutputSupport up to stereo PCM 192KHz 24Bit, DSD64 Dop, MQAHDMI Audio OutputDSD64 Native multi-channel/PCM192KHz multichannel raw output
Control Method Mobile App,
Touch screen control
XLR Output Audio CharacteristicsOutput level: 5.2V
Frequency response: 20Hz~20KHz(±0. 15dB)
Dynamic range: > 128dB
SNR: >128dB
THD+N: <0.00009%(-120dB) @A-wt
Crosstalk: >-125dB
RCA Output Audio CharacteristicsOutput level: 2.6V
Frequency response: 20Hz~20KHz (±0. 2dB)
Dynamic range: > 124dB
SNR: >124dB
THD+N: <0.00011%(-119dB)@A-WT
Crosstalk: >-124dB
PSUAC 110~240V 50/60HzRated Power13WDimensionsL 187mm* W 270mm* H 90mmPacking ListPower cable*1, USB cable*1,Screwdriver*1,user manual*1
Όλα αυτά κάτω απο χιλιάρικο (γύρω στα 900 ευρώ) και από τι μαθαίνω αντιπροσωπεύονται από την δικιά μας Audio Soul Ultra.
Unread post #172 by kostas6a3 » Sun May 14, 2023 7:07 pm
Ανακοινώθηκε πριν μια ώρα στη σελίδα της Rockna στο FB. Wavelight Server
https://www.facebook.com/rockna.audio/p ... JbHuanXmVl
Unread post #173 by Dr Pan K » Fri Jul 28, 2023 1:26 pm
kostas6a3 wrote:Ανακοινώθηκε πριν μια ώρα στη σελίδα της Rockna στο FB. Wavelight Server
Το σκεφτεσαι Κωστα?
Unread post #174 by kostas6a3 » Sat Jul 29, 2023 4:06 pm
Το σκεφτεσαι Κωστα?
Όχι , αλλά ακόμα το περιμένουν ......
Unread post #175 by angpsi » Sun Jul 30, 2023 1:07 pm
Το σκεφτεσαι Κωστα?
Παραδοσιακά αξιόπιστες οι εταιρείες hi-end... :lol:
Στιγμιότυπο οθόνης 2023-07-30, 1.05.29 μμ.png (55.9 KiB) Viewed 2763 times
Στιγμιότυπο οθόνης 2023-07-30, 1.08.11 μμ.png (31.35 KiB) Viewed 2762 times
Unread post #176 by DomieMic65 » Wed Aug 16, 2023 11:13 am
https://goldensound.audio/2023/02/09/ho ... surements/
https://www.kitsunehifi.com/product/hol ... -streamer/
Πολύ σημαντικό το ότι μπορείς να τρέξεις ότι OS προτιμάς!!
Unread post #177 by angpsi » Thu Aug 17, 2023 1:00 pm
DomieMic65 wrote:https://goldensound.audio/2023/02/09/holo-red-streamer-ddc-measurements/
Πραγματικό πολυεργαλείο!
Σχετικά με τα πολλά διαφορετικά OS, υποψιάζομαι πως οι πολύ χαμηλές μετρήσεις οφείλονται εν μέρει στο δικό τους RED OS το οποίο παίζει να είναι κάποιο από τα γνωστά Linux / MPD forks.
Τα καλά νέα είναι ότι έχουν κάνει δουλίτσα απομονώνοντας απο ένα τυπικό Pi όλα τα περιφερειακά κυκλώματα που δεν είναι χρήσιμα για audio. Αν βάλεις στο λογαριασμό το reclocker και το γραμμικό τροφοδοτικό, το κόστος απόκτησης στα 1Κ για εμπορικό προϊόν φαίνεται τουλάχιστον τίμιο!
Στιγμιότυπο οθόνης 2023-08-17, 12.59.37 μμ.png (61.65 KiB) Viewed 2543 times
Zakman35
Unread post #178 by Zakman35 » Fri Aug 18, 2023 10:14 am
Το αγόρασε πρόσφατα φίλος.
Πρόκειται για Κορυφαίο Renderer!
Μπορεί επίσης να παίξει και ως Server/Renderer, αλλά δεν έχει usb για σύνδεση hard drive.
To Red Os, ήταν υποδεέστερο από οτιδήποτε άλλο δοκιμάσαμε, αλλά ευτυχώς υπάρχουν πολλές εναλλακτικές.
Αν θυμάμαι καλά καταλήξαμε στο Roopie XL, με Squeezelite.
Unread post #179 by angpsi » Fri Aug 18, 2023 11:26 am
Zakman35 wrote:To Red Os, ήταν υποδεέστερο από οτιδήποτε άλλο δοκιμάσαμε, αλλά ευτυχώς υπάρχουν πολλές εναλλακτικές.
Από περιέργεια, τι διαφορές παρατηρήσατε; Ήταν θέμα εικόνας, χροιάς, μπάσου, ή άλλο;
Zakman35
Unread post #180 by Zakman35 » Fri Aug 18, 2023 10:19 pm
Κατά την γνώμη μου το Red OS είναι απλά ένα software που δίνει η εταιρεία προκειμένου να είναι λειτουργικό το προϊόν.
Επίσης υπήρχε θέμα στο να αναγνωρίσει το Dac μετά από reboot, τουλάχιστον στην version που έδειναν πριν 2-3 μήνες
Ανάλογα με το setup και το software που χρησιμοποιεί ο κάθε ένας, οι διαφορές μπορεί να είναι μικρότερες ή μεγαλύτερες. Στην δική μας περίπτωση η διαφορές ήταν μεγάλες σε όλα τα επίπεδα (ανάλυση, ταχύτητα, δυναμικά, εικόνα κτλ) συγκριτικά με άλλα software που δοκιμάστηκαν.
Υπόψη πως η HOLO όπως και πολλές άλλες εταιρείες του χώρου ειδικεύεται στο Hardware και όχι στο Software.
Το γεγονός ότι έφτιαξαν ένα προϊόν που μπορεί να χρησιμοποιήσει όλα τα software που κυκλοφορούν για RPI, εγώ το βλέπω σαν μια έξυπνη κίνηση.
