Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #171 by Dr Pan K » Sun Oct 08, 2017 11:39 pm
Mytek
Broolkyn+ DAC
DSD, DXD, MQA capable
Redesigned and enhanced conversion, analog and power supply circuits
New Sabre 9028PRO DAC chipset
upgraded headphone amplifier
better L/R separation
larger capacity power supply
new analog attenuator circuit
MSRP $2,195
brooklyn +.jpg (301.47 KiB) Viewed 5590 times
Unread post #172 by dapost » Mon Oct 09, 2017 11:05 am
Μάχη σώμα-με-σώμα με το Benchmark DAC3. Ίδιο chip, ίδια τιμή, πολλές δυνατότητες και τα δύο. MQA το Mytek, χωρίς το DAC3 - πτου κακά.
Unread post #173 by Gojakla » Mon Oct 09, 2017 12:28 pm
Focal Clear Open Back Headphones
Impedance
55 Ohms
Sensitivity
104dB SPL / 1mW @ 1kHz
THD
0,25% @ 1kHz / 100dB SPL
Frequency response
5Hz-28kHz
Loudspeaker
1.6" (40mm) Aluminum/Magnesium 'M'-shape dome
Weight
0.99lb / 450g
Cables provided
3m balanced cable (XLR 4-pin)
3m unbalanced cable (1/4" TRS jack)
1.2m unbalanced cable (1/8" TRS jack)
1/8" jack to 1/4" stereo jack adapter
Το "Clear" τοποθετείται ανάμεσα στα "Elear" & "Utopia".
Unread post #174 by dapost » Wed Oct 11, 2017 9:24 am
LCD-MX4
Style
Open circumaural
Transducer type
Planar magnetic
Magnetic arrays
Double Fluxor™ magnets
Magnet type
Neodymium
Transducer size
106 mm
Maximum power handling
15W (for 200ms)
Sound pressure level
>130dB with 15W
Frequency response
5Hz – 20kHz extended out to 50kHz
Total harmonic distortion
<1% through entire frequency range
Impedance
20 ohms
Efficiency
105 dB / 1mW
Optimal power requirement
1 – 4W
Τιμή
2,995 USD
Unread post #175 by Dr Pan K » Wed Oct 11, 2017 6:00 pm
LCD MX-4
Τιμή
2,995 USD
Πρέπει να είναι αυτά που δοκιμάσαμε στο Μόναχο με τον Αντώνη, πολύ πιο ελαφριά από τα γνωστά μοντέλα και με καλό ήχο. Μόνο που θυμάμαι ότι η τιμή έπρεπε να είναι η μισή από αυτήν που ανακοινώθηκε.
Unread post #176 by Dr Pan K » Thu Oct 19, 2017 10:20 pm
TotalDAC
Gigafilter USB Cable/ filter
Available @ 0.6, 1 & 2m length
MSRP starting at 1750 euro
Unread post #177 by BityaBit » Sun Oct 29, 2017 7:30 pm
TotalDAC
Tί στο καλό.. πλουτώνιο έχει μέσα;....
Unread post #178 by Dr Pan K » Sun Oct 29, 2017 9:45 pm
BityaBit wrote:
TotalDAC
Το δικό μου (άνευ φιλτρου) USB έχει κάπου εκεί και η τιμή δικαιολογείται (λέμε τώρα) από παλαιό χαλκό ... μην το ψάχνεις Πέτρο, ζητάνε ότι θέλουν
Unread post #179 by BityaBit » Mon Oct 30, 2017 8:30 am
Δεν είμαι αφελής για να κάτσω να το ψάξω εννοείται οτι είναι υπερκοστολογημένα και ας κάνουν δουλειά (σίγουρα κάτι θα κάνουν). Απλά κάνω ολιγον τί απο χιούμορ..
Unread post #180 by angpsi » Tue Oct 31, 2017 12:01 am
Dr Pan K wrote:Το δικό μου (άνευ φιλτρου) USB έχει κάπου εκεί και η τιμή δικαιολογείται (λέμε τώρα) από παλαιό χαλκό ...
Κάτι τέτοιο δηλαδή;
