Aurion Image and Sound
Audiohub Mod Team
Contact:
Re: Aurion Image and Sound
Unread post #21 by Audiohub Mod Team » Fri Dec 09, 2016 10:40 pm
The Questyle CMA600i Headphone Amp/DAC review @ Tone Audio
The Questyle CMA600i succeeds brilliantly on every level. It sounds great, is incredibly versatile and is visually elegant to boot. This is as good as it gets, and should you build a system around it; I suspect you will pass this one down to a family member. Well done Mr. Ball!
http://www.tonepublications.com/review/ ... ne-ampdac/
Διαχειριστική ομάδα
jemo
Contact:
Quad Artera Play / Stereo / Z-2
Unread post #22 by jemo » Sat Dec 17, 2016 10:12 am
http://avmentor.gr/reviews/quad_artera_ ... o_z2_0.htm
Artera with Z 2 series copy.jpeg (70.96 KiB) Viewed 8860 times
jemo
Contact:
AVTechmedia Award / BEST FLOORSTANDING LOUDSPEAKER / QUAD Z-3
Unread post #23 by jemo » Sat Dec 17, 2016 10:23 am
[image]
Quad Z-3 Awaqrd.jpg (1.09 MiB) Viewed 8857 times
[/image]
jemo
Contact:
TAS 2016 AWARD / EnigmAcoustics Sopranino Super-Tweeter
Unread post #24 by jemo » Sat Dec 17, 2016 10:37 am
[image][/image]
Absolute Sound’s Accessory of the
Year Award
$4995
The Sopranino is a self-biasing, horn-loaded, electrostatic super-tweeter that can be
added to any speaker system, either on top of the speaker or on available stands. It
is connected in parallel with your main speakers, and has selectable sensitivity and
crossover frequency. The Sopranino’s effect on the sound is decidedly unexpected: One
would think that a super-tweeter would add a bit of sparkle to the top octave, but the
Sopranino’s effect is more subtle. Rather than changing the tonal balance, the Sopranino
better resolves very fine treble detail, particularly micro-transients. The soundstage grows
larger and more expansive, with greater depth. Images within that soundstage have tighter
focus and delineation. With the Sopranino there’s a layer of air, space, dimensionality, and
micro-dynamic detail that you simply don’t hear when the Sopranino is disconnected—
even when it is used with world-class loudspeakers. Able to elevate the performance of
any speaker system, the Sopranino was an easy choice for The Absolute Sound’s Accessory of the Year. RH
jemo
Contact:
TAS 2016 AWARD / Synergistic Research Galileo UEF
Unread post #25 by jemo » Sat Dec 17, 2016 10:47 am
[image]
[/image]
Prices vary with
configuration
Ted Denney’s latest
creations improve on
the cumbersome ergonomics
of his original
Galileo multi-strand
cables (which had to
be plugged into and out of a multitude of boxes and actively biased via a
plethora of wall-wart power supplies) by packing most of that marvelous
Synergistic technology into the cable itself. Better still, the Galileo UEFs
significantly improve upon the truly stellar sonics of the original Galileos.
Indeed, the UEFs are the best-sounding wires Mr.
Denney has yet devised, achieving a dead-center
neutrality that is neither “bottom-up”
nor “top-down” in tonal balance, without any
sacrifice in natural warmth of timbre, resolution
of detail, transient speed, dynamic power, imaging
precision, or soundstage width, depth, and height.
When you consider that the Galileo UEFs are also
priced at one-third or one-quarter of what the original
Galileos went for (and roughly one-tenth of what
flagship cables and interconnects from certain other
companies currently cost), you have a veritable bargain
in ultra-high-end wire and a worthy TAS Interconnect
and Speaker Cable of the Year Award winner. JV (review
forthcoming)
jemo
Contact:
TAS 2016 AWARDS / AIR TIGHT
Unread post #26 by jemo » Sat Dec 17, 2016 11:19 am
[image]
[/image]
[image][/image]
Air Tight ATM-2001
Monoblock Amplifier
$135,000/pr.
With the arrival of the VAC 450 iQ, the Zanden
Model 9600, and the Constellation Hercules
stereo, this has been an exceptionally good
year in amps for JV. And while he would be
hard put to pick out a single indisputable
winner, this two-chassis monoblock from
Atsushi Miura of Air Tight is mighty impressive.
Almost as powerful as the VAC Signature
450 iQ, it equals or exceeds the VAC amp in
resolution, realism, and sheer timbral beauty. Somewhat fuller in balance (with
KT120s) than Kevin Hayes’ masterpieces, it is also bloomier than the V ACs and at
least as high in speed and detail (which is to say, as high as tube electronics get).
Although it could be argued that the ATM-2001s are inherently a bit “tubier”
than the VACs, what has been retained here of the classic tube sound is no more
nor less than all that is worthy of retaining: the three-dimensional “action” and
illuminated-from-within textural details that bring voices and instruments to
fullest life. Like the VACs, the Air Tights have near-solid-state-like grip in the
bottom octaves and the power range, and are realistically denser in color than
the VACs in both areas. As high-powered, push-pull, Class AB tube amplifiers go,
the ATM-2001 monoblocks are as good as they come—and therefore 2016’s TAS
Amplifier of the Year. JV (review in this issue)
opus-1-11-2-445w copy.jpg (131.7 KiB) Viewed 8857 times
Air Tight Opus 1
$15,000
Air Tight’s new top-line moving-coil cartridge adds even more resolution,
dimensionality, and energy to the beautiful reproduction
of tone color and superior soundstaging that the PC-1 Supreme
is justly famous for. Though not the non-stop thrill-machine and
sonic vacuum cleaner that the Clearaudio Goldfinger Statement
is, the Opus offers equally attractive (and more sophisticated)
benefits: a smoother, more natural upper midrange and treble, and
(building on one of the strengths of the Supreme) phenomenally
deep-reaching, superbly defined, extraordinarily quick and powerful
bass. Quite neutral in balance (when loaded at about 400–500
ohms), the Opus has the speed and resolution of über-cartridges,
without any trace of the analytic. One of JV’s references and one
of 2016’s worthiest Products of the Year. JV (261)
Audiohub Mod Team
Contact:
Unread post #27 by Audiohub Mod Team » Sat Dec 24, 2016 2:49 pm
Synergistic Research Black Quantum Fuses And UEF Black Duplex Outlet @ Enjoy The Music
Perhaps the least expensive way to give your system a qualitative upgrade of such magnitude.
http://www.enjoythemusic.com/magazine/e ... Review.htm
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Unread post #28 by Audiohub Mod Team » Thu Jan 26, 2017 8:04 pm
questyle stack.jpg (83.81 KiB) Viewed 8805 times
All in all, the Questyle Audio Gold Stack Reference system, as individual components and as a whole is everything you would expect or desire from a Reference system from a first class manufacturer, and a bargain at that.
http://headphone.guru/what-dreams-are-m ... ce-system/
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Unread post #29 by Audiohub Mod Team » Sun Jan 29, 2017 11:11 pm
Air Tight @ CES 2017
Not unlike a fine whiskey or wine, this type of sonic reproduction does not hit one over the head, and shout “I’m so gooooooood!” No, it plays around your edges, and draws you in. It unravels the loose thread on your sweater, and pulls until you’re sitting there oblivious, and half naked. This isn’t what I’d call music for the masses, it’s for those looking to develop their palate.
https://parttimeaudiophile.com/2017/01/ ... las-vegas/
Διαχειριστική ομάδα
jemo
Contact:
AURION SALES! Προσφορά -25% σε QUAD Classic ηχεια
Unread post #30 by jemo » Mon Jan 30, 2017 11:27 am
Αγαπητοί φίλοι,
Για το χρονικό διάστημα 1-28 Φεβρουαρίου και διαθεσιμότητα,
κάνουμε μια προσφορά -25% στα ακόλουθα QUAD ηχεία
σε κλειστά κιβώτια.... με εγγυήσεις!
Οι προσφορά με τα ηχεία 11L Classic, 12L Classic, 23L Classic, 25L Classic, QPM1,
και Quad L-ite 5.1, L-ite Sub, L-ite LCR
Η προσφορά μας: - 25% Λιανική τιμή
QUAD - 11L Classic piano black 480 ευρώ
12L "" "" " 720 "
23L " rose & black 1880 "
25L " rose & black 2780 "
QPM1 piano black 1200 "
L-ite 5.1 " " 1400 "
Sub " " 840 "
L-ite LCR " " 480 "
25L Classic (3).jpg (213.07 KiB) Viewed 8833 times
QH_23L (1).jpeg (26.17 KiB) Viewed 8833 times
25l classic veneer.jpeg (133.22 KiB) Viewed 8833 times
25L Classic (4).jpg (161.15 KiB) Viewed 8833 times
25l classic piano7.jpg (30.68 KiB) Viewed 8833 times
QUAD Vena Lifestyle 02a.jpeg (66.29 KiB) Viewed 8833 times
L-ITE LCR sound bar.jpeg (267.04 KiB) Viewed 8833 times
Return to “Αντιπρόσωποι & Κατασκευαστές”
