Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #21 by Dr Pan K » Wed Jul 20, 2016 7:37 pm
Cary Audio
SI-300.2d class AB amplifier
300Watt/8Ohm
$5,995
The SI-300.2d mates a 300 watts per channel stereo Class A/B power amplifier with analogue RCA and XLR inputs to a Class A analogue preamplifier gain stage. The amplifier itself is biased to run Class A for an extended portion of the power output. The digital section is a chip off Cary’s reference products thereby including technologies like their proprietary TruBit™ Upsampling and OSO™ reclocking features.
Digital inputs include; XMOS USB capable of True native DSD up to 256 and PCM/DXD up to 32 Bit / 384kHz, as well as Coaxial (2), Optical, AES/EBU, and aptX® Bluetooth inputs. All SPDIF and Bluetooth digital sources offer 10 TruBit™ selectable upsampling or PCM to DSD conversion options. On the analogue side, the SI-300.2d includes 4 analogue inputs (2-balanced XLR, 2-RCA), with one each of the XLR and RCA inputs offering true Cinema Bypass features.
Additional features include: a pre/subwoofer output, coaxial and optical digital outputs, IR hand held remote, trigger out, IR sensor input, and Ethernet and Wi-Fi for controlling the SI-300.2d with free iOS and Android apps.
Unread post #22 by Dr Pan K » Fri Jul 22, 2016 12:18 pm
Electrocompaniet
EMC 1 MKIV Reference CD player
Since 1998, Electrocompaniet has produced one of the best sounding CD players on the market, the EMC 1-UP. The new EMC 1 MKIV builds upon this legacy, and refines by using a new drive unit. The player has a high performance sample rate converter, fully balanced D/A converters and discrete analog audio circuitry for excellent performance. It features an unique cancellation system which cancels acoustic / mechanical vibrations, preventing the laser pick-up from receiving unwanted and sonically degrading signals.The audio quality surpassed our own EMC 1 UP, arguably one of the best CD players on the market today.
http://www.electrocompaniet.no/opencms/ ... _MKIV.html
Audiohub Mod Team
Contact:
Suesskind Audio Progress
Unread post #23 by Audiohub Mod Team » Tue Jul 26, 2016 10:50 pm
Suesskind Audio
Progress 3way speakers
Designed by Joachim Gerhard
4000euros
gerhard new.jpg (352.65 KiB) Viewed 39486 times
http://www.suesskindaudio.de/?portfolio ... go&lang=en
Διαχειριστική ομάδα
AQUA Formula optologic DAC
Unread post #24 by Dr Pan K » Tue Aug 02, 2016 8:45 pm
AQUA
Formula Optologic 24/384 DAC
proprietary discrete R2R resistors ladder D/A conversion system
Galvanic and magnetic isolations are implemented between the FPGA and the four branches of the R2R ladder converter
No digital filter
Discrete power supplies for analog and digital sections by extensive use of BJT, Mosfet, Jfet and ultra-fast diodes
Tantalum, solid-polymer OS-CON and double-metalized MJP caps
Price TBD
http://www.aquahifi.com/
YG Sonja XV anniversary speaker system
Unread post #25 by Dr Pan K » Tue Aug 02, 2016 9:15 pm
YG
Sonja XV four tower speaker system
MSRP: $265.900
yg xv.png (226.2 KiB) Viewed 39470 times
Sonja™ XV is an extreme, four-tower version of Sonja™, created to celebrate YG Acoustics™’ upcoming 15 year anniversary (2002-2017). It combines everything that we know about speaker-design, and incorporates several next-generation technologies that cannot be found elsewhere. Sonja™ XV - an entirely new sonic benchmark, truly extreme in every way... handmade in U.S.A.
Innovations include, first and foremost, a breakthrough tweeter made in-house, and proprietary cost-no-object bass inductors. These enhancements, together with an ability to move near-limitless amounts of air, result in an effortless listening experience that is typically only associated with a live musical performance.
The bass, midbass and midrange units are made in-house using YG Acoustics™’ proprietary BilletCore™ technology: the drivers are precisely machined out of massive slabs of aircraft-grade aluminum. This unique process offers overwhelmingly superior dynamics, musical delicacy and low distortion due to industry-leading rigidity and accuracy (tight tolerances). A pair of Sonja™ XV utilizes a total of 18 BilletCore™ drivers.
The brand new BilletDome™ tweeter is YG Acoustics™' most complex mechanical invention to date: a resonance-free soft dome is supported by a stiff, light airframe machined from aluminum billet. The airframe weighs a mere 30 milligrams (a thousandth of an ounce), but its critical sections are up to 14 times thicker than a typical hard dome, so its structural strength is vastly superior even to domes made of the most exotic hard materials. Finally, a tweeter that ends the age-old debate of hard versus soft, by combining the best of both.
The tweeter's motor is YG Acoustics™’ ingenious ForgeCore™ system: in-house CNC-cutting introduces sophisticated 3D geometries into the magnet system. The resulting improvement is greatly reduced distortion and a sense of ease to the sound.
YG Acoustics™ crossover circuits are all created using proprietary software developed entirely in-house. DualCoherent™ technology provides the best frequency response and relative phase available. Competing speakers are optimized in either the frequency domain (most common) or time domain. Only YG Acoustics™ has the ability to optimize both domains simultaneously.
Sonja™ XV's bass crossover uses a brand new technology: ViseCoil™ inductors are CNC-wound in-house, then encased in a vise-like milled structure to eliminate vibration and tighten tolerances. Residual loss is reduced by 24%, and linearity is improved by 60%. The result is better control over the woofers, far greater bass impact, and an easier job for most amplifiers.
Sonja™ XV’s mid and tweeter crossover uses ToroAir™ technology: in-house CNC-wound toroidal air-core inductors are unique in eliminating cross-talk (cross-contamination) common in crossover circuits. The result is preservation of high-frequency detail without harshness, brightness or sibilance.
Sonja™’s exquisite cabinet combines visual refinement with over-engineering. It is constructed of precision-machined aircraft-grade aluminum alloy. This material, using vibration-free pressurized assembly, allows for the most acoustically desirable enclosure achievable. The multi-layered structure is optimized for each module’s specific frequency range. This ensures the lowest vibration achievable, even at extreme volume levels.
FocusedElimination™ anti-resonance technology keeps mechanical losses lower than any competing speaker, by combining the minimized turbulence of a sealed design with the low friction otherwise associated with enclosure-free concepts.
YG Acoustics™ speakers are not voiced. All measurements are verified using extensive listening tests, but the speakers are not artificially manipulated. YG Acoustics™ speakers simply convey the recording – nothing more, nothing less.
The end-result: Sonja™ XV is the closest that we have ever come to the natural sound of a live performance. It will be heard by few and attained by even fewer, but those who hear it will likely echo the statement that our President Yoav Geva made upon finishing his masterpiece: "From now on, when I listen to music, I want it to be either live or with Sonja™ XV".
Expansions and Upgrades
Existing pairs of YG Acoustics™ Sonja™ can be expanded to Sonja™ XV, without the need to replace the speakers.
Sonja™ XV, in addition to its state-of-the-art two-channel (stereo) performance, is also fully compatible with multi-channel audio and home-theater systems. Sonja™ XV can also be combined with speakers from YG Acoustics™’ other lines for properly phase-coherent multi-channel systems.
Specifications
Deviation:
±1 dB in the audible band
±5° relative phase throughout entire overlap
Exceptional pair-matching
Usable output extends from below 20 Hz to above 40 kHz
Drivers:
A four-way, four-tower system with a total of 20 drivers per pair of speakers
BilletCore™ ultra-high-rigidity woofers, mid-woofers and mids
BilletDome™ ultra-low-distortion tweeter, unique to Sonja™ XV
Filters:
Sonja™ XV is fully-passive
Proprietary DualCoherent™ crossover at 65 Hz, 337 Hz and 1.75 kHz
Designed using software developed in-house
ViseCoil™ bass inductors reduce residual loss and improve linearity, for greater bass impact and an easier job for most amplifiers
ToroAir™ mid and tweeter inductors eliminate cross-talk
Sensitivity:
88 dB / 2.83 V / 1 m 2π anechoic
Impedance:
4Ω nominal, 3.5Ω minimum
Dimensions:
4 towers, each 179x43x72 cm (70x17x28”) HxWxD
Avalon Saga
Unread post #26 by Dr Pan K » Thu Aug 11, 2016 2:01 pm
Avalon Saga
4 driver 3 way speakers
92dB sensitivity, 4Ohm min impedance
Estimated RP >110.000 euros
avalon saga + JR.jpg (456.56 KiB) Viewed 39445 times
Rockport Lyra
Unread post #27 by Dr Pan K » Tue Aug 16, 2016 11:50 pm
RockportLyra
3+1/2 way spewaker
Berilium tweeter, 2x6" mid, 2x10" woofers
Aluminum and polymer composite cabinet
$149.500 installation included
rockport lyra.jpg (541.17 KiB) Viewed 39433 times
lyra rockport.jpg (83.7 KiB) Viewed 39433 times
Platanus 2.0 MC cartridge
Unread post #28 by Dr Pan K » Thu Aug 18, 2016 1:16 am
Platanus MC cartridge
designed by Tetsuya Sukehiro
Output voltage: 0.3mV
Frequency response: 10Hz ~ 50kHz
Internal impedance: 2.5Ω
Channel separation: 30dB or more (1kHz)
Channel balance: 0.5dB within (1kHz)
Compliance: 7 x 10-6cm / dyne (100Hz)
Cantilever: A2017 aluminum alloy, tapered shape
Needle tip: Diamond / line contact (curvature radius 3μm x 30μm)
Magnet: Neodymium
Housing: A7075 aluminum alloy (base), A6063 aluminum alloy (body part)
Needle pressure: 1.9g ~ 2.1g (standard 2.0g)
Own weight: 16.0g
Retail price in Japan 360.000Υen
ZYX Ultimate 100
Unread post #29 by Dr Pan K » Sat Aug 20, 2016 11:29 am
ZYX Ultimate 100
Στην Ιαπωνία ανακοινώθηκε η απόλυτη 100ρα απο την ΖΥΧ, κόστος 160.000Yen. Προς το παρόν δεν υπάρχει τίποτα στον δυτικό τύπο αλλα τα τεχνικά χαρακτηριστικά ειναι
ZYX Ultimate 100
output 0.24mV
DC resistance 4 Ohm
6N copper coils
channel separation >30dB @1KHz
frequency extension 10-80KHz
tracking weight 1.7-2.5gr
optimal tracking 2gr
weight 5gr
http://www.hinoetp.com/ZYX201608NEW.pdf
HiFiMan SuperMini
Unread post #30 by Dr Pan K » Mon Aug 22, 2016 10:24 pm
HiFiMan SuperMini
Dimensions : 4.09” x 1.77” x 0.33” (104.0 x 45.0 x 8.5mm L x W x H )
Weight : 2.4oz (70g)
Output : 320mW@32Ω(Balance Output)
TF Card : Up to 128GB
Frequency Response : 20Hz - 20kHz
THD : 0.04%
S/N : 102 ± 3 dB
Battery Life : 22 hours
Supported Music Formats : (Up to 24Bit / 192kHz) WAV, FLAC, AIFF, APE, MP3, OGG, AAC, WMA, ALAC, DSD (DSF, DFF)
MSRP $399
supermini bottom.jpg (183.67 KiB) Viewed 39407 times
