Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #231 by Dr Pan K » Thu Jul 05, 2018 4:57 pm
Krell
K300i integrated amplifier
2x150/8, 2x300/4 Ohm
80.000 μF
770VA power transformer
18Kgr
24/192 DAC
Roon ready
MQA capable
Msrp 5.500 έυρω
Unread post #232 by Dr Pan K » Sat Jul 14, 2018 10:40 pm
Audeze
LCD-2
closed back planar magnetic headphones
Proprietary magnet array
Phase management FAZOR
Magnet type Neodymium N50
Diaphragm type Ultra-thin
Transducer size 106 mm
Maximum power handling 15W
Maximum SPL >130dB
Frequency response 10Hz – 50kHz
THD <0.1% @ 100dB
Impedance 70 ohms
Sensitivity 97dB/1mw (at Drum Reference Point)
Minimum power requirement >100mW
Recommended power level 1 - 4W
MSRP approx 900 euros
Για περισσότερες πληροφορίες Audio Soul Ultra
Unread post #233 by Dr Pan K » Sat Jul 21, 2018 7:41 pm
Chord
Hugo M Scaler
Upscales digital audio up to 705.6kHz (16x CD’s 44.1kHz native resolution)
Upscaling to 768kHz (from 96kHz files) with selected Chord Electronics DACs
Rob Watts’ 35-year goal of >1M taps achieved: M Scaler has 1,015,808 WTA taps
Improves all digital: streamers; smart devices/computers; CD/DVD players and more
Compact TT chassis stackable with Hugo TT 2 DAC/pre and TToby power amp
Multiple inputs for a range of devices: galvanically isolated USB-B; 2x BNC; 2x optical
Galvanically isolated dual BNC outputs (to 768kHz) for use with DAVE, Qutest, Hugo TT 2 and future products; single BNC to 384kHz output, optical to 192kHz
Adjustable sample rate output with pass-thru mode, plus low latency video mode
Automatic modes for video and source selection plus remote control
MSRP approx 4.000 euros
Unread post #234 by Dr Pan K » Fri Jul 27, 2018 10:54 am
Klipsch
r5 wireless earphones
5mm micro driver
IPX4 (water resistant)
aptX & AAC Bluetooth connectivity
Hand stiched leather band
MSRP approx 140 euro
Unread post #235 by Dr Pan K » Fri Aug 03, 2018 5:04 pm
Carot One
Ernestolo 50K integrated amplifier
50.000 Carot One amps sold world-wide anniversary edition
Single RCA input
2x12/8Ohm 2x24/4Ohm
Msrp 649 euro
Unread post #236 by Dr Pan K » Mon Aug 06, 2018 10:42 pm
Vinnie Rossi
L2 Signature Preamp
Class A Direct Heated Triode design
compatible with: 2A3, 45, 300B, PX4, 101D, 205D, and SV811
Discrete, 64-step resistor ladder volume control
Phono and DAC option
MSRP 22.000 euro
rossi pre front.png (909.52 KiB) Viewed 6067 times
rossi pre back.png (1.03 MiB) Viewed 6067 times
Vinnie Rossi
L2 Signature Mono power amplifiers
2x75W/8 Ohm, 2x140W/4 Ohm
100KOhm input impedance
100dB SNR
9Kgr/mono
MSRP 14.995$/mono
rossi mono.png (1.07 MiB) Viewed 6067 times
rossi mono back.png (1.01 MiB) Viewed 6067 times
Unread post #237 by pankon » Mon Aug 06, 2018 11:03 pm
Αυτά θα ήθελα να τα ακούσω!!!
Unread post #238 by Dr Pan K » Tue Aug 07, 2018 1:15 pm
pankon wrote:Αυτά θα ήθελα να τα ακούσω!!!
Πάλι καλά που δεν έγραψες ότι σε ενδιαφέρει..
Unread post #239 by pankon » Tue Aug 07, 2018 1:44 pm
Με ενδιαφέρουν σαφώς! Πλατωνικά όμως... :lol:
Unread post #240 by Dr Pan K » Sun Aug 12, 2018 10:18 pm
Rega
Aura Reference phono stage
Input Sensitivity for 200 mV on Unbalanced Output
67 μV - 69.5 dB Gain Setting I
131 μV - 63.5 dB Gain Setting II
Gain Input to Unbalanced Output
63.5 dB Minimum
69.5 dB Maximum
Input Load 50, 100, 150, 300 & 400 Ω
Capacitive Load 1000, 2000, 3200, 4300, 5700 pF
Input Overload @ 1 kHz
9.6 mV - 63.5 dB Gain Setting
4.9 mV - 69.5 dB Gain Setting
RIAA Accuracy (Better Than) 0.2 dB 100 Hz to 50 kHz
THD Typically 0.03 % @ 1 V 20 Hz 20 kHz (Bandwidth 100 Hz to 22 kHz)
Output Noise Level (Unbalanced Output, A-Weighted and 15 Ω Input Load)
-77 dB V (69.5 dB Gain Setting I)
-82 dB V (63.5 dB Gain Setting II)
MSRP 3999 GBP
rega aura.jpg (183 KiB) Viewed 6026 times
http://www.rega.co.uk/aura-mc-stage.html
