Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #251 by Dr Pan K » Fri Oct 05, 2018 12:15 am
Sonus Faber
Electa Amator III
2-way bookshelf loudspeaker system
A 28mm tweeter featuring the DAD TM – Damped Apex Dome TM technology (the tripod recalls the peculiarity of its predecessor);
“Paracross topologyTM” crossover design with Clarify Cap ESA capacitors, for a sweeter sound that remember the voice the 90ies models;
6.5 inches mid-woofer specifically developed for this special project.
MSRP 10.000 euro
Unread post #252 by Dr Pan K » Sat Oct 13, 2018 9:39 pm
Focal
Elegia electrodynamic closed back headphones
aluminium/magnesium alloy 40mm dome
extended frequency response of 23 KHz
frameless copper voice coil
35Ohm impedance
430gr
MSRP 850 euro
Unread post #253 by Dr Pan K » Sat Oct 20, 2018 1:17 am
TAD
E1TX-K Speaker
3-way, bass reflex, floor type
Woofer: 16-cm cone type x 2
Midrange/Tweeter: Coaxial 9-cm cone type / 2.5-cm dome type
Reproduction Frequency Band: 29 Hz-60 kHz
Crossover Frequency: 420 Hz, 2.5 kHz
Output Sound Pressure Level: 88 dB (2.83 V-1 m)
Maximum Input: 200 W
Nominal Impedance: 4 Ω
Unit Polarity: Low range (+), middle range (+), high range (+)
External Dimensions: 350 mm (W) x 1215 mm (H) x 512 mm (D)
Weight: 46 kg
TAD E1TX-K.png (157.05 KiB) Viewed 7325 times
http://www.technicalaudiodevices.com/ne ... wkpy-f98al
Unread post #254 by Dr Pan K » Mon Oct 22, 2018 1:18 am
VPI
HW 40
direct drive turntable
2,500 pulses/revolution
12Kgr aluminum platter
torque: 2.68 Nm/sec
40 years anniversary Harry Weisfeld
JMW FatBoy gimbal tonearm
VTA on the fly
dustcover included
MSRP $15.000
Unread post #255 by Dr Pan K » Tue Oct 23, 2018 10:29 pm
Stax
80th Anniversary Limited series earspeakers
SR-L300 Limited edition
other models to follow
Limited model in Black finished with a gold plaque
Limited to 800 units
The "MLER" (Multi-Layer Elect Rode) ellipse sound element is equivalent to Lambda series top model SR-L700.
Frequency response: 7 - 41,000 Hz
Capacitance: 110 pF (including cable)
Impedance: 145 kΩ / 10 kHz (including cable)
Sound pressure sensitivity: 101 dB / 100 V r.m.s.
Bias voltage: 580V DC
Cable: specially made 6-core low capacity OFC cable, length 2.5 m
Earpad: fine artificial leather
Weight: 486 g (including cable), about 360 g (without cable)
Stax 80th Anniversary SR-L300 limited.jpg (114.88 KiB) Viewed 7255 times
https://staxaudio.com/earspeaker/sr-l300limited
Unread post #256 by Dr Pan K » Fri Nov 09, 2018 9:53 pm
Chord
Ultima Pre & Power amplifiers
Frequency Range: 2.5Hz – 200kHz +/- 3dB
Total Harmonic Distortion: 0.002% 20Hz – 20kHz
Intermodulation Distortion: -125dB on all inputs
Signal to Noise Ratio: -125dB on all inputs
Channel Separation: 20Hz @ 110dB, 1kHz @ 105dB, 10kHz @ 100dB, 20kHz @ 95dB
Channel Balance: 0.01dB
Switching mode power supplies
Fully balanced design
Proprietary Chord Mosfet
Sliding class AB
780W@8Ohm, 1400@4, 2500@2
Peak current 500A
MSRP 30.000£ each
https://chordelectronics.co.uk/product/ultima-pre/
https://chordelectronics.co.uk/product/ultima/
Unread post #257 by Dr Pan K » Thu Nov 15, 2018 8:21 pm
GigaWatt
Marton Reference 2.00 stereo power amplifier
bridgable mono configuration
Designed by Marek Knaga
120Kgr
MSRP 47.000 euro
marton inside.jpg (85.68 KiB) Viewed 7114 times
Unread post #258 by Dr Pan K » Sat Dec 01, 2018 12:51 am
YG
Invincible subwoofers
Bandwidth Truly full output (-0 dB), even anechoically, to below 20 Hz
Usable output extends below 15 Hz
Drivers
BilletCore™ ultra-high-rigidity subwoofer(s) with a diameter of 53 cm (21”)
InVincible™ 21.1 – single driver
InVincible™ 21.2 – dual drivers
Amplifier Up to 6,000 watts RMS (requires a 230 Volt AC hookup, otherwise 3,000 watts)
DSP Proprietary DualCoherent™-inspired crossover with user-controllable frequency
Designed using software developed in-house
Pre-programmed for precise matching with YG Acoustics™ speakers
Extensive options for matching with third-party speakers
Dimensions 75x68x68 to 177x68x68 cm (30x27x27 to 70x27x27”) depending on configuration
Weight 111 to 210 kg (244 to 462 lbs) unpackaged, depending on configuration
Unread post #259 by Dr Pan K » Wed Dec 05, 2018 6:51 pm
McIntosh
70th Anniversary MC2152 power amplifier and C70 Preamplifier
For each of these 70 Limited Edition Commemorative Systems sold, McIntosh will donate $1,000 to global humanitarian organization Save the Children.
MC2152 2x150 Watt
Only 70 will be made from each design
MC2152 70th Anniversary Amplifier: $15,000 USD
C70 70th Anniversary Preamplifier: $7,000 USD
MC2152 C70 Anniversy System.jpg (355.69 KiB) Viewed 6932 times
MC2152 70th Anniversary engraving StC.jpg (317.6 KiB) Viewed 6932 times
MC2152 Hero green tubes.jpg (297.34 KiB) Viewed 6932 times
C70 Angle Close Up2 Background StC.jpg (456.92 KiB) Viewed 6932 times
C70 Back Background.jpg (388.61 KiB) Viewed 6932 times
C70 Tubes.jpg (475.78 KiB) Viewed 6932 times
Unread post #260 by Dr Pan K » Sat Dec 08, 2018 5:28 pm
Ortofon
Century Turntable
• Ortofon Concorde Century cartridge pre-installed
• Electronic speedcontrol (33/45 rpm)
• Top grade Clamp and Leather mat included
• Belt drive principle
• Height adjustable decoupling feet
• Precision balanced TPE-damped aluminium-platter
• Metal/MDF sandwich chassis floating on TPE suspension
• 9” aluminium s-shape tonearm with SME compatibility
• Japanese ball bearing (base of tonearm)
• Integrated central vertical cable outlet for unhindered arm movement
• Ultra low friction Zircon pin-point cardan bearings (top and side)
• Azimuth and VTA fully adjustable
• TPE damped counterweight
MSRP 2990 euro
https://www.project-audio.com/en/produc ... n-century/
