Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #261 by angpsi » Thu Dec 13, 2018 12:32 pm
Αυτό πώς το χάσαμε βρε παιδιά; Τώρα και με ενσωματωμένο streamer, 4.4mm balanced headphone jack, AES input και XLR output για studio monitor συστήματα, σε χρυσό και σε μαύρο. Με λίγα λεφτά επιπλέον παίρνεις το μοντέλο "Master" με κεραμική Rogers PCB και πιο προσεκτικά διαλεγμένα υλικά. https://www.questyle.com/en/product/CMA-twelve
Questyle
CMA Twelve
CMA Twelve Master
New Flagship DAC / Headphone Amp
Questyle CMA12 celebrates 12 years of Questyle products distilled into one brilliant machine!
Questyle CMA Twelve, the new flagship DAC / Headphone Amp from Questyle inherits their classic desktop design format and outperforms its peers once again. It marks the anniversary of Questyle’s revolutionary Current Mode Amplification technology, invented 12 years ago.
Only when you see it will you truly understand the exquisite finish and design detail achieved between Questyle and their manufacturing partner, Foxconn, setting new benchmarks in technological standards. The chassis of the CMA Twelve has very high efficiency for heat dissipation, which ensures it will work with absolute stability in pure Class A, keeping the temperature at 45 degrees.
Mechanical vibration will affect audio signal processing and the resulting sound. To avoid resonance, the CMA Twelve chassis is formed from 10mm-thick aircraft-grade Aluminium 6063, with high precision machining techniques of ±0.02mm.
Questyle CMA 12 is designed with four groups of Current Mode amplifiers, exhibiting forceful driving power and an ultra-low distortion level of a mere 0.0005%. Plus the high-performance BIAS Control System, CMA Twelve will give full performance to your headphone or speaker systems and bring you an exceptional listening experience.
Balanced headphones with a 4.4mm connector are a rising trend with many headphone manufactures including Sennheiser, Audio Technica and Sony, launching products with 4.4mm-connections. CMA Twelve is Questyle’s first device to feature the 4.4mm jack and Questyle is committed to support this growing trend.
Whole Device
· Finish:Black | Golden
· Chassis Materials: special CNC tooled Aluminum
· Dimension: 12.99”(330mm)[ W ]×7.87”(200mm)[ D ]×1.38”(55mm)[ H ] · Working Status: Pure Class A
· Voltage:100-120V or 220-240V,the voltage is switchable.
· Power Consumption: 17W
DAC+Headphone Amplifier Section
- Outputs:
4.4 mm balanced headphone jack
4PIN balanced headphone jack
6.35mm headphone jack
- Max Output Power(Po):
247mW @ 300Ω; 900mW @ 32Ω(6.35mm headphone jack)
825mW @ 300Ω; 2W @ 32Ω (balanced headphone jack)
- THD + N:
0.00070% @Po=100mW, 300Ω
0.00167% @ Po=50mW, 32Ω
- Frequency Response:
DC-20kHz(+0, -0.4dB)@0dBFS, 24Bit, 192kHz
DC-80kHz(+0, -3dB)@0dBFS, 24Bit, 192kHz
- SNR: 112dB, non-weighting
DAC+Pre-Amp Output Section
- UCB Type B Input:
Support 44.1kHz-384kHz/16Bit-32Bit PCM and DSD Native DSD64, DSD128, DSD256, as well as DSD64, DSD128, DSD256 of DoP format
(Note: support Win XP, Vista, Win7, Win8, Win10 and Mac OS)
- Digital Input & Output:
SPDIF input and output, Optical input, AES/EBU input
Support 44.1kHz-192kHz/16Bit-24Bit PCM
- Pre-Amp & DAC Section:
Balanced XLR x1 pair, unbalanced RCA x1 pair
STANDARD 14dBu: XLR: 5.084V RCA: 2.549V
STUDIO 20dBu: XLR: 8.887V RCA: 4.475V
THD+N@STUDIO 20dBu: XLR: minimum at 0.00085% RCA: minimum at 0.00115%
SNR: XLR:>112dB RCA:> 109dB (non-weighting)
(Note: FIX/ADJ: Fixed Output Mode or Adjustable Output Mode of the pre-amp.)
Unread post #262 by Dr Pan K » Sat Jan 05, 2019 2:04 am
Copland
CTA 408 integrated amplifier
2x6072A/12AY7 & 2x12BH7
4xKT150 output tubes in push pull configuration
2x75W@8Ohm
MM & MC phono stage
remote control
headphone output
MSRP approx 6890euro
COPLAND_408 back.jpg (59.82 KiB) Viewed 12216 times
copland_CTA-408 inside.jpg (150.35 KiB) Viewed 12216 times
Unread post #263 by Dr Pan K » Fri Feb 01, 2019 8:43 am
Takatsuki Electric Industry
TA-S01 integrated amplifier
3-stage amplification, single ended triode amplifier
Vacuum tube used 12AU7×4 , TA-300B×2
Power supply Department:TA-274B×1
Output transformer TAMURA F-2007A×2
Impedance(output/input) 4, 8, 16Ω/ 100kΩ
Input RCA pin jack stereo, 2 systems
(Direct input×1, AC coupling input×1)
Mass 28kg
MSRP $50.000
Απο τους σχεδιαστές μιας εκ των κορυφαίων 300Β έρχεται ενας ολοκληρωμένος ενισχυτής με σιδερα Tamura και πολλά υποσχόμενο ήχο. Η ανορθωτρια ειναι επισης κατασκευασμενη απο την Takatsuki. Αν ειδα καλα εχει manual bias adjustment
takatsuki TA-S01.jpg (34.57 KiB) Viewed 12068 times
300b back.jpg (117.55 KiB) Viewed 12068 times
https://www.takatsuki-denki.co.jp/en/pr ... b-amp.html
Unread post #264 by Dr Pan K » Tue Feb 05, 2019 9:39 am
Sonus Faber
Palladio custom installation speaker line
Level 5 modern design
Level 6 in wood veneer
In wall and in ceiling installation
Unread post #265 by Dr Pan K » Thu Feb 28, 2019 9:31 am
Luxman
PD-151 turntable
sine wave/Pulse Width Modulation power supply provides ultra-stable direct current to the
new DC brushless belt drive, high torque motor
Wow & flutter < 0.04%
4Kg Aluminum platter
Aluminum upper plate
antiresonant chassis
PEEK thrust bearing
33-45-78 rpm
Jelco tonearm
15.7Kg
MSRP 3895$
luxman pd 151 back.jpg (25.25 KiB) Viewed 11772 times
luxman pd 151 cover.jpg (94.4 KiB) Viewed 11772 times
luxman front.jpg (103.1 KiB) Viewed 11772 times
Απίθανη περίπτωση!
Unread post #266 by Dr Pan K » Fri Mar 01, 2019 11:59 am
Boulder
2108 phono stage
3 separate balanced inputs
Resistive and capacitive loading adjustable on individual Personality Cards
3 separate power supplies
RIAA, DECCA, Columbia EQ curves
2 chassis
Max THD 0.005%
MC: 70 or 60 dB gain
MM: 50 or 40 dB gain
Crosstalk -100 dB or better, 20 Hz to 20 kHz
16.8 + 21.8 Kg
Το αναφεραμε στην ακροαση στο Melody Club, το προηγούμενο μοντελο ηταν θρυλος ενω το μικρο 500ρακι μας εντυπωσιασε με τις επιδοσεις του. Τωρα ξεκιναει το λανσαρισμα του νεου 2108, τιμη απαγορευτικη αλλα ηχος απο αλλο πλανήτη?
Unread post #267 by Dr Pan K » Thu Mar 14, 2019 6:28 pm
Estelon
Forza speakers
Type: 4-way sealed box
Woofer: 2 x 250 mm CELL Aluminium Sandwich Accuton (custom design)
Mid Woofer: 190 mm CELL Aluminium Sandwich Accuton (custom design)
Midrange: 168 mm CELL Ceramic Accuton
Tweeter: 25 mm CELL Diamond Accuton
Internal Wiring: Kubala-Sosna
Frequency Response: 25 - 60 000 Hz
Power Rating: 400 W
Min Amplifier Power: 20 W
Nominal Impedance: 3 Ohm (min 2,0 Ohm at 42 and 110 Hz)
Sensitivity: 90 dB/2.83 V
MSRP in Europe 110,000 EUR.
Unread post #268 by Dr Pan K » Tue Mar 19, 2019 1:44 pm
Tech DAS
Air Force Zero turntable
Base Frame: 100 kg, stainless steel
Platter Base: 35 kg, extra super duralumin
Platters: 118 kg in total
Bottom platter: 30 kg, ø 40cm, forged Stainless Steel SUS 316L
Second platter: 20 kg, ø 31cm, forged Stainless Steel SUS 316L
Third platter: 20 kg, ø 31 cm, cast Gunmetal
Fourth Platter: 20 kg, ø 31 cm, forged Stainless Steel SUS 316L
Top Platter: 28 kg, ø 31 cm, powder sintered Tungsten
Total moment of inertia: 18,720 kg/cm square
Drive system: Belt-drive, polished and nonflexible polyurethane fiber belt
Drive Motor: 3-phase 12-pole AC synchronous motor manufactured by Papst, Germany (1000/5001)
During a startup and adjustment of the rotation, high torque rotation
In a stead-state rotation, non servo, low torque, ultra low vibration
Rotation speed: 33.3 rpm / 45 rpm, precise speed adjustment function
Wow & Flutter: below 0.03%
Suspension: Air suspension, air charged by an electric air pump built-in in Power Supply Unit
Main Unit Dimensions including Motor: 901 (W) x 677 (D) x 335 (H) mm
Distances between center point of base frame feet:
front left foot - front right foot 674mm / rear left foot - rear right foot 722mm
front left foot - rear left foot 461mm / front right foot - rear right foot 442mm
Total weight of Main Unit including Motor: 350kg (Power Supply / Air Pump Units are not
To ζωο της αποκαλυψης. Κτηνος 350 κιλα με Papst κινητηρα, το ειχαμε ακουσει σαν προσχεδιο πριν 2 χρονια στο Μοναχο αλλα τωρα ειναι πραγματικοτητα.
Air Force Zero.jpg (525.64 KiB) Viewed 11490 times
Air Force Zero side.jpg (533.32 KiB) Viewed 11490 times
Unread post #269 by angpsi » Tue Mar 19, 2019 1:55 pm
"Platter Base: 35 kg, extra super duralumin", σαν να μην ήταν δηλαδή το υπόλοιπο κατασκεύασμα αρκετά επιβλητικό! :lol: :lol: :lol:
Unread post #270 by Dr Pan K » Mon Apr 08, 2019 8:48 am
Stenheim
Alumine 3
3-way floor standing speaker
2 x 8-inch woofers, 1 x 5 1⁄4-inch neodymium medium drivers, 1 x neodymium tweeter
Massive aluminium cabinet with 3 independent chambers: 2 closed (medium & tweeter) and 1 with a laminar flow front port
Passive 3-way crossover, using high-grade audiophile components
Frequency response: 32 to 35 kHz
Sensitivity: 93 dB, half space
Power handling: 150 W RMS, 300 W peak
Minimum recommended power: 10 W
Nominal impedance: 8 ohms (minimum 5 ohms)
Dimensions: H 1050mm x W 250mm x D 330 mm
Weight: approx. 70 kg (including adjustable feet)
Guarantee: 5 years
Αυτο ενδέχεται να ειναι και το ιδανικο high end ηχειο για ελληνικο σπιτι.
3749-101_no-backg round_v3.png (104.19 KiB) Viewed 11322 times
