Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #291 by Dr Pan K » Sun May 31, 2020 2:13 pm
Έβγαλα ένα μηδενικό, στα 10Κ πρέπει να έχει εκτος Ιαπωνίας
Unread post #292 by Dr Pan K » Fri Jul 03, 2020 9:31 am
ATC
150 SCM ASLT Active limited edition
2x350W class AB amplification
LEMO connectors
116kg each speaker
MSRP 46.000 GBP (approx 50K euro)
Manufactured to the highest standard by ATC’s own cabinet makers, weighing 116kg and at approximately 1.4m tall, each speaker enclosure is finished in selected European crown-cut walnut veneer with a high-gloss polyester lacquer, and detailed with a stainless steel badge, input panel and bespoke limited edition plinth. Stainless steel components are treated using PVD (Plasma Vapour Deposition) to create an exclusive dull nickel-like appearance, inspired by Billy Woodman’s passion for vintage motor and sports cars. The finish is both beautiful and exceptionally tough.
P6 Power Amplifier
The P6 is a high-performance Class AB dual-mono power amplifier designed and built by ATC to provide dedicated amplification and optimally matched active crossovers for the SCM150ASLT. It features a total of 6 channels for a combined output power of 350W/side. Generating a signal-to-noise ratio of more than 105dB, its ultra-low noise discrete design, paired with 3-way active crossovers with phase equalisation, offers clear and detailed audio reproduction. On the rear panel, balanced XLR inputs (from preamplifier/digital source) are joined by aerospace-grade LEMO multi-pin loudspeaker output connectors. Proprietary 3m loudspeaker cables are included.
As is customary with ATC products the SCM150ASLT and P6 are covered by a six-year warranty.
Only 22 pairs are available and on a first-come-first-served basis.
Unread post #293 by Gojakla » Fri Jul 03, 2020 5:53 pm
ΦΑΚ
Unread post #294 by angpsi » Fri Jul 03, 2020 6:37 pm
Παλιάνθρωπε!
Unread post #295 by Dr Pan K » Fri Jul 03, 2020 10:07 pm
Και όμως με τον ενισχυτή δεν τα αγόραζα. Παθητικά και πάλι παθητικά, βάζω ότι γουστάρω για ενίσχυση και παίζω πολύ καλύτερα. Άσε που το 150 δεν ξέρω αν με καλύπτει..
Unread post #296 by angpsi » Sat Jul 04, 2020 12:41 am
Πάντως σε παθητικό μόνο μέχρι το 150άρι βλέπω ότι πάει η ATC.
Unread post #297 by MILES » Sat Jul 04, 2020 9:09 am
Dr Pan K wrote:Και όμως με τον ενισχυτή δεν τα αγόραζα. Παθητικά και πάλι παθητικά, βάζω ότι γουστάρω για ενίσχυση και παίζω πολύ καλύτερα. Άσε που το 150 δεν ξέρω αν με καλύπτει..
Είναι γεγονός ότι με τα ενεργά γλυτώνεις πολύ ψάξιμο και αποτελούν σίγουρες/δοκιμασμένες λύσεις, γιατί τη "δουλειά" την έχουν κάνει άλλοι για σένα.
Αλλά βρε παιδί μου έτσι χάνεται η μαγεία του ψαξίματος και γενικά του hobby μας!
Unread post #298 by Dr Pan K » Mon Jul 06, 2020 8:29 am
Καλα, προφανώς γλιτωνεις αλλα θες να γλιτωσεις?
Και περαν του χομπι, οι ενισχυτες της ATC ειναι τιμιοι αλλα μεχρι εκει. Οταν φοριουνται μεσα σε ενα ηχειο με συγκεκριμενο ογκο στην διαθεση τους, οταν οι ψυξη τους ειναι αυτη που ειναι σε μεγεθος ενω ταυτοχρονα πρεπει να αποδιδουν χαμηλη θερμοκρασια για να μην ψησουν τις μοναδες μεσα στο ηχειο και οταν δηλωνουν 350W στο συνολο ανα καναλι και το τροφοδοτικο χωραει μεσα σε ενα κουτακι στην πλατη του ηχειου, οταν η τιμη σε σχεση με το παθητικο ειναι μολις λιγες χιλιαδες ευρω παραπανω τοτε καταλαβαινει ο καθενας οτι αυτα τα ενισχυτικα παιζουν σε ταξη Β παρα ΑΒ (και σιγουρα εχουν ισως ενα watt σε ταξη Α) και πως γενικα αποκλειεται να ειναι ο κορυφαιος συνδυασμος.
Τα ενεργα της ATC ειναι σχεδιασμενα για τις αναγκες ενος studio, οπου οι χροιες δεν εχουν θεση, οπου η καταναλωση ρευματος πρεπει να ειναι χαμηλη, οπου η παραγωγη θερμοτητας πρεπει να ειναι περιορισμενη και ισως συματνικοτερο ολων, το budget δεν ειναι hiend αλλα το βλεπουν σαν απαραιτητο εξοπλισμο. Τιποτα απο ολα αυτα δεν συναδει με κορυφαιο ηχο.
Unread post #299 by pankon » Mon Jul 06, 2020 8:43 am
Ρεαλιστική τοποθέτηση, Παναγιώτη, που δεν μπορεί κάποιος να την αμφισβητήσει. Για πες, τι ενισχυτές θα χρησιμοποιούσες με αυτά τα ηχεία; Λάμπες ή SS;
SouthKops
Unread post #300 by SouthKops » Mon Jul 06, 2020 10:23 am
Για το συγκεκριμένο επετειακό ηχείο καθώς και για τα ενεργά 150, 200 & 300, η ενισχυτική διάταξη είναι εξωτερικά και θηριώδης, όπως στη φωτό, άνωθεν.
Φυσικά, όσο καλύτερο και ποιοτικότερο ενισχυτή χρησιμοποιήσει ο χρήστης ATC,  τόσο καλύτερα αποτελέσματα θα έχει.
Σε αυτό το hobby --> Sky is the limit!
Από την άλλη σε πολλές περιπτώσεις ιδιοκτητών ATC, η ενεργή λύση προσφέρει πολλά πλεονεκτήματα. Ειδικά όσο αφορά τα 40 & 50.
Προσωπικά έχω "βάλει στο μάτι" ένα 200άρι, νομίζω με τον Gryphon Antileon EVO θα είναι match made in heaven.....
