Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #341 by Dr Pan K » Fri May 16, 2025 12:19 pm
H Mark Levinson λανσαρει νεα σειρα (600) ενισχυτων και μαθαίνοντας απο τα λαθη επιστρεφει σε κλασση Α/ ΑΒ.
https://us.marklevinson.com/600-series#
№ 626: Where Analog Soul Meets Digital Precision
The № 626 Dual-Monaural Preamplifier is a celebration of sonic fidelity blending an all-analog signal path with a high-resolution digital core. At its heart is the Precision Link III DAC, capable of decoding up to 32-bit / 384kHz PCM and native DSD audio through its six digital inputs. The analog stage is anchored by a fully balanced Pure Path architecture, while a Pure Phono MM/MC phono stage and Main Drive Class A headphone amplifier make the № 626 a complete solution for every source. Designed with modular isolation, dual power supplies, and vibration-damped foot architecture, this is a preamplifier that lets the music speak for itself and say everything.
№ 632 and № 631: Pure Power, Unbound Emotion
Designed for those who demand authority and refinement in equal measure, the № 632 Dual-Monaural Amplifier and № 631 Monaural Amplifier deliver dynamic headroom and clarity that unveil the full scale of a performance.
Both amplifiers feature Class A/AB operation, Pure Path fully balanced signal paths, and robust toroidal power supplies housed within their own dedicated modular chassis. The № 632 offers stereo flexibility and dual-mono separation, while the № 631 delivers uncompromised performance as a single-channel powerhouse, unleashing music with stunning impact, tonal depth, and holographic imaging.
Unread post #342 by Dr Pan K » Wed Oct 22, 2025 2:36 pm
Marantz Model 10
Integrated amplifier
2x250W @8 Ohm, 2x400 @4 Ohm
Switching mode power supply
33.7 Kgr
MM / MC phono input
PHONO (MM): 88dB
PHONO (MC): 76dB
CD: 122dB
Balanced: 122dB
Headphone Output Level 130mW / 32 ohms
Available in black or champagne color
Copper plated chassis
270W power consumption
Made in Japan
MSRP $15.000 / 15.500€
https://www.marantz.com/en-us/product/a ... ifications
15K για ενα ολοκληρωμένο ενισχυτή με μετρησεις στα 125 W (και οχι στα 250 που δηλωνει) και διακοπτικο τροφοδοτικό για τα στάδια εξόδου μου φαίνονται καπως πολλα. Με τα ίδια χρήματα αγοράζεις σετ προ τελικών ή και πολυ σοβαρούς ολοκληρωμένους από ASR, Symphonic line, Densen, Electrocompaniet κτλ κτλ κτλ.
Unread post #343 by pankon » Sun Apr 12, 2026 6:51 pm
Ο Andrew Jones σχεδίασε νέο ηχείο, πλέον από τη δική του, νεοϊδρυθήσα εταιρία. https://www.youtube.com/watch?v=cb0oRL_cE28
Unread post #344 by DomieMic65 » Mon Apr 13, 2026 1:30 pm
Το είχα δει!!
Ενδιαφέρον δείχνει το όλο concept αλλά να το ακούσουμε εδώ μάλλον δύσκολο!!
Unread post #345 by Dr Pan K » Mon Apr 13, 2026 4:06 pm
Έπαιξε Σικάγο το ΣΚ (έτρεχε η Axpona). Θα μάθω νέα
Unread post #346 by angpsi » Wed Apr 15, 2026 10:20 pm
Βλέπω ματσάρισμα με Lab 12;;
Εξηγήσεις εδώ:
Μουσικούλα ε΄δώ:
Unread post #347 by pankon » Thu Apr 16, 2026 8:52 am
έχουμε καμιά εικόνα για τιμή; Ο Chris1997 ετοιμάζεται για ψ΄ώνια. Έμεινε πολύ καιρός ήσυχος στο πεδίο των ηχείων.
Unread post #348 by Dr Pan K » Thu Apr 16, 2026 10:14 am
$33.9K απο το στομα του Andrew
Το δωματιο ειχε ασταματητα ουρα για να μπεις μεσα, σε σημειο που πολλοι δεν καταφεραν να το ακουσουν καν. Και συμπερασματα δεν ειναι ευκολο να βγουν στις εκθεσεις αλλα τα πηγαν πολυ καλα με ενα ολοκληρωμενο Lab12 (Integre4).
Ευαισθησία στα 93dB, tube friendly. Πανο εχουν το ονομα σου γραμμενο επανω τους
*κατι πηρε το αυτι μου για λιγο τονισμενες μεσαιοψηλες αλλα πρεπει να το διασταυρωσω.
Unread post #349 by pankon » Thu Apr 16, 2026 10:27 am
Εγώ ακολουθώ τον Χρήστο. Μόλις τα βάλει στο μικρό δωμάτιο, θα τα ακούσω και θα τραβήξω τη σκανδάλη. Οι μεσουψηλες αν είναι τονισμένες, θα μου αρέσουν, γιατί έχουμε και μια πτώση ακοής λόγω ηλικίας.
Unread post #350 by pankon » Thu Apr 16, 2026 8:00 pm
Η τιμή αναμένεται στα 34Κ USD. Σεμνά και ταπεινά.
