Straight Outta Factory!
Re: Straight Outta Factory! Wilson Audio Autobiography
Unread post #351 by Dr Pan K » Fri Apr 24, 2026 9:22 am
Wilson Audio
Autobiography
Autobiography Red Rock Sunset Front 3-4-2.JPG (1019.96 KiB) Viewed 1730 times
At the core of Autobiography lies a completely new driver complement. This is a five-way loudspeaker configured in an M(MTM)M array, with every transducer making its first appearance in this system. Each driver was conceived specifically for Autobiography, not developed as an isolated component, but as part of a unified acoustic architecture.
The vertical arrangement consists of a 7-inch midrange at the top and bottom of the gantry, followed by a symmetrical MTM crescent framed array composed of dual 2-inch midrange drivers flanking the CSLS front-firing tweeter. This assembly creates a mirror structure that reinforces coherence through the critical vocal and instrumental regions. Low frequencies are handled by two dissimilar woofers, a 12-inch unit and a 15-inch unit, developed exclusively to operate together. Completing the driver lineup is a rear-firing ambient tweeter designed to enrich
spatial information.
MSRP $788.000
Autobiography Red Rock Sunset MTM Alingment Assembly Tweeter.JPG (1.04 MiB) Viewed 1730 times
Autobiography Red Rock Sunset Upper Side 2.JPG (974.36 KiB) Viewed 1730 times
Unread post #352 by Dr Pan K » Fri Apr 24, 2026 9:24 am
Autobiography Alingment Scale.JPG (835.7 KiB) Viewed 1730 times
Autobiography Ethereal White Central Nervous System Gantry Binding Posts.JPG
Autobiography Ethereal White Central Nervous System Gantry Binding Posts.JPG (1.75 MiB) Viewed 1730 times
Autobiography Ethereal White Copper Heat Sinks.JPG (1012.2 KiB) Viewed 1730 times
Autobiography Ethereal White Front 3-4 1-2.JPG (1019.91 KiB) Viewed 1730 times
Unread post #353 by Dr Pan K » Fri Apr 24, 2026 9:30 am
Autobiography NZ Black Sand.jpg (426.55 KiB) Viewed 1729 times
Autobiography Crowned Rose Red Grille.JPG (1.11 MiB) Viewed 1729 times
Unread post #354 by angpsi » Fri Apr 24, 2026 10:21 pm
Είδα παρουσίαση / συνέντευξη του Daryl στο Youtube με παρουσίαση του ηχείου. Με την αισθητική δεν είμαι εντελώς εκεί, αλλά σαν κατασκευή είναι ακραίο!
Unread post #355 by pankon » Mon Apr 27, 2026 8:45 am
Μου φέρνει λίγο "alien"
