Straight Outta Factory!
McIntosh MHA150 Headphone Amplifier
Unread post #41 by Gojakla » Wed Sep 14, 2016 12:46 pm
MHA150 Angle Right USB with MHP1000.jpg (286.41 KiB) Viewed 42285 times
McIntosh, the global leader in prestigious home entertainment and ultimate-quality audio
for over 65 years, is proud to announce the launch of the new MHA150 Headphone Amplifier.
HEADPHONE POWER OUTPUT
High Selection: 1W
Normal Selection: 250mW
HEADPHONE OUTPUT IMPEDANCE
8-40 Ohms
40-150 Ohms
150-600 Ohms
TOTAL HARMONIC DISTORTION
0.005%
DYNAMIC HEADROOM
1.5dB
FREQUENCY RESPONSE
+0, -0.5dB from 20Hz to 20kHz
+0, -3dB from 10Hz to 100kHz
SENSITIVITY (BALANCED / UNBALANCED)
600mV / 300mV
SIGNAL TO NOISE RATIO
105dB
TONE CONTROLS
5 Step Bass Boost Control
HEADPHONE OUTPUT
1 (1/4”)
INPUTS BALANCED
1 Stereo
INPUTS UNBALANCED
1 Stereo
DIGITAL USB INPUT
1 (accepts PCM signals up to 32-bit/384kHz; supports
DSD64, DSD128 & DSD256; DXD352.8kHz & DXD384kHz)
DIGITAL COAXIAL INPUT
1
DIGITAL OPTICAL INPUT
1
DIGITAL MCT (SACD) INPUT
1
TUBE OR SOLID STATE
Solid State
DIMENSIONS (W X H X D)
29.2cm x 14.9cm x 45.7cm
WEIGHT
12 kg
Murasakino Sumile MC cartridge
Unread post #42 by Dr Pan K » Thu Sep 15, 2016 11:15 pm
Murasakino Ltd. Sumile MC cartridge
“Sumile” means “violet” in Japanese, taken from the cartridge’s housing color.
Frequency Response 10~50,000HZ
Output Voltage 0.35mV / 1kHz
Internal Impedance 1.2Ω
Tracking Force 1.9~2.1g
Cantilever Material Boron
Weight 14.5g
http://www.murasakino.audio/products/sumile.html
Audiohub Mod Team
Contact:
Thomas Mayer 300B Differerntial power amps
Unread post #43 by Audiohub Mod Team » Fri Sep 23, 2016 1:12 am
Thomas Mayer 300B Differential power amps
15Watt in Class A
10Y driving 300B in push pull configuration
tube rectification by 6Ax4
choke input and oil caps
Like the matching line and phono stages they will be fully differential throughout. Nut just a PP output stage but also a differential input stage. Of course they can also be used with single ended preamps. Phase splifting is done via input transformers. Output tubes will be a pair Elrog 300Bs per channel, driven by a pair 10Y. Alternatively 801A can be used as well. These should be good for a solid 15W per channel. Operation will be pure Class A.
http://vinylsavor.blogspot.gr/2016/09/t ... art-1.html
Διαχειριστική ομάδα
Wilson Audio Yvette
Unread post #44 by Dr Pan K » Fri Sep 23, 2016 11:27 pm
Wilson Audio Specialties Yvette
3 way single enclosure speaker
Tweeter, midrange and 10" woofer as used on Alexx and upcoming WAMM speakers
MSRP $25.500 in Wilsongloss™ Standard Colors, $26,150.00 in Wilsongloss Upgrade Colors
http://www.wilsonaudio.com/products/yvette
Von Schweikert Audio Ultra-11
Unread post #45 by Dr Pan K » Sun Sep 25, 2016 11:19 am
Von Schweikert Audio Ultra-11speakers
All-new exotic drivers: four 15" active ceramic woofers, four 9" ceramic midranges, two 7" reinforced ceramic midranges, two Beryllium tweeters, and two 5" aluminum ribbon super tweeters
Point to point hand built networks and enclosed in a proprietary Faraday Cage that protects crossover parts and wiring from electrical noise contamination
Time Alignment, Phase Consistency, and adjustable bi-polar sound radiation pattern for room-filling sound
Frequency response from 10Hz to 100kHz
Sensitivity 94dB
$300.K
Re: Straight Outta Factory!
Unread post #46 by Dr Pan K » Sun Sep 25, 2016 11:30 am
Το πλαϊνό απο τα Zellaton Statement και η οπίσθια πλευρά απο τα Lansche ή τα μεγαλα Stenheim? Kαι αντε να πουμε οτι δυο μεγαλα woofer εχουν χρησιμοποιηθεί απο πολλους στο πίσω μέρος του ηχείου, η καμπίνα ομως ειναι προκλητικά κοντά σε αυτή της Zellaton.
zellaton statement.jpg (108.74 KiB) Viewed 42236 times
Lansche by PK.JPG (1.07 MiB) Viewed 42236 times
OPPO HA-2SE Portable Headphone Amplifier and DAC
Unread post #47 by Dr Pan K » Wed Sep 28, 2016 6:47 pm
HA-2SE offers high performance digital-to-analog conversion for Apple’s iPhone/iPod products, a wide range of Android devices, PC and Mac computers.
Ultra-slim Design – Stacking the HA-2SE on top of most smartphone models is often still thinner than other portable headphone amplifier models alone.
ESS Sabre32 Reference DAC – ES9028Q2M DAC chip delivers high-resolution performance with extremely low noise and distortion.
High-Resolution Audio – The HA-2SE supports PCM audio up to 384 kHz / 32-bit, DSD audio up to 12 MHz (DSD256 or DSD4x). No Camera Connection Kit required for high-resolution playback from iOS devices.
Ideal Companion for iPhone 7 – The HA-2SE provides improved sound quality over the adapter that comes with the iPhone 7, and its ability to charge the phone while you listen to music resolves the issues arising from the removal of the 3.5 mm headphone jack.
Multiple Devices Support – The HA-2SE supports multiple device types for digital-to-analog conversion via USB: iPod / iPhone / iPad, smartphones with USB OTG feature, PC and Mac computers.
Mobile Power Bank with Rapid Charging – The HA-2SE functions as an external battery pack to charge mobile devices. Its internal battery can be quickly charged in about 30 minutes with the patented rapid charger.
$299
https://www.oppodigital.com/headphone-amplifier-ha-2SE/
KEF LS50 Wireless
Unread post #48 by Gojakla » Thu Oct 13, 2016 5:33 pm
200 watts -Class D- power for the bass driver
30 watts -Class A/B- for the coaxially-aligned tweeter
24/192 capable DAC
DSP module to implement the crossover network and correct phase errors
OLED touch display on the master loudspeaker
Asynchronous USB and TOSLINK inputs
2.4GHz / 5GHz Ethernet and Wi-Fi network streamer with DLNA networking
RCA connectors to tap a phono pre-amplifier’s line-level output and digitise it
Cat6 Ethernet connection between master & slave speaker
Remote Controled
Spotify Connect
US$2200
Watch the Teaser video!
Source: DAR_KO
Unread post #49 by Dr Pan K » Thu Oct 13, 2016 7:59 pm
Αν η KEF εχει κάνει υποτυπωδώς σωστά την δουλειά της το παραπάνω ηχειο πρέπει να τα σπάει..
Chord TToby stereo amplifier
Unread post #50 by Dr Pan K » Thu Oct 13, 2016 11:32 pm
ttoby 1+2.JPG (233.95 KiB) Viewed 42198 times
The TToby is an exciting new desktop stereo power amplifier designed to complement the Hugo TT DAC and take advantage of its high-quality digital preamp functionality. The TToby has been created using the same form factor as the Hugo TT and its introduction enables desktop audio lovers to create a high- performance Chord system where space is tight.
ttoby back.JPG (156.21 KiB) Viewed 42198 times
The new TToby will offer Chord’s proprietary amplifier technology and deliver 130 watts into a four-ohm load. The Hugo TT and TToby combination, allows music lovers to enjoy the benefits of Chord’s class-leading DAC technology via headphones and loudspeakers, giving complete flexibility within busy households. TToby offers both balanced and unbalanced inputs to complement the Hugo TT’s outputs, and benefits from Chord’s famous switch-mode power supplies.
MSRP: 2995 GBP (UK)
