Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #51 by Gojakla » Fri Oct 14, 2016 8:33 pm
Dr Pan K wrote:Αν η KEF εχει κάνει υποτυπωδώς σωστά την δουλειά της το παραπάνω ηχειο πρέπει να τα σπάει..
http://us.kef.com/ls50-wireless
Hi Fi Man Shangri La electrostatic headphones
Unread post #52 by Dr Pan K » Mon Oct 17, 2016 10:26 pm
Hi Fi Man
Shangri-la electrostatic headphones and matching energizer
7Hz-50Khz
Estimated MSRP $50.000
shangri la.jpg (105.37 KiB) Viewed 6984 times
shangri-la headphone.jpg (206.56 KiB) Viewed 6984 times
Unread post #53 by Gojakla » Tue Oct 18, 2016 12:04 am
Και δεν υπαρχει τυπογραφικο λαθος να υποθεσω, ε;
Unread post #54 by Dr Pan K » Tue Oct 18, 2016 12:09 am
Για τα 50 χιλιάρικα? Λίγα ε? Κάνουν τα μεγαλα Stax να φαίνονται σαν entry level budget component... Αλλα χωρίς πλάκα, δεν μου κανει εντύπωση, το κλασσικό Sennheiser Orpheus ειχε φτάσει στα 30Κ μεταχειρισμένο και ηταν και περιζήτητο. Γιατι να μην ζητάνε 50 για κατι που θεωρούν ανώτερο (και τεχνολογικά ειναι)
Focal by Tournaire
Unread post #55 by Dr Pan K » Wed Oct 19, 2016 9:26 pm
Focal by Tournaire
Tournaire jewellers have been renowned for many years for their symbolic and atypical designs. Focal and Tournaire share the same values, which include excellence and uniqueness. Both are renowned “Living Heritage Companies” (having received the Entreprises du Patrimoine Vivant label), and the two companies are famous throughout France and worldwide for their exceptional expertise.
MSRP 110.000 euro
focal tournair.jpg (135.4 KiB) Viewed 6946 times
http://www.focal.com/en/content/11974-u ... -the-world
Analog Domain DAC1
Unread post #56 by Dr Pan K » Sat Oct 22, 2016 2:26 pm
Analog Domain
upcoming DAC1
MSRP TBD
AD DAC1.jpg (52.34 KiB) Viewed 6926 times
Mytek Manhattan II
Unread post #57 by Dr Pan K » Sun Oct 23, 2016 11:06 pm
Mytek
Manhattan II DAC, headphone amplifier, pre-amplifier, phono stage, network streamer
MSRP 5995euro, phono stage card $1495, network card $995
Designed with the new, world's highest performance 130dB Sabre ES9038 32bit DAC chipset, the unit handles PCM up to 384k, 32bit, MQA, native DSD up to DSD256, DXD and 130dB Dynamic Range. A new Mytek Femto Clock™ incorporated into their C777 Clocking architecture pushes jitter and the noise floor below measurable levels. Wordclock input and output allows stacking multiple units for multichannel operation, including multichannel DSD and SACD.ISO playback.
Optional "Roon Ready" Network Card:
Turns the Manhattan into network streamer with 24/192k andDSD64 maximum throughput.
Compatible w/ Roon, Airplay, DLNA/UpnP, Spotify Connect, IOS, Android.
Στην ουσια η Mytek προσπαθεί να διορθώσει τα λάθη της πρώτης γενιας (με το γνωστό πρόβλημα του θορύβου του phono stage λογω κακου layout των κυκλωμάτων) ενω ταυτόχρονα προσθέτει λειτουργιά streamer (που ομως δεν μπορεί να ανέβει μεχρι DXD και 4xDSD οταν το DAC απο άλλη πηγή τα υποστηρίζει). Οι ιδιοκτήτες του Manhattan Ι θα μπορουν να αναβαθμίσουν με περίπου 1000 ευρω.
Jazzer
Unread post #58 by Jazzer » Mon Oct 24, 2016 7:12 pm
Σε αυτά τα χρήματα παίρνει κάποιος το ROCKNA με κλειστά μάτια και χαιρετάει την Mytek από μακρυά.
Είναι αρκετά σοβαρό ποσό για να μην εξεταστούν και άλλες σοβαρότερες προτάσεις, για όποιον βέβαια μπορεί να φτάσει μέχρι εκεί !
Unread post #59 by Dr Pan K » Mon Oct 24, 2016 8:38 pm
Σε αυτά τα χρήματα παίρνεις γενικότερα ladder DAC και οχι ESS SABRE..
Shinola TT by VPi
Unread post #60 by Dr Pan K » Mon Oct 24, 2016 11:02 pm
Shinola Runwell
belt drive turntable
built by VPi
MSRP $2500
https://www.shinola.com/audio.html#/
