Straight Outta Factory!
Re: Straight Outta Factory!
Unread post #81 by BityaBit » Thu Nov 24, 2016 8:39 pm
andreasecon wrote:Απλά δεν παίζεται στο design o Metaxas !!!!!!!!!!!!!!!!!!!!!!!
+1 :shock:
Unread post #82 by Dr Pan K » Sat Dec 03, 2016 9:37 pm
XTZ Spirit series
New line of speakers
Prices 285-850 euro
http://www.xtzsound.eu/product/spirit-series
McIntosh D1100 Digital Preamplifier and MP1100 Vacuum Tube Phono Preamplifier
Unread post #83 by Dr Pan K » Fri Dec 09, 2016 10:36 pm
McIntosh D1100
MSRP $7.000
D1100 Angle Left OPT.JPG (262.38 KiB) Viewed 7502 times
D1100 Back.jpg (260.01 KiB) Viewed 7502 times
The D1100 Digital Preamplifier is a reference level stereo preamplifier and digital-to-analog converter (DAC). Its 8-channel, 32-bit DAC is used in Quad Balanced mode with half of it dedicated to the left audio channel and the other half to the right channel. It’s the most advanced DAC McIntosh has ever used and delivers an unprecedented level of performance so that all digital music is reproduced with exceptional accuracy and authenticity.
Nine inputs are included to keep even the largest digital system connected as 3 optical, 3 coaxial plus 1 each of MCT, AES/EBU and USB inputs are onboard. The USB input accepts up to 32-bit/384kHz signals and supports DSD64, DSD128, DSD256, DXD 352.8kHz and DXD 384kHz playback. All the other inputs accept up to 24-bit/192kHz. Three sets of balanced and unbalanced stereo outputs connect the D1100 to the rest of the audio system.
McIntosh MP1100
Phono Preamplifier
MSRP $8.000
MP1100 Low Angle LP.JPG (283.19 KiB) Viewed 7502 times
MP1100 Top Angle.jpg (491.8 KiB) Viewed 7502 times
MP1100 Back Angle.jpg (338.45 KiB) Viewed 7502 times
The MP1100 Phono Preamplifier will give vinyl lovers a new level of musical enjoyment and exhilaration. It’s filled to the brim with everything needed to not only play records, but it will also get every last musical note and nuance out of them – including some that may have never been heard before.
The MP1100 is designed first and foremost for analog audio and achieves our most accurate equalization ever. It utilizes four 12AX7A vacuum tubes, with 2 tubes used per channel in a fully balanced configuration – making it our very first fully balanced vacuum tube phono stage. It has 3 sets of RCA phono inputs with XLR connectors also available on 1 of the inputs. All phono inputs allow for adjusting both resistance (6 settings) and capacitance (8 settings). For ease of use, it comes pre-programmed with profiles for Moving Coil and Moving Magnet cartridges as well as the McIntosh MT10 and MT5 turntables. Five additional profiles are included that are fully customizable and can be assigned to any phono input. RIAA, LP, NAB, AES and 78 analog equalization curves are included. Two fairly rare but highly useful analog filters are built-in: a Rumble Filter helps remove noise that may have seeped into a song during the recording process; while a Scratch Filter can help restore the sound of frequently-played records that may have become a little worn, or records that may have some damage. Adjustable gain from 40dB to 64dB allows for further customization, while a Mono setting permits proper playback of mono recordings. In addition, there’s a pair each of balanced and unbalanced high level inputs for connecting other sources. A pair each of balanced and unbalanced fixed outputs round out the connections.
Not to completely overlook digital audio, the MP1100 has an optical, coaxial and USB output. They are fixed at 24-bits and can be set to either 96kHz or 192kHz. When used with a properly configured conversion program, the USB output can be used to “rip” albums to a computer.
Genesis Maestro loudspeakers
Unread post #84 by Dr Pan K » Sat Dec 17, 2016 7:49 pm
Genesis
5 Way design
two Genesis Ring-Radiator Ribbon Tweeters (front and back)
one 4.5-inch solid Titanium-cone midrange driver
two 6.5-inch aluminum mid-bass couplers
four 8-inch woofers with 500W servo-controlled bass amplifier
MSRP $30.000 + taxes in the US
genesis maestro.png (1022.79 KiB) Viewed 7488 times
http://www.genesisloudspeakers.com/
YG Acoustics Rack
Unread post #85 by Dr Pan K » Mon Dec 19, 2016 11:20 pm
YG Acoustics
Rack
MSRP starting at $14.850
Unread post #86 by Dr Pan K » Thu Dec 22, 2016 7:54 pm
Danish Audio Design
The Little
Class A/B stereo power amplifier
MSRP 23.100 euro
TheLittle DAD.png (426.9 KiB) Viewed 7466 times
Audionet Stern Preamplifier
Unread post #87 by Dr Pan K » Sun Dec 25, 2016 10:11 pm
Audionet
Stern Preamplifier
Designed by Hartmut Esslinger (Apple)
DC coupled
Galvanic separation of all analog circuits by opto couplers
Magnetically and capactively optimized circuit and device design without any ferro-magnetic material
Four encapsulated and decoupled 50 VA toroid transformers
176.000 μF of total filtering capacitance
MSRP to be announced @ CES
AKG N Series Noise cancelling headphones
Unread post #88 by Dr Pan K » Wed Dec 28, 2016 1:58 pm
AKG
N Series
TBA @ CES 2017
akg n series.jpg (712.11 KiB) Viewed 7432 times
akg n quincy.jpg (379.84 KiB) Viewed 7432 times
akg n iem.jpg (353.72 KiB) Viewed 7432 times
TAD Micro Evolution One
Unread post #89 by Dr Pan K » Mon Jan 02, 2017 7:00 pm
TAD
Micro Evolution One
3 way speakers
Woofer: 6.3-inch Aramid cone
Midrange/Tweeter: Coaxial 3.5-inch Magnesium cone / 1-inch Berylium dome
MSRP: $12.495
tad me1.jpg (27.39 KiB) Viewed 7417 times
http://tad-labs.com/jp/corporate/press/160916_01.php
DS Audio 002 cartridge
Unread post #90 by Dr Pan K » Tue Jan 03, 2017 12:44 am
DS Audio
DS 002 Optical phono cartridge system
Aluminum cantilever - Shibata tip
Whereas MM & MC cartridges rely on magnets and coils to generate the electrical signal, the Optical cartridge uses a beam of light to detect cantilever movement, making the cartridge much lighter, and more agile. This also removes the magnetic field inside the cartridge caused by the coils & magnets in conventional cartridge designs, and it’s subsequent influence on cantilever movement.
MSRP TBD
ds2 amp.jpg (39.07 KiB) Viewed 7399 times
