Straight Outta Factory!
Mark Levinson No 515 Turntable
Unread post #91 by Dr Pan K » Wed Jan 04, 2017 9:17 pm
Belt Drive Turntable
Built in collaboration with VPi
MDF and Aluminum plinth
20 pound Aluminum platter
inverted bearing
high torque AC motor
MSRP $10.000
https://parttimeaudiophile.com/2017/01/ ... turntable/
Nordost Valhalla 2 USB cable
Unread post #92 by Dr Pan K » Wed Jan 04, 2017 9:22 pm
flat, twin-axial geometry
19 AWG solid core, silver-plated copper conductors
Dual Mono-Filament technology
finely-braided silver shield for each conductor
HOLO:PLUG® connecto
MSRP $3500
Chord Hugo 2
Unread post #93 by Dr Pan K » Fri Jan 06, 2017 1:48 pm
Τα νεα προϊόντα απο το CES συνεχίζουν να ανακοινώνονται:
Chord Hugo 2
32bit/768KHz
DSD512
49152 taps
2600mAh battery
Crosfeed, Line level mode
IR remote control included
MSRP 1800GBP
Moon 888 power amps
Unread post #94 by Dr Pan K » Fri Jan 06, 2017 1:51 pm
Moon By SimAudio
888 mono power amps
888 Watts
250Lbs weight each
8KW max power output
MSRP $118.888/ pair
Blumenhofer Fun 13 MK 2
Unread post #95 by Dr Pan K » Wed Jan 11, 2017 9:48 pm
Blumenhofer
Fun 13 MK 2
2 ways speaker based on a quarter wavelength bass horn
New silk dome tweeter, 28mm diameter
New woofer same dimensions but with P2C (peek carbon peek sandwich) membrane
MSRP 2700 euro in Germany
Sugden 50 year Grande Anniversary power amp
Unread post #96 by Dr Pan K » Thu Jan 12, 2017 9:37 pm
Sugden
100 Watts in pure class A
50Kgr per mono amp
sugden anniversary.jpg (24.38 KiB) Viewed 6409 times
Air Tight ATM-3211
Unread post #97 by Dr Pan K » Sun Jan 15, 2017 11:19 pm
Air Tight ATM-3211
211 push pull mono power amplifiers
100 Watt/8 Ohm
Price TBD
VPI Titan
Unread post #98 by Dr Pan K » Wed Jan 18, 2017 12:24 am
VPI Titan
Rim Drive Magnetic drag turntable
MSRP $75.000
vpi titan.jpg (342.97 KiB) Viewed 6376 times
vpi titan close up.jpg (695.26 KiB) Viewed 6376 times
Re: Straight Outta Factory!
Unread post #99 by Dr Pan K » Wed Jan 18, 2017 10:51 pm
Lexicon
Soundsteer SL-1 speaker system
2 x 12" woofers, 8 midrange, 12 dome tweeters per speaker
22 power amps for 1250 Watts/ speaker
WiFi, 24/192 capable
Price TBD
Lexicon SL1.jpg (67.85 KiB) Viewed 6363 times
Conrad Johnson new Classic Amplifiers
Unread post #100 by Dr Pan K » Fri Jan 20, 2017 9:10 pm
Conrad Johnson
Classic Amplifiers
CL62 uses a pair of EL34 output tubes per channel to produce 60 Watts/channel.
CL120 uses two pair of EL34s for 125 Watts/channel.
Each is also available in upgraded “SE” versions featuring KT120 output tubes
MSRP TBD
C J Classic 62.jpg (51.18 KiB) Viewed 6355 times
C J Classic-120.jpg (70.38 KiB) Viewed 6355 times
http://conradjohnson.com/announcing-new ... mplifiers/
