Rockna Wavedream DAC
Unread post #1 by Gojakla » Mon Apr 11, 2016 8:23 pm
Official Site
OVERVIEW
THE SOUND YOU EVER EXPECTED, AND BEYOND.
We are proud to present our current flagship in digital audio reproduction. We believe it has the right ingredients to produce a sound that will honour it’s name. In the good tradition established by it’s predecessor, the Wavedream continues to push the limits of performance, design and sound quality. The ingredients, innovations, technology and features of the product are presented below.
SOFTWARE DEFINED ARCHITECTURE
We always thought that high-end audio should be everything about innovation. Playing around with off-the-shelf available chips is fun and certainly a good and economic way to produce good sound. But once you want to design a cutting-edge product, the off-the-shelf approach doesn’t apply. Naturally, a custom solution, freed from the limitation of the available chipsets, come into place, allowing us to design and build from the scratch an entire digital audio system.
All building blocks of the Wavedream DAC consernig digital processing are built entirely on a single piece of programmable silicon – a FPGA . With a FPGA, it’s internal hardware architecture could be described by a piece of software (actually, a very complex one). When upgrading the Wavedream with new firmware, you actually change it’s hardware. This system allows great flexibility, obsolescence protection and let us improve the sound of your dac by changing it’s internal architecture, or add new cool features, or improve the existing ones.
FEATURES
FEMTOVOX CLOCK SYSTEM
The clock is the heart of a digital reproduction system. It’s accuracy and jitter levels are critical in regard of sound quality. Only a very good clock system can make the way to the analog sound on the output of your DAC. If the clock is flawed, digital harshness will occur and the analog feeling of the music will be severely altered. Apart from the performance of the clock itself, equally critical is the construction of the clock tree (the clock distribution architecture) inside the DAC. The jitter amount that really counts it’s not only the performance of the clock itself – but the clock which actually enters the dac and is used for conversion – let’s call it the conversion clock. The conversion clock that enters the dac section relies on the clock tree, which is usually not just routing, but in most cases conditioning, altering it’s quality. A poorly designed clock tree can degrade significantly the clock quality entering the d/a section, even if the source clock has great performance.
With these facts in mind, we designed for the Wavedream an advanced clock system called the femtovox. With femtovox in place, one is assured that only extremely small amounts of jitter are present at the dac conversion clock input. It’s unique architecture employs that conversion clock is directly synthesised at the dac input, without any conditioning, giving constant jitter performance at any sample rate. The conversion clock is controlled with 1 ppb precision, while exhibiting about 300 fS of jitter. The smallest jitter figure in the world? No. The smallest jitter figure where actually matters? Probably.
CUSTOM DIGITAL FILTERS
The Wavedream upsamples any material with a fixed rate of 16x. The dac modules will decode the digital stream with a rate of 768Khz, or 705.6Khz, respectively, according to input sample rate. We found this rate to be optimal for analog performance of the dac modules. Behind this simple multiplication factor (16x) lies a huge processing power. The digital filters are made with the combined effort of 58 DSP blocks, resulting into a impressive figure of 15 GMACS of processing power.
The developed filters are unique. We avoided standard Nyquist rate filters as not providing the expected performance for the dac. After lots of mathematical simulations and careful listening tests, we have created a custom Parks-McClellan upsampling filter. There are three variations available on current firmware: linear, minimum and hybrid phase. They are highly optimised filters, offering stunning performance with a large number of taps (5k), and they are different in regard of impulse response. For the linear phase, the ringing energy (Gibb’s overshoot) is equally split before and after impulse. Minimum phase type shows all this energy after impulse, while our special hybrid phase filter has a combined response between linear and minimum, exhibiting very low overshoot before the impulse.
D/A CONVERSION
For the effective D/A conversion stage we developed dedicated dac modules called RD-0 (used in Signature – 27 bit structure) and RD-1 (used in Edition – 26 bit structure). Modules themselves are complex pieces of technology, sharing a discrete sign-magnitude hybrid ladder topology, driven by a complex algorythm which is embedded into their own FPGA. Therefore the dac modules firmware is updatable both performance and feature-wise. Currently RD-0/1 can sustain a maximum sample rate of 6 MHz, which is the industry’s maximum sample rate specified for a audio dac. The output of the dac modules is un-buffered, allowing maximum transparency and natural sound reproduction.
OUTPUT STAGE
Finally, the last stage of the signal path is the analog output stage. It’s contribution to final sound is of extreme importance. Designed from the scratch to work with converter modules RD-0 & RD-1, the output stage is totally discrete and acts as a high-speed buffer. Made entirely with through-hole components (non-smd), we combined j-fet & bipolar devices into a class A design, with a closed-loop output impedance of under 1 ohm and equivalent input noise as low as 1nV, as a perfect match for the converter overall performance.
THE POWER SUPPLY
Naturally we have dedicated sections for digital and analog areas. There are 3 separate transformers, and all power supplies are low noise linear - no switchmode power supplies are used whatsoever. There are a total of 20 linear regulators inside the dac. We dedicated our attention to the dac modules regulators – which are designed from the scratch for low impedance and ultra-low noise.
GALLERY
BLUES
Re: Rockna Wavedream DAC
Unread post #2 by BLUES » Fri Apr 22, 2016 10:08 am
Καλημέρα
Eιμαι ενας από τους λιγους ευτυχεις κατοχους της νεας βερσιον RD-1 single end στην Ελλαδα
Είναι ενας από τους λογους που καταργησα το αναλογικο τμημα και ακουω μονο πια αρχεια hires pcm-flac-dsd with Mac Book pro kai-audionirvana+
Oτι καλυτερο κυκλοφορει εως 20000 ε
morfeas
Contact:
Unread post #3 by morfeas » Fri Apr 22, 2016 12:49 pm
Πραγματικά πρόκειται για εξαιρετική περίπτωση. Απ όσα έχω ακούσει το καλύτερο, με το TotalDAC αρκετά κοντά. Ασχετα απο τιμή.
Unread post #4 by BityaBit » Fri Apr 22, 2016 1:13 pm
Έχοντας και εγώ την τύχη να το ακούσω τολμώ να πώ οτι είναι απο τις συσκευές ψηφιακής αναπαραγωγής που συνδυάζουν δύο ετερόκλητες ιδιότητες. Είναι απολύτως άρτιο ηχητικά αλλα και διαχρονικό σαν απόκτημα. Δύσκολα ψάχνεσαι παραπέρα.
Unread post #5 by Dr Pan K » Fri Apr 22, 2016 1:19 pm
Ανάμεσα στην τριτη και την τετάρτη φωτο για οσους δεν το παρατήρησαν υπάρχουν διαφορές. Η αρχική εκδοση του Wavedream (της οποίας ειμαι κάτοχος) ηταν σχεδιασμένη γυρω απο τις θρυλικές μοντουλες της MSB ενω η νεα γενιά (που εχει ο Γιωργος/ BLUES) εχει in house σχεδιασμένους μετατροπείς. Το receiver παραμένει το ιδιο με τα ιδια custom φιλτρα.
Χωρίς να ειναι στο επίπεδο του αναλογικού μου μπορώ να πω οτι αυτο το DAC με έβγαλε απο μια μεγάλη περίοδο αναζήτησης ψηφιακού front end καθώς οι μέχρι εκείνη την στιγμή δοκιμές με διάφορες άλλες συσκευές δεν είχαν πείσει καθόλου.
Unread post #6 by andreasecon » Fri Apr 22, 2016 1:55 pm
Δεν ήξερα ότι το καινούργιο έχει in house μετατροπείς !! Ενδιαφέρον να το ακούσουμε !
Το παλιό είχε τα Platinum dacs της MSB, οπότε είχα κάποια αίσθηση πως μπορεί να παίζει, αφού για ένα διάστημα ενός χρόνου είχα το Platinum Dac της MSB
Unread post #7 by Dr Pan K » Fri Apr 22, 2016 1:58 pm
Εχει αρκετά διαφορετικό ηχο απο το MSB Platimun ειδικά σε χωροθέτηση και pace, καθώς εχει ανώτερο receiver. Η δεύτερη γενια προφανώς διαφοροποιείτε και παροτι την εχω ακουσει μερικές φορες αυτο δεν εχει γινει με πραγματικά γνώριμο σύστημα οποτε δεν τοποθετούμε στο αν βελτίωσε σε σχέση με την πρώτη.
johnVO
Unread post #8 by johnVO » Fri Apr 22, 2016 11:31 pm
Πολύ καλό dac...το εχω ακούσει στον dr Pan και πράγματι έδειχνε τα "δόντια" του με την πρώτη ευκαιρία!
Ο Ρουμάνος (κατασκευαστής) πάντως, δείχνει να το κατέχει καλά το αντικείμενο...το interface
hydra z και το τροφοδοτικό του (zpm) που έχω την χαρά να έχω, είναι εξαιρετικά!
Unread post #9 by Dr Pan K » Sat Jan 13, 2018 4:36 pm
Ξανανοιγω το νήμα γιατι μετα απο αρκετό καιρό που το συζητάμε καταφέραμε να ακούσουμε το τελευταίο Wavedream (με τις ομοσταυλες μοντουλες) διπλα στο πιο παλιό δικό μου (με τις MSB). H ακρόαση που προέκυψε τελευταία στιγμή ειχε πολύ ενδιαφέρον, εγινε σήμερα το πρωί παρεα με Chris1967 και Angpsi, αργότερα προστέθηκε στην παρέα και ο Gojakla (που ακουσε μονο Garrard).
Το βασικο συμπέρασμα ειναι οτι το τρέχον Rockna Wavedream ειναι αλλα DAC απο το πρώτο. Καποια πράγματα βέβαια εχουν μείνει σταθερά και η υπογραφή τους ειναι η ίδια (φίλτρα, receiver) ενω το σασι εχει πρακτικά μηδενικές διαφορές. Στο θέμα του ήχου ομως ο χαρακτήρας είναι πιο laid back, με μεγαλύτερη έμφαση στις μεσαίες. Overall θα το έλεγα πιο smooth.
Φυσικά ακολούθησε φαγοπότι (κάποιες παραδόσεις δύσκολα αλλάζουν) με σχετική κουβέντα.
Unread post #10 by Dr Pan K » Thu Apr 19, 2018 7:52 pm
Μαθαίνω απο σίγουρη πηγή οτι πρόκειται να ανακοινωθούν νεες μοντουλες για το Wavedream..
