Metaxas Audio Systems
Unread post #1 by Gojakla » Sun Jun 12, 2016 3:43 pm
Official Site
Η Metaxas & Sins Audio Systems ιδρύθηκε το 1981 στην Αυστραλία απο τον Ελληνικής καταγωγής, Κώστα Μεταξά. Σχεδιάζει και κατασκευάζει μια πλήρη γκάμα Hi-End ενισχυτικών (ολοκληρωμένο/pre/power) καθώς και ηλεκτροστατικά ηχεία αντλώντας έμπνευση και γνώση απο την πολυετή εμπειρία του στα studio ηχογραφήσεων.
Αξίζει λοιπόν να ρίξουμε μια γρήγορη ματιά στην εταιρία αλλά και στις πραγματικά μοναδικές δημιουργίες του, των οποίων η αισθητική και κατασκευαστική αρτιότητα θα μπορούσε να είναι θέμα σεμιναρίου.
About Kostas Metaxas
Award winning artist and audio designer, electrical and recording engineer, Magazine Editor/Publisher and a Filmmaker/Broadcast Producer who covers fashion, design, gastronomy and the arts with over 1000 documentary interviews and two awarded feature films (visti http://www.exero.com for more info) to his credit.
Drawn to the shapes and textures of old master painters and sculpture since he was a teenager, about the same time, he was introduced to Hi-End Hi Fi equipment and fell in love with the art of the reproduction of music. To him, art and design is “visual music”. Unable to afford expensive Hi Fi equipment, he taught himself electrical engineering and started producing, which turned into his first business.
Hungry for knowledge about art and design, Metaxas started a magazine so he could interview great artists and designers worldwide, learn from them, and feed his own creativity.
For Metaxas, designing feels euphoric. He enjoys working with materials – metal, glass, ceramic, plastic and subverting technology, like using dental techniques to create jewelry and watches. Both the traditional manufacturing methods and the latest software or their combination work great for him. He thinks of the big picture first, then the details and the best methods to create them.
He strongly believes in balance with a twist, in the fight between chaos and order, with a little intrigue thrown in. A bit of theatre, a bit of utility – there needs to be substance, it should be useful, it should also invoke experimenting and playfulness with infinite possibilities.
Some advice from Metaxas to young designers:
“Research the breathtaking work of others, and wait until your idea exceeds that standard, otherwise it has no reason to exist. Do your absolute best. If you’re not motivated, don’t do it. Give life to an object which never existed before."
OVERVIEW
The only way to design state-of-the-art audio equipment is to have some experience with the finest available recording equipment AND playback equipment.
Our systems have been designed using a variety of state-of -the-art phono playback equipment and custom-made Tape Recorders including the battery operated Stellavox SM-8 using 1/4" tape at 30 ips and Stellavox TD-9 using 1/2" tape at 30 ips using Bruel & Kjaer 4135 and Neumann TLM50 & M150 microphones.
Our impressive 'listening laboratory' is rivalled by our comprehensive testing facilities where each amplifier is individually calibrated and tested by an experienced technician before being subjected to extensive listening tests over a one week burn-in period.
Painstaking selection and matching by hand of all the components
Bespoke hand-made production by one technician from start to finish.
Millitary-spec grade components. CNC machined & laser etched panels.
Over 300 "in-house" Master Tape concert recordings as our ABSOLUTE REFERENCE.
PRODUCT GALLERY
Re: Metaxas Audio Systems
Unread post #2 by Dr Pan K » Mon Jun 13, 2016 8:33 pm
Απο τους πιο ιδιαίτερους σχεδιαστές στον χωρο του high end, o Μεταξάς ηταν ηδη ενεργός απο τις αρχες της δεκαετίας του 80 οταν ξεκίνησε να σχεδιάζει ενισχυτές με πολυ χαμηλό θορυβο λειτουργίας για στουντιο, και πιο ειδικα για τις ηχογραφήσεις του. Μετα απο καποια χρονια σχετικης αποχης απο τα δρωμενα (σχετικης γιατι συνεχίζει να ηχογραφεί και να κανει παραγωγές για την τηλεόραση) επέστρεψε με τα κλασσικά του μοντελα, αναθεωρημένα σε κρισιμα σημεία (custom μετασχηματιστές, ποιοτικά υλικά οπως αντιστάσεις Kiwame) και το σημαντικοτερο, νεα σασι με πραγματικά πρωτοποριακή σχεδίαση.
Στην πρόσφατη συνάντηση μας εδω στην Αθήνα μου εξηγησε πως το σασι αυτο, περαν του αισθητικού μερους, ειναι απερίγραπτα άκαμπτο καθως αποτελείτε απο ενα μασίφ billet αλουμινίου και απορροφά οτι κραδασμούς δημιουργεί ο μετασχηματιστής και το κύκλωμα προσφέροντας ουσιαστικά στην αναπαραγωγή.
Στο Μόναχο το δωμάτιο του Μεταξα με τα Γαλλικά ηχεια Apertura ηταν ενα από τα πιο εντυπωσιακά, ειδικα αν αναλογιστεί κανείς οτι τα ηχεία ηταν σχετικά χαμηλής τιμής, διδρομα. Υπαρχει λοιπον μεγαλο ενδιαφέρον να τα ξαναακουσουμε εδω στην Αθηνα ;-)
Unread post #3 by Geopolitis » Mon Jun 13, 2016 11:26 pm
Πολύ ενδιαφέρον θα είχε κάποια ακρόαση με αυτά τα αριστουργήματα... Περιμένουμε νέα....
Unread post #4 by Dr Pan K » Tue Aug 02, 2016 8:21 pm
Geopolitis wrote:Πολύ ενδιαφέρον θα είχε κάποια ακρόαση με αυτά τα αριστουργήματα... Περιμένουμε νέα....
Μάλλον έκλεισε! Μιλησα με τον Κωστα (Μεταξα) και αν ολα πανε καλα θα έχουμε εναν ολοκληρωμένο για ακρόαση αποκλειστικά για τα μελη του audiohub.gr μεσα στον Αύγουστο. Details to follow..
Unread post #5 by Gojakla » Sat Aug 20, 2016 12:41 am
IKARUS has landed.
Unread post #6 by andreasecon » Sat Aug 20, 2016 10:31 am
συνδεθηκε ??
Unread post #7 by Dr Pan K » Sat Aug 20, 2016 10:47 am
andreasecon wrote:συνδεθηκε ??
Και παίζει σχεδόν ασταμάτητα από εχθές..
Unread post #8 by andreasecon » Sat Aug 20, 2016 10:51 am
πρώτες εντυπώσεις ?
Unread post #9 by Dr Pan K » Sat Aug 20, 2016 11:11 am
Σκοτώνει..
Unread post #10 by Gojakla » Sat Aug 20, 2016 11:17 am
If looks can kill, then this is a hitman...
[afro]
Return to “Ενισχυτές”
