Schiit Audio line of DACs
Unread post #1 by Gojakla » Wed Jun 29, 2016 7:06 pm
Official Site
FULLA
USB DONGLE DAC/AMP
"That tiny thing is a combined DAC and headphone amp? For $79? You’re Fulla Schiit!” you might be
saying. And you know what, you’re right. That’s Fulla, and it’s not only a combined DAC and
headphone amp, it’s also the least expensive quality dongle-DAC/amp on the market, with a knob
for volume control—connected to a real live analog volume pot, not a volume control chip.
MODI 2
COMPLETE, AFFORDABLE DAC FAMILY
Modi is a complete family of affordable DACs for virtually any need. Whether you want better sound
from your computer, your tablet, your CD player, or many other sources, the Modi family has a
model that will fit your needs.
BIFROST
MULTIBIT OR DELTA-SIGMA DAC
Bifrost is the DAC that changed the game in affordable digital audio—bringing full upgradability to
the most inexpensive platform in the world, and introducing concepts like bit-perfect clock
management and modular USB architecture. Now, Bifrost changes the game once again with the all
new Bifrost and Bifrost Multibit.
GUNGNIR
MULTIBIT OR DELTA-SIGMA BALANCED DAC
Multibit or delta-sigma? Yes. With Gungnir, you have the flexibility to choose between affordable
delta-sigma performance, or Schiit’s own proprietary multibit architecture with closed-form digital
filter. Both versions offer excellent performance for a moderate price—as well as the comfort of
completely upgradable, modular design.
YGGDRASIL
MULTIBIT DAC WITH CLOSED-FORM FILTER
Forget everything you know about DACs. Yggdrasil is the world’s only closed-form multibit DAC,
delivering 21 bits of resolution with no guessing anywhere in the digital or analog path. We’ve
thrown out delta-sigma D/As and traditional digital filters to preserve the original samples all the
way through from input to output.
Re: Schiit Audio Yggdrasil
Unread post #2 by Geopolitis » Wed Jun 29, 2016 8:24 pm
Ολοι λενε τα καλυτερα για το Yggdrasil. Λενε μάλιστα οτι σε συνδυασμο με ενα Audiobyte Hydra η ενα Mutec MC-3 σαν interface χτυπάει πολυ πολυ ακριβότερα Dac. Είδωμεν....
Unread post #3 by Dr Pan K » Sat Jul 09, 2016 12:32 pm
Geopolitis wrote:Ολοι λενε τα καλυτερα για το Yggdrasil. Λενε μάλιστα οτι σε συνδυασμο με ενα Audiobyte Hydra η ενα Mutec MC-3 σαν interface χτυπάει πολυ πολυ ακριβότερα Dac. Είδωμεν....
Όχι όλοι. Όταν το πρωτοδοκιμασε ο Σκοτ (κατόπιν δικής μου προτροπης) δεν ξετρελαθηκε. Μου είχε πει μάλιστα ότι το exogal comet ήταν στην ίδια κατηγορία τιμής καλύτερο σε ροή.
Τελικά μετά από κάποιους μήνες ήρθε ένα εδώ Αθήνα και καταφέραμε να το ακούσουμε δύο φορές, στο σπίτι του ιδιοκτήτη με reference ακουστικά αλλά και στο δικό μου, επάνω στο κυρίως σύστημα.
Κακό δεν το λες αλλά καμία σχέση με το giant killer που κάποιοι επιτηδευμενα το παρουσιάζουν. Βασικό πρόβλημα μια σκληράδα στις μεσαιοψηλες που προσωπικά θεωρώ deal breaker. Στα μισά χρήματα το Teac 503 με κλειστά μάτια.
Modi 2 Multibit
Unread post #4 by Dr Pan K » Wed Jul 27, 2016 6:13 pm
Νεο και πολύ ενδιαφέρον ειναι το Modi 2 Multibit, το πιο affordable επώνυμο ladder DAC αυτη την στιγμή στην αγορά. Στα $250 συνήθως το μονο που μπορούμε να βρούμε ειναι κινέζικες κατασκευές (dac απο τα Lidl θα έλεγα).. Αν ειχα προλάβει θα έπαιρνα ενα για το εξοχικό
Modi Multibit is the most affordable multibit DAC with a modern architecture—from any manufacturer, from any country in the world. Featuring Schiit’s unique closed-form digital filter, and using the same Analog Devices AD5547 multibit DAC as Bifrost, Modi Multibit smashes the high-price barrier in multibit DACs.
Re: Schiit Audio line of DACs
Unread post #5 by Gojakla » Wed Jul 27, 2016 7:06 pm
Πολύ καλοδεχούμενο το μικρό multibit.
Παρατηρώ επίσης ότι δεν έχουν πλέον στην product list τους το Loki, το DSD -only- DAC τους.
Και μια σκέψη μου... μήπως πάνε και για κατάργηση των delta-sigma τώρα που τα "γυρίσανε" όλα και σε multibit?
Unread post #6 by BityaBit » Wed Jul 27, 2016 10:50 pm
Γενικά η όλη μόδα με το dsd έχει αρχίσει να ξεφουσκώνει στις πραγματικές της διαστάσεις σαν φαινόμενο οπότε η ύπαρξη ντάκ που να υποστηρίζει dsd και μάλιστα αποκλειστικά πόσο μάλλον σε χαμηλά βαλάντια δεν ειναι και ότι πιό εμπορικό.. Φυσικά πάντα θα υπάρχουν οι audiophiles που θα σκίζουν τα ρούχα τους για την υπεροχή του DSD όμως καλώς ή κακώς οι φωνές τους έχουν την ένταση του μεγέθους του καταλόγου της διαθέσιμης μουσικής σε αυτό το format.. Και δεν εννοώ μόνο της κλασσικής..
Kαι για να επιστρέψω στο θέμα του νήματος. Ώραία και καλά τα schiit, ειδικά τα φτηνούλια έχουν κάποιο ιδιαίτερο appeal και θα πουλούσαν αρκετά αν υπήρχε dealer στην Ελλάδα που θα τα προωθούσε σωστά... Ερώτηση. Επιμένει η schiit στην πολιτική απευθείας αγοράς απο αυτούς; (με τα τελωνεία και ότι αυτό συνεπάγεται για τον υποψήφιο αγοραστή μιας και Made in Usa..)
Unread post #7 by Gojakla » Thu Jul 28, 2016 1:20 am
Υπαρχει εμπορος για ολη την Ευρωπη Πετρο, χωρις τελωνεια και προβληματα.
Δεν ειναι η ιδια η εταιρια, μην σας μπερδεψει το url. Για μεταπωλητη προκειται ο οποιος βρηκε ελευθερο το url και το εκλεισε.
Εδω.
Jotunheim headamp and DAC
Unread post #8 by Dr Pan K » Mon Aug 29, 2016 8:08 pm
Ενισχυτής ακουστικων και προενισχυτής με δυνατότητα τοποθέτησης στο εσωτερικό μοντουλας για ΜΜ phono stage ή DAC βασισμένο στο ΑΚΜ 4490. Η μοντουλα αλλάζει σε περίπτωση που η Schiit κυκλοφορήσει κατι νεότερο. Το μονο μου παραπονο, γιατι να μην προσφερουν δυνατοτητα για 2 μοντουλες ταυτοχρονα (δλδ και phono και DAC) αφου πολλοι χρησιμοποιουν και τα 2..
Στα $399 μονο ο ενισχυτής, στα 499 με μια απο τις 2 προσθήκες.
A one-box, do-all, no-excuses desktop system that’s ready for any headphone and powered monitor on the planet. Done. At the same time, why don’t we make the conventional, non-upgradable DAC/amp idea seem, well, a bit outdated? Done and done. Welcome to Jotunheim
Amplifier:
Frequency Response: 20Hz-20Khz, -0.1db, 2Hz-700KHz, -3dB
Balanced Headphone Output:
Maximum Power, 16 ohms: 7500mW
Maximum Power, 32 ohms: 5000mW
Maximum Power, 50 ohms: 3000mW
Maximum Power, 300 ohms: 900mW
Maximum Power, 600 ohms: 500mW
Single-Ended Headphone Output:
Maximum Power, 16 ohms: 2500mW
Maximum Power, 32 ohms: 1500mW
Maximum Power, 50 ohms: 800mW
Maximum Power, 300 ohms: 350mW
Maximum Power, 600 ohms: 175mW
THD: <0.001%, 20Hz-20KHz, at 1V RMS
IMD: <0.0015%, CCIR
SNR: >109db, A-weighted, referenced to 1V RMS
Crosstalk: >-70dB, 20 Hz-20KHz
Output Impedance: Less than 0.1 ohms, balanced or SE, at both gain settings
Gain: 2 (6dB) or 8 (14dB), selectable via front switch
Inputs: Balanced XLR and Single-Ended RCA, selectable via front switch
Outputs: Balanced headphone (4-pin XLR), single-ended headphone (1/4” TRS), balanced line preamp, single-ended line preamp
Optional Inputs: AK4490 Balanced USB DAC or Passive MM Phono
Gain Stage: Proprietary Schiit Pivot Point™ fully discrete differential current-feedback topology
Power Supply: One 48VA transformer with 6 stages of discrete or integrated regulation and over 70,000uF total filter capacitance
Optional Dual AK4490 DAC:
USB Input Receiver: C-Media CM6631A
D/A Conversion IC: AK4490 x 2
Analog Output: fully differential, passive summing and passive filtering
Frequency Response: 20Hz-20KHz, +/-0.1dB, 2-100kHz, -3dB
Maximum Output: 2.0V RMS
THD: <0.0015%, 20Hz-20KHz, full scale
IMD: <0.002%, CCIR
S/N: >106dB, referenced to 2V RMS, unweighted
Optional Passive Filtered Phono Stage:
Gain: 42dB
THD: <0.01%, A-weighted, at 1V RMS
SNR: >80dB, A-weighted, inputs shorted
Crosstalk: -70dB, 20-20kHz
Sensitivity: 2.3mV for 400mV output
Overload Margin: >20dB
Input Impedance: 47k ohms
Input Capacitance: 100pf
RIAA Accuracy: +/- 0.25dB, 20-20kHz
Topology: Fully passive RIAA network with AD8599 gain stages and PET film capacitors throughout, DC coupled, with DC servo
Power Consumption: 25W typical
Size: 9” x 6” x 2”
Weight: 6 lbs
http://schiit.com/products/jotunheim
Unread post #9 by DomieMic65 » Wed Aug 31, 2016 11:31 am
το μόνο θέμα που βλέπω με τα DACs της Shiit είναι ότι χρησιμοποιούν cmedia usb receivers!
θεωρώ το xmos πιο "ασφαλής" λύση για συμβατότητα με λειτουργικά και audio files πάσης φύσεως!!!
Unread post #10 by Dr Pan K » Wed Aug 31, 2016 1:03 pm
DomieMic65 wrote:το μόνο θέμα που βλέπω με τα DACs της Shiit είναι ότι χρησιμοποιούν cmedia usb receivers!
Συμφωνώ απόλυτα. Το Cmedia είναι το πιο προβληματικό receiver της αγοράς.
