Munich High End 2022
Unread post #1 by Dr Pan K » Wed May 11, 2022 11:30 am
Munich 2022.jpg (838.5 KiB) Viewed 8890 times
19 με 22 Μαιου ειναι προγραμματισμένη η εκθεση ηχοσυστηματων και ακουστικών του Μοναχου. Ειναι η πρώτη που γινετε μετα τον κορωνοιο και δυστυχως τα πραγματα δεν εχουν εξομαλυνθεί ακομα. Δεν θα ανεβω τελικα αλλα απο εδω ξερω πως θα εχουμε τον Ανδρεα με τον Γιωργο ενω απο το Part Time Audiophile θα ειναι επανω ο Marc, οποτε θα εχουμε αρκετο φωτογραφικο υλικο και εντυπωσεις.
Re: Munich High End 2022
Unread post #2 by Dr Pan K » Wed May 11, 2022 11:40 am
Εχθες εφτασε το παρακατω μυνημα απο τον Jorn της Tidal / Vimberg
Dear Friends & Partners,
unfortunately we needed to make a tough decision yesterday: we will not exhibit in Munich next week. The reason is that the biggest part of our employees (incl. my wife Miriam) have been tested positive with Covid like an avalanche these last days and needing to be in quarantine.
Everything has been planned with the whole team around finishing last steps for the products for the show, and of course all the logistic steps being involved such as packing, transport to Munich and installation etc.. But this situation now makes it simply impossible for us to participate the High End in Munich next week, at least impossible to present it as it has to be and we do not wanted to compromise with an emergency solution and present things only half way, this is not what wo do and who we are.
A bitter pill for us, especially since we have been looking forward to present the new successor of the TIDAL Piano (after 8 years), a totally new electronic masterpiece, the TIDAL Contros, and even planned to show and demo the TIDAL for Bugatti Royale to partners and friends, in two set up’s side by side with a new room concept. Attached you could see how it was planned and prepared (plus additional fine tuning, lighting, rope-dividers and many details not see in it).
Οποτε Tidal/ Vimberg/ Bugatti δεν θα παιξουν, κριμα γιατι ειχαν πολλα να μας παρουσιασουν.
Unread post #3 by Dr Pan K » Wed May 11, 2022 11:44 am
Υπηρξε και μια ασυνεννοησία απο μεριας της διοργανωσης οταν τους προηγουμενους 2 μηνες εστελναν μηνυματα που εξηγουσαν τις απαιτήσεις για 1/ατομο ανα δωματιο, με μασκες κτλ. Πολλοι επαγγελματιες δεν το βρηκαν λογικο να εκθεσουν υπο αυτες τις συνθηκες, μετα ομως τα μετρα άρθηκαν οποτε οποιος παει επανω μαλλον θα γυρισει με κορωνοιο..
Unread post #4 by Dr Pan K » Wed May 18, 2022 1:14 pm
Ενα απο τα συστηματα που θα ηθελα να ακουσω, ηχεια του Rainer (Kaiser) με ενισχυτες και πηγες Ypsilon. Ειναι και το σετ ενισχυτικων που θα ηθελα να δοκιμασω με τα Vimberg Tonda D, υποψιαζομαι οτι θα δενουν εξαιρετικα
Unread post #5 by Dr Pan K » Thu May 19, 2022 7:28 pm
Ξεκιναμε την καλυψη μας με το booth της Lab12 οπου παρουσιαστηκε ο νεος τελικος της εταιριας με ονομα Irama. Χρησιμοποιει τις ολοκαινουργιες KT 170 της Tung Sol και υποσχεται να οδηγησει λιγο πολυ τα παντα..
Επισης πολυ ενδιαφερουσα η συνεργασια της Lab12 με την Signal Projects στον χωρο των καλωδιων.
Unread post #6 by Dr Pan K » Thu May 19, 2022 8:26 pm
Συστημα της YG με την Burmester, streamer της Aurender. Αυτα τα ηχεια σε αυτο το δωματιο δυσκολα θα αποδωσουν, ειναι απλα μικρα για τα τετραγωνικα.
YG Burmester front.jpg (760.38 KiB) Viewed 8723 times
YG Burmester side.jpg (690.5 KiB) Viewed 8723 times
Unread post #7 by Dr Pan K » Thu May 19, 2022 9:48 pm
Goebel - TLA - WADAX - Kronos
Αυτό πρέπει να είναι ανάμεσα στα καλύτερα συστήματα της έκθεσης. O Oiver έφερε λίγο πιο μικρό ηχείο αλλά με νέα subwoofer, μαζί με τα ενισχυτικά της TLA που είχα πέρυσι στο σπίτι και από ογγες το καινούργιο κορυφαίο πικάπ της Kronos και το κορυφαίο ψηφιακό combo της Wadax.
Unread post #8 by Dr Pan K » Fri May 20, 2022 12:15 am
Ένα ιδιαίτερο ηχείο από μια εταιρία που ποτέ δεν συμπάθησα, το Concept 50 της Monitor Audio.
Unread post #9 by Dr Pan K » Wed Jun 01, 2022 11:49 am
Στο Part Time Audiophile εχει σχεδον ολοκληρωθει η καλυψη απο τον Marc..
https://parttimeaudiophile.com/category ... nich-2022/
Unread post #10 by dapost » Sat Jun 04, 2022 3:36 pm
Ακούστε το podcast για εντυπώσεις από το best of show. Αν δεν καταλάβετε σε ποιον dr. αναφέρεται, δεν είναι άλλος από τον γνωστό, εκ Ζακυνθου ορμώμενο…
https://audio-head.com/highlights-and-b ... -end-2022/
