Orpheus Audio
Audiohub Mod Team
Contact:
Orpheus Audio
Unread post #1 by Audiohub Mod Team » Tue Jul 26, 2016 4:35 pm
Official Site
Orpheus Audio was founded in 1990 by Assimakis Reboutsikas and Alexander Tsakiris,
with the mission of offering the finest hi-fi audio and video equipment from the world's leading
manufacturers, while providing an unparalleled level of customer service and technical support.
Since then the selection and inventory has grown to include a wider range of products from
a greater selection of top brands, including an expansion of their inventory to include home
entertainment equipment.
Orpheus is proud to represent the following manufacturers:
ACAPELLA / AMAZON / A.S.R. / AUDIO AGILE / AUDIO MAGIC PRODUCTION / AUDIO PHYSIC /
BURMESTER / CineVERSUM powered by BARCO / CLEARAUDIO / COCKTAIL AUDIO / COPLAND /
DENSEN / DEVIALET / DREAMVISION / DUEVEL / DYNAVOX / DVDO / EINSTEIN / ERGO /
HEIL - A.M.T. / JC. VERDIER. /ISOTEK / D. KLIMO / K.R. AUDIO / MICROMEGA / H.H. MORCH / NAIM /
NORDOST / ORTOFON / PATHOS / PLUTO AUDIO / PRIMARE / PROJECT AUDIO / SCREEN RESEARCH /
S.D. ACOUSTICS / SOLID TECH / SYSTEM AUDIO / SYMPHONIC LINE / SUMIKO / T.A.C. / TRIANGLE /
Tri-PLANAR / UNISON RESEARCH - UNICO / VINCENT
Contact:
Κεντρικό - Αθήνα
Orpheus Audio
Στουρνάρη 46, 104 33
Τηλέφωνο: +30 (210) 522 1524 - (210) 522 5569
Φαξ: +30 (210) 522 2962
sales@orpheusaudio.gr
http://www.orpheusaudio.gr
http://www.orpheusaudiostock.gr
Πετρούπολη
Orpheus Audio
Παλαιολόγου Κ. 6
Τηλέφωνο: +30 (210) 506 6320
Φαξ: +30 (210) 506 6320
info@orpheusaudio2.gr
http://www.orpheusaudio2.gr
Θεσσαλονίκη
Orpheus Audio
Βούλγαρη 73
Τηλέφωνο: +30 (2310) 818 352
info@orpheusaudio.gr
Λάρισα
Orpheus Audio
31ης Αυγούστου 67
Τηλέφωνο: +30 (2410) 552 802
info@orpheusaudio.com.gr
http://www.orpheusaudio.com.gr
Νέο Ηράκλειο - Αθήνα
Orpheus Audio - Haus Musik
Κολοκοτρώνη 2Γ
Νέο Ηράκλειο, Αττική
Τηλέφωνο: +30 (210) 2848893
Φαξ: +30 (210) 2848950
info@orpheusaudio-hausmusik.gr
http://www.orpheusaudio-hausmusik.gr
Κόρινθος
Orpheus Audio
Αράτου 50
Τηλέφωνο: +30 (27410) 21033
Φαξ: +30 (27410) 21033
orpheus2@otenet.gr
Πάτρα
Orpheus Audio
Κορίνθου 67
Τηλέφωνο: +30 (2610) 434542
info@hi-fi.gr
http://www.hi-fi.gr
Δάφνη
Studio HiFi - Diapason
Χρήστος Κοψιάς
Ηλιουπόλεως 101
Τηλέφωνο: +30 (210) 976 5076
http://www.studiohi-fi.gr
info@studiohi-fi.gr
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Pro Ject Head Box RS + Power Box Uni1 @ High Fidelity Poland
Unread post #2 by Audiohub Mod Team » Fri Aug 05, 2016 9:41 pm
Pro-Ject HEAD BOX RS + POWER BOX RS UNI 1
project box.jpg (94.54 KiB) Viewed 15263 times
It is a universal device. It does not emphasize the drawbacks of the source and does not discriminate headphones. However, with time, having tested different headphone models and designs, I have come to the conclusion that Austrian headphones – Sennheiser and AKG suit the amp best.
http://highfidelity.pl/@main-681&lang=en
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Clearaudio Innovation Basic
Unread post #3 by Audiohub Mod Team » Thu Aug 11, 2016 1:31 pm
CONSTRUCTION DETAILS
Resonance optimised chassis's shape, belt driven with optical, full automatic speed control
SPEED RANGES 33 ⅓ rpm, 45 rpm, 78 rpm
DRIVE UNIT Decoupled DC motor in a massive metal-housing.
This turntable can be connected to 230 V or 110 V AC (50 Hz and 60 Hz).
BEARING
Inverted and polished ceramic bearing shaft, polished sinter bronze insert, including patented CMB bearing technology
PLATTER
VA stainless steel sub-platter, Delrin or acrylic GS-PMMA platter, precision CNC machined surface
SPEED ACCURACY (MEASURED) less than ± 0.05 %
DEVIANCE OF THE SET VALUE ± 0.01 %
TOTAL WEIGHT Approx. 23 kg (without tonearm and power supply)
DIMENSIONS (W/D/H in inches) Approx. 16.85 x 14.96 x 8.82
DIMENSIONS (W/D/H in mm) Approx. 428 x 380 x 215
WARRANTY 5 years
Price in Greece Approx. 4000 euros
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Pro Ject The Classic Turntable wins EISA award 2016
Unread post #4 by Audiohub Mod Team » Thu Aug 25, 2016 5:08 pm
Pro-Ject The Classic
Released to celebrate the company’s 25th anniversary, the timeless, traditional look of The Classic hides plenty of up-to-date engineering aimed at making this two-speed turntable as plug-and-play as possible. The main chassis plate rests inside an elegant wooden frame on six elastomer balls that provide some measure of isolation, while the inner circumference of the precisely-machined 2.1kg aluminium platter is also damped with a similar material. The deck is pre-fitted with a hybrid carbon/alloy tonearm that offers the potential to unleash even greater potential with better pick-ups, and rounds off one of the most stylish, snappy-sounding and user-friendly vinyl sources around. A new classic is born!
https://www.eisa.eu/awards/hi-fi/12/eur ... html#award
Διαχειριστική ομάδα
Audiohub Mod Team
Contact:
Pro-Ject RPM-9 CARBON review @ High Fidelity Pl
Unread post #5 by Audiohub Mod Team » Wed Aug 31, 2016 9:53 pm
carbon 9.jpg (145.6 KiB) Viewed 15213 times
It has a full, deep sound and high resolution. Bass is well extended and slightly emphasized, and the treble is nicely extended as well. The background noise as well as cracks&pops are barely audible. This is a very serious turntable.
http://highfidelity.pl/@main-687&lang=en
Διαχειριστική ομάδα
ORPHEUS AUDIO
Contact:
DCS ONLY THE MUSIC
Unread post #6 by ORPHEUS AUDIO » Fri Sep 16, 2016 12:00 pm
Φίλοι και φίλες του Αudiohub , με χαρά σας ανακοινώνουμε τη νέα μας αποκλειστική Αντιπροσωπεία DCS μια απο τις ποιο ποιοτiκες εταιριες που κατασκευαζει συστηματα digital-to-analogue conversion
DCS products are high end – a combination of world-class craftsmanship and leading-edge technology – but those who invest in dCS have the chance to experience that unique, spine-tingling moment when the world stops and there is… only the music.
http://www.dcsltd.co.uk/
ORPHEUS AUDIO
Contact:
Re: Orpheus Audio
Unread post #7 by ORPHEUS AUDIO » Sat Sep 17, 2016 12:03 pm
Τα βινύλια βρήκαν τη νέα στέγη τους δίπλα στα κλασσικά μοντέλα αυτοκινήτου και υπόσχονται μια ανεπανάληπτη γιορτή για όλους τους vinyl maniacs, αλλά και τους εκθέτες, χωρίς περιορισμούς, πρωτοπορώντας και πάλι!
Το Vinyl is Back, η κορυφαία εκδήλωση για το βινύλιο, υπόσχεται για 8η φορά happenings και εκπλήξεις στο Ελληνικό Μουσείο Αυτοκινήτου την Παρασκευή 23, το Σάββατο 24 και τηνΚυριακή 25 Σεπτεμβρίου 2016.
Η είσοδος είναι ελεύθερη και η θέα της Αθήνας από τον 4ο όροφο εκπληκτική!
Audiohub Mod Team
Contact:
Re: Orpheus Audio
Unread post #8 by Audiohub Mod Team » Fri Oct 07, 2016 8:14 pm
Διαχειριστική ομάδα
ORPHEUS AUDIO
Contact:
Re: DCS ONLY THE MUSIC
Unread post #9 by ORPHEUS AUDIO » Mon Oct 17, 2016 12:53 pm
ORPHEUS AUDIO wrote:Φίλοι και φίλες του Αudiohub , με χαρά σας ανακοινώνουμε τη νέα μας αποκλειστική Αντιπροσωπεία DCS μια απο τις ποιο ποιοτiκες εταιριες που κατασκευαζει συστηματα digital-to-analogue conversion
ORPHEUS AUDIO
Contact:
Re: Orpheus Audio
Unread post #10 by ORPHEUS AUDIO » Wed Oct 19, 2016 10:39 am
Με χαρα σας ανακοινωνουμε την αφιξη της καινουργιας μας εταιριας VTL . Στην εκθεση του Hχου και Εικονας 26 27 νοεμβριου θα μπορεσετε να δειτε και να ακουσετε τα προιοντα της!! http://vtl.com/
About VTL
.. a world leader in high-powered, high performance tube equipment for music reproduction in the home. Using modern technology, VTL delivers dynamic, musical sounding amplifiers & preamplifiers that are exceptionally user-friendly.
All VTL products are manufactured in our own facility in Chino, CA and are designed for musical sound quality. With a proven track record of over 20 years in the home audio business, VTL has a solid heritage of delivering reliable, timeless components that you can enjoy for generations to come.
Return to “Αντιπρόσωποι & Κατασκευαστές”
