Magico
Magico
Unread post #1 by Gojakla » Fri Aug 05, 2016 5:20 pm
Official Site
MAGICO was created over a decade ago for the sole purpose of leading a no-holds-barred assault on
what is possible in contemporary loudspeaker design.
Inspired by the unique vision of industrial designer Alon Wolf, every MAGICO speaker is designed
against the standard of perfect audio reproduction - live music.
At MAGICO, we strive to lead in the creation, development, and manufacture of the most advanced
loudspeaker systems in the world.
MAGICO uses state-of-the-art computer graphic modeling, precision real-time analysis, and the
most sophisticated CAD acoustic simulators and emulators available today.
Re: Magico
Unread post #2 by Gojakla » Fri Aug 05, 2016 5:24 pm
Q7 Mk II
In the constant pursuit of perfection, the new Q7 Mk II represents Magico’s leading edge
engineering capabilities which allows us to surpass the superb performance of the original Q7.
The design and art form factor of the Q7 remains intact however the scientific research applied to
the new Q7 Mk II brings forth radically new and cutting-edge technologies that are found in a newly
designed tweeter and midrange driver along with state-of-the-art crossover componentry.
Q5
Standing on the shoulders of past successes to create a new standard of technical excellence.
Can there really be an answer to the question “is there such a thing as a truly better loudspeaker?”
At Magico, our energy is gathered out of the belief that the answer is a definitive “yes”.
Q3
The latest addition to the family, the Q3 flaunts its pedigree inside and out.
The Q3 achieves a 90dB efficiency rating, setting a new standard for moderately-sized, full-range
loudspeaker performance, by incorporating the Q design platform for ideally engineered
loudspeaker enclosures with a new and remarkably efficient 7” Nano-Tec® driver.
Q1
Replacing an iconic and revolutionary product is as much an exercise in understanding human
emotion as it is in engineering.
For any new generation of products, in addition to being compared to its predecessor by actual
performance, there is a need to contend with the intense feelings of witnessing the introduction of
a loudspeaker so far ahead of its time that it redefines a genre.
Re: Magico
Unread post #3 by Gojakla » Fri Aug 05, 2016 6:13 pm
S7
Towering over other S-Series models, the S7 is a full range, 3-way loudspeaker that incorporates
new tweeter, midrange and bass driver designs which are derived from the engineering triumphs in
the M-Pro loudspeaker.
The S7 houses three 10-inch bass drivers that have extremely powerful magnets and ultra-stiff
aluminum cones which are capable of producing deep powerful bass frequencies with speed and
accuracy. The excursion rate of the voice coil is measured at 15-mm linear movement and produces
clean and undistorted sound pressure levels up to 120dB @ 50Hz / 1-meter.
S5 MKII
The new S5 Mk II silhouettes its predecessor however that is where any similarity ends. Significant
performance enhancements are realized with the implementation of new and advanced transducer
and enclosure designs which have been distilled from the extensive engineering research devoted
to the S7.
S3
The S3 is a full-range, floorstanding loudspeaker that offers cutting-edge technology and
unparalleled performance at its price.
According to Magico CEO and chief designer Alon Wolf, "By drawing from our technological well and
in-house manufacturing capabilities, we are now able to deliver a remarkable value proposition in
the S3, one which will become a new benchmark in its category."
S1 MKII
At first glance the S1 Mk II may appear similar to its predecessor. However, it is entirely redesigned,
and incorporates distilled elements of our most recent and ground breaking engineering
accomplishments. The design platform of the S1 Mk II features core technologies that are unique to
Magico –an all aluminum enclosure, and proprietary driver design that outperforms any other
driver available today.
Re: Magico
Unread post #4 by Dr Pan K » Fri Aug 05, 2016 9:16 pm
Τεχνολογικά μιλώντας αναμεσα στα κορυφαία ηχεία αυτη την στιγμή. Το απόλυτο σε αδράνεια καμπίνας, μονάδες "σχεδιασμένες" απο την εταιρεία, κτλ. Υπάρχουν ομως δυο θεματακια, το ένα ειναι η τιμή και το αλλο η μουσική.
Η τιμή ειναι σχεδόν αστεία, για ενα σοβαρό ηχειο της Magico ο δυνητικός αγοραστής καλειται να πληρώσει απο 100 εως 200+ Κ, στα ιδια χρηματα πολλοί high end κατασκευαστές προσφέρουν πληρέστερα (αν αν θελετε μεγαλύτερα) προϊόντα. Στην τελευταία αναβάθμιση της μεγαλης σειράς μπηκαν επανω βελτιωμένα mid range και tweeter. Οποιος ηθελε να αναβαθμισει απο την mk I επρεπε να καταβάλει για 4 μονάδες το γελοίο ποσο των $44.000, παραπάνω δηλαδη απο την ναυαρχίδα της B&W 800D3. Γελοίο το λιγότερο..
Μετά τίθεται το θεμα του ηχου, ή καλύτερα της μουσικης. Τεχνικα οι κατασκευές ειναι αρτειοτατες αλλα περαν των payola reviews δύσκολα θα βρείτε audiophiles που τα εχουν ακουσει καποιες φορες και παθιαστικαν απο το ακουσμα. Αυτο που λείπει ειναι ο συναισθηματικός δεσμός με την μουσική, το ηχειο απογοητεύει καθώς ειναι ανίκανο να μαγευσει τον ακροατή.
Σε παλαιότερη αναφορά μου στο Part Time Audiophile ειχα γράψει
For being a half a million dollar room, the sound, while not bad per se, was just not what I expected for this category of equipment. It is not a matter of “playing right”; systems of this caliber have to do everything by the book and even more so. It actually comes down to sensations, and while I think the Q7 Mk2 are a clear step forward for Magico, there’s still some room to grow.
https://parttimeaudiophile.com/2015/06/ ... 15-magico/
ChrisM
Re: Magico
Unread post #5 by ChrisM » Fri Aug 05, 2016 10:22 pm
Το s5 & s7 κοστίζουν αρκετά λιγότερο από το ποσό που αναφέρεις. Φαντάζομαι λες για τα μεγάλα Q? Πάντως όσο αφορά τον σχεδιασμό της καμπίνας και την αδράνεια αυτής....έχω μείνει παραπάνω απο αφωνος.
Μία ερώτηση μόνο:
Στην παρουσίαση σου high end munich show είχες αναφέρει ότι στο set up με τα magico υπήρχε ένα cd player που θα σε δελεαζε να το αγορασεις. Πως γίνεται σε ένα set up με ηχεία που τους προσδίδεις έλλειψη μουσικοτητας να είχες κρίνει ένα cd player και μάλιστα με τόσο κολακευτικά σχόλια. Κάπου σε έχασα....
Re: Magico
Unread post #6 by Dr Pan K » Fri Aug 05, 2016 11:03 pm
Ενδιαφέρουσα παρατήρηση. O Alon Wolf εχει χρησιμοποιήσει στο παρελθόν και αλλη πηγή που πολυ θα ήθελα να εχω, το κατα πολλούς καλύτερο DAC που εχει σχεδιαστεί ποτε (Pacific Microsonics). Και εκεινη την φορα το αποτέλεσμα δεν ηταν το επιθυμητό καθώς οι κόρνες της Magico εχουν πρόβλημα στον χρονισμό των μοναδων. Εδώ περισσότερα για εκείνη την "φαουλ" (και για αλλους λογους) παρουσίαση.
Η απάντηση στο ερώτημα ειναι οτι το CD player της Spectral οπως και το DAC της Pacific Microsonics το γνωρίζω και απο αλλού, το ιδιο και τους ενισχυτές που χρησιμοποιήθηκαν στις παραπάνω ακροάσεις. Οποτε καταλήγω οτι σε μεγάλο βαθμο μου έφταιγαν τα ηχεία..
Re: Magico
Unread post #7 by Gojakla » Sat Aug 06, 2016 12:48 pm
O Alon παντως ειναι το κλασσικο american dream... εφυγε απο Ισραηλ (στρατιωτικος) να επισκεφθει τον πατερα του που ηταν Αμερικη και γυρνωντας πισω επεσε σε καταθλιψη. Ξαναγυρισε βεβαιως στην "γη της επαγγελιας" και αφου εκανε διαφορες σκατοδουλειες εκανε μια καλη μπαζα απο την οποια ξεκινησε τη Magico.
Καθολου ασχημα.
@Πανο: Ο χρονισμος που αναφερεις στις κορνες; Αλλα ντ' αλλα κουτρουβαλα; Καμια συνοχη;
Re: Magico
Unread post #8 by Dr Pan K » Sat Aug 06, 2016 4:58 pm
Gojakla wrote:@Πανο: Ο χρονισμος που αναφερεις στις κορνες; Αλλα ντ' αλλα κουτρουβαλα; Καμια συνοχη;
Πονεμένη ιστορία. Αποφασίζει ο Αλον να κατεβάσει το ultimate mk III στο Μόναχο (γιατί απ ότι είχα ακούσει είχε έτοιμο πελάτη ο Γερμανός αντιπροσωπος). Φέρνει μαζί συστοιχία ενισχυτων Pass και το κορυφαίο DAC που λέγαμε πριν. Το δωμάτιο μάλλον μικρό αλλά για να είναι σίγουρος ότι θα εντυπωσιάσει στήνει και δύο διπλά 15" subwoofer, δλδ στο σύνολο έχει 6*15" ενεργά με 2000 βατ Class D το καθένα. Ξεκινάει το ντεμο με δική του προεπιλεγμενη λίστα αφού πρώτα μας εξηγεί ότι τα ηχεία είναι ότι καλύτερο στον κόσμο και πως οι μονάδες έχουν έρθει από την Ιαπωνία.
Μέτρα τώρα πόσα φάουλ έχουν γινει:
Κατασκευάζει ηχεία κλασσικά, με καμπίνες δλδ αλλά το κορυφαίο του είναι κορνα. Γιατί να μην πάρω λοιπόν κορνα κατευθείαν από κάποιον άλλο ειδικό στις κορνες και να πάρω τα κουτιά του στα 50-100-200 Κ;
Λέει ότι οι μονάδες που μπαίνουν στα κουτιά του είναι οι κορυφαίες που υπάρχουν άλλα για τις κορνες του πάει και ψωνίζει από αλλού. Άρα παραδέχεται ότι υπάρχουν καλύτερες και ότι αυτός παρότι χρεώνει ότι του κατέβει δεν έχει την τεχνογνωσία για τις κορυφαίες.
Το κορυφαίο ηχείο του είναι κορνα αλλά για να βγάλει χαμηλό το κάνει με subwoofer και μάλιστα με ενίσχυση σε τάξη Δ...
Καμία από τις τεχνολογίες δεν έχει περάσει στα "νορμαλ" μοντέλα. Έστω το ρουτερ..τπτ.
Σαν να λέω ότι είμαι ο καλύτερος ζαχαροπλαστης αλλά για το σπίτι ψωνίζω από το παγωτατζιδικο στο απέναντι πεζοδρόμιο..
Πάμε τώρα και στον ήχο. Όταν υπήρχε μετάβαση από την μία οκταβα στην άλλη στις μεσαίες η εικόνα ανεβοκατεβαινε 40 πόντους, σαν να σηκώνεται και να ξανακαθεται η τραγουδιστρια σε καρέκλα. Θέμα κρος αλλά και όγκου κορνων, το σίγουρο είναι ότι το αποτέλεσμα ήταν κάτω του μετρίου.
