Dan D’ Agostino Momentum Integrated Amplifier
Unread post #1 by Gojakla » Sat Apr 16, 2016 11:55 am
Momentum Integrated_Intro.jpg (207.69 KiB) Viewed 3086 times
Official Site
OVERVIEW
Until now, choosing an integrated amplifier always meant choosing compromise. But that's because until now, no integrated amplifier has ever borne the signature of Dan D'Agostino. The new Momentum integrated amplifier combines the core audio circuits of the Momentum preamplifier and the Momentum stereo amplifier, both of which have been acclaimed by respected reviewers around the world as among the best audio components every created.
The front panel has the same look and functionality as the Momentum preamplifier, with an illuminated dial and indicator needles inspired by classic Swiss watches. Six balanced XLR inputs are provided on the back panel. Bypassable tone controls allow the listener to customize the sound to suit the recording or personal taste, without affecting the fundamental sound quality and musicality of the unit.
The amplifier section is conservatively rated at 200 watts per channel into 8 ohms and 400 watts per channel into 4 ohms. A completely separate power supply, encased in a chassis machined from solid aluminum billet, isolates the sensitive audio circuitry from electromagnetic interference.
The Momentum integrated amplifier is an audio first: an integrated amplifier without compromise.
Momentum Integrated_Quote.jpg (133.16 KiB) Viewed 3086 times
SPECIFICATIONS
Power
200 watts @ 8Ω
400 watts @ 4Ω
800 watts @ 2Ω
Frequency Response
0.1 Hz to 200 kHz, -1 dB
20Hz to 20 kHz, ±0 dB
Distortion
200 watts @ 8 Ω
< 0.1%, 20 Hz to 20 kHz
Signal-to-Noise Ratio
95 dB, unweighted
Inputs
6 stereo balanced XLR
Input Impedance
1 MΩ
Output Impedance
0.12Ω
Dimensions
8 x 18 x 16 inches
120 lbs. (with power supply)
GALLERY
Re: Dan D’ Agostino Momentum Integrated Amplifier
Unread post #2 by Dr Pan K » Wed Jun 29, 2016 10:59 pm
O Dan έκανε το μεγαλύτερο come back στην ιστορία του high end, ever! Η σειρά των D'Agostino Master Audio Systems απο όταν πριν λιγα χρόνια παρουσιάστηκε το πρώτο μοντέλο (ο τελικός) αναπτύχθηκε σε μια πληρέστατη γκαμα ενισχυτων με διαφορετικες γραμμές για ολες τις "ανάγκες" με προ, τελικούς, home theater (master power βγαίνει και σε τρικαναλο), phono stage αλλά και ενα Life Style ενισχυτή με ενσωματωμένο streamer!
Έχοντας ακούσει πρακτικά ολα τα μοντέλα στις διαφορες εκθέσεις μπορω να πω οτι παιζουν εξαιρετικά. Παρουσιάζουν κοινα χαρακτηριστικά μονο με τα πρώτα πρώτα σχεδια απο την εποχη Krell, σε καμια περίπτωση δεν εχουν την σκληραδα των μετα D'Agostino θηρίων. Πολυ χαρακτηριστική ειναι η αίσθηση ροης και οι φυσικές χροιές τους. Αν κόστιζαν ενα μηδενικό λιγότερο θα τους ειχα βαλει στο σύστημά μου αλλα δυστυχώς με τοσα δεν παίρνεις ουτε το σασι άδειο.
Φωτο απο την έκθεση του Μοναχου, στην ασπρόμαυρη ο Dan με τον MIchael Fremer
Return to “Ενισχυτές”
