dCS
dCS
Unread post #1 by Gojakla » Sun Sep 18, 2016 1:12 pm
Official Site
OVERVIEW
dCS products are high end – a combination of world-class craftsmanship and leading-edge technology – but those who invest in dCS have the chance to experience that unique, spine-tingling moment when the world stops and there is… only the music.
We believe that the role of a hi-fi system is to preserve all of the subtle information on a recording through the reproduction chain, and present it to the listener with every last nuance of emotional content intact.
One of the most important parts of the music reproduction process is digital-to-analogue conversion, when the digital data on a CD or computer file is converted into an analogue signal – the music we hear through the loudspeakers.
It is this process that dCS has been refining for twenty five years and, by making the world’s most advanced digital-to-analogue converters (DACs), master clocks and digital-to-digital converters (D2D), we can make Compact Discs or computer music files sound more faithful to the original recording than anything else.
Over the years dCS has demonstrated to music lovers worldwide that by separating the key functions of the digital playback chain, huge sonic benefits and extraordinary musicality can be achieved.
For this reason a typical dCS reference system can comprise up to four separate units: Upsampling CD/SACD Transport, Digital-to-Digital Converter, Digital-to-Analogue Converter and Master Clock.
The positive contribution that each makes to the overall musical performance can easily be heard. All dCS products express the same values of musical and technical excellence and, by utilising the same key technologies across our ranges, we can be sure that whatever the source, the musical performance is guaranteed.
Re: dCS
Unread post #2 by Gojakla » Sun Sep 18, 2016 1:14 pm
Vivaldi
Vivaldi is a compete digital music playback system that offers unmatched sonic and measured performance. Designed for maximum flexibility with an array of input and output configurations it is easily set up and optimised for music systems with various sources. Vivaldi redefines state-of-the-art in digital playback, transforming your listening experience and taking your music collection to levels you have not heard before.
Vivaldi DAC uses the latest groundbreaking dCS technology including ‘next generation’ versions of the dCS Ring DAC™, Digital Processing Platform and Clocking System so that, as the hub of a digital audio system, an array of features guarantees superlative performance from any digital source.
Vivaldi Upsampler is designed to act as the hub of a digital audio system. It will transform your listening experience, taking your music collection to levels you have not heard before.
Vivaldi Transport is designed to extract revelatory levels of detail from both CD and SACD and is the ultimate machine for silver disc replay. All signal processing in Vivaldi Transport is proprietary to dCS.
Vivaldi Master Clock is a powerful yet simple to use Grade 1 master clock based on our pioneering developments in studio and home audio. Featuring two banks of clock outputs capable of outputting different frequencies, Vivaldi Master Clock uses the latest groundbreaking technology from dCS.
Re: dCS
Unread post #3 by Gojakla » Sun Sep 18, 2016 1:16 pm
Rossini
The new dCS Rossini system makes superlative sounding music from a wide range of digital sources. This single box digital streaming player features the legendary dCS Ring DAC and digital processing platform, plus a custom high performance UPnP music streamer and CD transport. Rossini delivers a powerful and visceral sound yet it is highly transparent too, making for an immersive and realistic listening experience.
The new dCS Rossini Player makes superlative sounding music from a wide range of digital sources, simply integrating your digital music and setting the performance standard for digital playback.
The new dCS Rossini DAC makes superlative sounding music from a wide range of digital sources, simply integrating your digital music and setting the performance standard for digital playback.
The new dCS Rossini range makes superlative sounding music from a wide range of digital sources, simply integrating your digital music and setting the performance standard for digital playback.
Re: dCS
Unread post #4 by Gojakla » Sun Sep 18, 2016 1:17 pm
Debussy
The entry point to the world of dCS, Debussy combines the legendary dCS Ring DAC and our award winning USB technology to deliver an elegant DAC that will extract an amazing musical performance from any digital source.
Single-box elegance at the cutting edge of standalone DAC design. Debussy is the entry point to the world of dCS and designed to be the hub of a digital playback system.
Built to the highest specification, Debussy features a sleek solid aluminium fascia, high-grade aluminium casing, metal buttons and is powered by dCS electronics. Whether you use CD or a computer as your source, Debussy will resolve every last bit of detail from your music collection, bringing a realism that you have never heard before.
Re: dCS
Unread post #5 by Dr Pan K » Mon Sep 19, 2016 9:11 pm
Θυμάμαι οταν ειχα διαβάσει τις μετρήσεις του Vivaldi στο Stereophile πριν περίπου 3 χρόνια ειχα μείνει με το στόμα ανοιχτό..
The Vivaldi DAC's channel separation was superb, at >125dB in both directions below 1kHz (not shown), and still 118dB at 20kHz. The very low noise floor with 24-bit data can be seen in fig.11, with all power-supply–related spuriae at or below –135dB and the random noise components mainly stemming from the analyzer's A/D converter. Astonishing! With a dithered 1kHz tone at –90dBFS, increasing the bit depth from 16 (fig.12, cyan and magenta traces) to 24 (blue and red) dropped the noise floor by 24dB, indicating that the Vivaldi DAC has at least 20-bit resolution, which is the state of the art.
O Atkinson μάλιστα καταλήγει:
Without any doubt, this was the best digital playback I have experienced. While there are digital processors that offer measured performance almost as good as the Vivaldi—the Electrocompaniet ECD-2, for example, and MSB's Diamond DAC IV or even NAD's M51—there was an increased sense of ease to the Vivaldi's sound quality, particularly when the Upsampler transcoded the data to DSD, that proved addictive. In this respect, it was even better than the MSB it replaced in my system.
Και φετος στο Μοναχο το συστημα με τα Wilson Specialties Alexia και τους τελικους του D'Agostino ηταν απο τα κορυφαία ακούσματα. Μιλάμε για το πλήρες σετ του Vivaldi 2.0 που προσέθεσε και Roon ready δυνατότητα. Αν εχω ενα παράπονο αυτο εχει να κανει με το ψηφιακό ποτενσιομετρο, προσωπικά επειδη και μονο η ιδεα οτι χανω καποια πληροφορια με κανει να δυσανασχετω, θα προτιμούσα ενα ποιοτικό προενισχυτη στην αλυσιδα. Ισως να ειναι μονο η ιδεα, καθως στο Μοναχο το σύστημα, παρολο το ψηφιακό ποτ (και τα καλώδια της Transparent που ποτέ δεν με ενθουσιασαν), έπαιζε εξαιρετικά.
https://parttimeaudiophile.com/2016/06/ ... oon-ready/
Re: dCS
Unread post #6 by BityaBit » Mon Sep 19, 2016 11:05 pm
Άντε να έρθει ο Νοέμβριος να τα ακούσουμε και στην έκθεση εδώ στην Αθηνα. Περισυ πέρασα από τον Ορφέα μόνο για να χαιρετήσω φίλους και γνωστούς. Φέτος προβλέπεται να περνάω αρκετό χρόνο στα δωμάτια του..
Bartok dCS
Unread post #7 by Dr Pan K » Sat Aug 11, 2018 11:11 pm
Bartok dCS.jpg (176.47 KiB) Viewed 3945 times
Νεο "εισαγωγικό" μοντελο απο την dCS, το Bartok ! Θα ερθει σε 2 εκδοσεις, μια με DAC & streamer, η αλλη με εξτρα ενισχυτή ακουστικων. Τιμες περίπου 11 και 13Κ ευρω αντίστοιχα.
dCS Bartók network DAC with Class A headphone output (£11,999)
dCS Bartók network DAC (£9,999)
latest generation dCS Digital Processing Platform and Ring DAC™
Supports UPnP™, asynchronous USB and Apple AirplayTM sources, plus AES and S/PDIF digital audio streams.
Class A headphone amplifier stage drives low and high impedance phones
Streaming services supported include TIDAL™ and Spotify Connect™
Built in Roon Ready™
multi-stage oversampling design, optional DSD upsampling; selectable filters
auto-clocking system improves ease of use and minimises jitter
Accepts encrypted SACD data from dCS Transports via Dual AES inputs.
multi-stage power regulation and twin mains transformers
firmware-upgradeable for future functionality and performance upgrades
https://www.dcsltd.co.uk/news/dcs-launc ... amplifier/
