Aavik
Aavik
Unread post #1 by Gojakla » Tue Sep 27, 2016 3:46 pm
Official Site
Lars Kristensen.jpg (206.49 KiB) Viewed 3131 times
Founded in 2014 by some of the leading professionals in the high-end audio industry, each with more than 25 years of experience, Aavik Acoustics is a creator of state-of-the-art amplifiers with the most modern technology and a functional and minimalistic design based on Scandinavian design traditions.
Aavik Acoustics’ first amplifier, the Aavik U-300, has already been tested to be one of the world's top integrated amplifiers by several high-end magazines and reviewers.
Our team feel it is important to talk to our customers and meet them in person, which is why we try to visit as many high-end audio shows as possible. If you follow on us Facebook, we will provide you with the latest updates on upcoming shows and new products.
Re: Aavik
Unread post #2 by Gojakla » Tue Sep 27, 2016 3:48 pm
Aavik U-300 Integrated Amplifier
U-300 Front.jpg (111.26 KiB) Viewed 3130 times
U-300 Back.jpg (141.12 KiB) Viewed 3130 times
Output:
2 x 300 W/8 ohm, 2 x 600 W/4 ohm
Distortion: <0.005% (THD+N: 1-100 W / 8Ω)
IMD<0.0008%
TIM<0.002% (10W, 8Ω)
Phono:
Floating RCA (1 set)
Load-impedance adjustable from 50 ohm to 5 kOhm;
Frequency response: +/-0.15dB (20-20 kHz)
Noise < -100dB re @ 2V out
Distortion < 0.01% (20-20 kHz)
RIAA correction curve
Gain: 62 dB
Line:
Line 1, Line 2, Line 3
Gain adjustable in 3 steps (0, 6, 12 dB)
Input impedance: 10 kOhm
Digital:
2 x RCA SPDIF (32 – 192 k-samples, 24 bit)
2 x TOSLINK optical (32 – 96 k-samples, 24 bit)
1 x USB fully isolated, UAC 2, asynchronous (PCM 32 – 192 k-samples, 24 bit)
Volume Control:
Volume adjustable from -100 dB to 0 dB in 80 1 dB steps
Dimensions:
100 x 440 x 370 mm
Weight:
16.5 kg
Re: Aavik
Unread post #3 by Gojakla » Tue Sep 27, 2016 3:50 pm
Aavik P-300 Power Amplifier
P-300 Front.jpg (128.18 KiB) Viewed 3130 times
P-300 Back.jpg (157.32 KiB) Viewed 3130 times
Inputs:
2 XLR, 2 RCA
Input sensitivity: 2V RMS
Input impedance:
22KΩ (XLR), 10KΩ (RCA)
Outputs:
1 set copper binding post
Power rating:
150 W, 8Ω, 0.01 THD+N
Frequency response:
0.1 Hz to 150 kHz
Gain:
27 dB
Distortion:
<0.005% 10V, 1 kHz
Output impedance:
0.001Ω
Damping factor (8Ω load):
8,000
Weight:
35 kg
Dimensions:
440 x 480 x 133 mm (WxDxH)
Re: Aavik
Unread post #4 by Gojakla » Tue Sep 27, 2016 3:52 pm
Aavik C-300 Preamplifier
C-300 Front.jpg (97.88 KiB) Viewed 3130 times
C-300 Back.jpg (165.07 KiB) Viewed 3130 times
Phono:
Gain 70 dB @ 1 kHz
Load-impedance adjustable from 50Ω to 5KΩ
Frequency response: +/-0.15 dB (20-20 kHz)
Noise
Distortion <0.01% (20-20 kHz)
Line:
Gain (line 1-2): 9 dB, maximum input: 2.5V RMS
Gain (line 3): 3 dB, maximum input: 5V RMS
Input impedance: 10KΩ
Digital:
2 x RCA SPDIF (32 – 192 k-samples, 24-bit)
2 x TOSLINK optical (32 – 96 k-samples, 24-bit)
2 x USB fully isolated, UAC 2, asynchronous
USB 1: PCM 32 - 192 k-samples, 24-bit
USB 2: DSD 64 - DSD 128
OUTPUTS
1 set gold-plated RCA
Output impedance: 50Ω
1 set XLR balanced
Output impedance: 100Ω
Volume control:
Adjustable from -80 dB to 0 dB in 80 one dB steps
Dimensions:
100 x 440 x 370 mm (W/D/H)
Weight:
16.5 kg
Return to “Ενισχυτές”
