Rockport Technologies
Unread post #1 by Gojakla » Thu Sep 29, 2016 1:29 pm
Official Site
Rockport Technologies began as Payor Acoustics Inc. in 1984 with the design of a compact, satellite/subwoofer loudspeaker system. Long ago we recognized that the two areas of greatest loss in an analog reproduction chain are where the transduction occurs from mechanical to electrical energy at the front end, and then back to mechanical (acoustical) energy at the loudspeaker. Consequently, these two transduction sites provide the greatest opportunity for improvement in an audio system, and have been the areas where we have focused our attention for more than 25 years.
From Rockport Technologies founder and chief designer Andy Payor: “I was privileged to have a love for music instilled in me at an early age by my parents. The profound effect that music has in the way we think and feel, and to evoke memories, has always inspired me.”
Each one of our loudspeakers is built using the finest components available, and all Rockport Technologies loudspeakers, from the Mira II to the Arrakis are assembled using the same proven techniques. One of the many benefits of limited production is that we are not under pressure to manufacture huge quantities of product to cover excessive overhead, or meet arbitrary marketing goals. In fact, we build each loudspeaker as if it were going into our own home.
There is a great degree of similarity in the design and execution of our different loudspeaker models. We have integrated our best efforts into each system that we build, and the primary difference between models is their deep bass extension and ultimate sound pressure capabilities. All of these models exhibit a marked family resemblance, but are suited for different size rooms and listening levels. The exquisite build quality and stunning performance of every Rockport Technologies product, from our most ambitious to our most affordable, is evidence of our commitment to excellence.
Re: Rockport Technologies
Unread post #2 by BityaBit » Thu Sep 29, 2016 7:40 pm
To HI END απωθημένο μου στα ηχεία ειναι ένα ζευγάρι ALTAIR.. Eχω ακούσει τους προγόνους τους με τα κατάλληλα συνοδά σε φροντισμένο χώρο και εγώ (και οι πέτρες στα νεφρά μου) ακόμα θυμάμαι την εμπειρία την οποία ελπίζω να επαναλάβω σύντομα.
Zakman35
Unread post #3 by Zakman35 » Thu Sep 29, 2016 8:26 pm
Συμφωνώ, τα Altair είναι όντως μια εμπειρία που δεν ξεχνάς.
Unread post #4 by Dr Pan K » Fri Sep 30, 2016 8:01 pm
Ανάμεσα στα λιγα ηχεία που ζηλεύω και θα ήθελα να έχω κάποια στιγμή στο σύστημα μου. Γρήγορα, λεπτομερή, με έκταση και εικόνα. Μονο μειονέκτημα κάποιων μοντέλων το δύσκολο στήσιμο στον χωρο ένεκα πλάγιου woofer. Οκ, δεύτερο μειονέκτημα η τιμη αλλα για τα δεδομένα του high end σχεδόν τα θεωρώ vfm λύση.
Ελπίζω στο Μόναχο το 2017 να εχουν το τελευταιο Cygnus γιατι διαβάζοντας τα χαρακτηριστικά και τις τεχνικές κατασκευής υποψιάζομαι οτι η Rockport έκανε αλλο ενα βήμα μπροστά. Επισης ελπιζω να μην χρειαστει να τα ακουσω με τους ενισχυτες της Absolare γιατι δεν εχουν καταφέρει ποτε να ελέγξουν το χαμηλό των ηχείων (παροτι σχετικά ευαίσθητα θέλουν σοβαρή τρανζιστορατη ενίσχυση). H παρουσίαση του 2016 με τον υβριδικό ενισχυτή δεν ηταν και τοσο άσχημη βέβαια..
Ειδική μνεια πηγαίνει στον Andy Payor, που παρόλα τα προσωπικά του προβλήματα εχει σχεδιάσει κορυφαία ηχεια χωρίς να μπορώ να θυμηθώ εστω ενα που δεν αποτελούσε επιτυχία.
Unread post #5 by andreasecon » Fri Sep 30, 2016 8:30 pm
Πάντως σιγά σιγά καταργεί τα πλαΪνά woofers, ξεκίνησε απο τα μικρά μοντέλα και ανεβαίνει....
Unread post #6 by Dr Pan K » Fri Sep 30, 2016 9:04 pm
Ισχυει, και υποψιάζομαι οτι το Cygnus θα ειναι απερίγραπτα καλο ηχείο. Αλλα τα αλλα 2, το Altair και το Arrakis δύσκολα θα αλλάξουν σχεδίαση, δεν υπάρχει χωρος στην μπροστινή μπαφλα για τοσο μεγάλες μονάδες.
panos_adgr
Unread post #7 by panos_adgr » Sun Oct 02, 2016 11:46 pm
Αν με ρωτούσαν ποτέ ποιό είναι το αντικείμενο πόθου μου στο audio θα απαντούσα ότι είναι τα Ηχεία Rockport.
Θα ζούσα άνετα και με ένα ζευγάρι Avior. H αίσθηση της ακρόασης από την έκθεση μου έχει μείνει ακόμα.
Κορυφαία!
