JDS Labs "Element" Line
Unread post #1 by Gojakla » Mon Nov 28, 2016 2:30 pm
Official Site
OVERVIEW
Expanded connectivity for Desktop Audio is the theme we’ve been working towards lately. I listen to powered speakers at my desk whenever I have the chance, and transition to headphones at other times. Many of our customers listen the same way, and agree that a single system should be able to interface with headphones and speakers.
Sometimes a system doesn’t involve a USB connection. Thus, optical and coaxial S/PDIF inputs are long overdue. Element Line provide means to switch between listening to headphones or to powered speakers. Introducing:
EL Dac
EL DAC delivers performance far beyond Objective criteria, with full USB Audio Class 2 support, transformer isolated coaxial input, and optical input. Stack with EL Amp for single button switching between headphones and speakers.
DAC PERFORMANCE
Frequency Response 20Hz-20kHz
+/- 0.15dB
THD+N 20Hz-20kHz
< 0.0011%
IMD CCIF 19/20 kHz -6.03 dBFS
0.00017%
IMD SMPTE -6.03 dBFS
0.00061%
Noise (A-Weighted)
-109 dBu
Dynamic Range (A-Weighted)
117 dB
Linearity Error -90 dBFS
-0.01 dB
Crosstalk -10 dBFS 100K RCA
-108 dB
USB Jitter Components 11025Hz
-116 dB
Maximum DAC Line-Output, 100K
2.00 VRMS
DATA SUPPORT
Audio Formats (S/PDIF)
16/44.1kHz thru 24/192kHz
Audio Formats (USB)
16/44.1kHz thru 32/384kHz
USB Interface
USB Audio Class 2
USB Driver OS Support
Windows XP/7/8/10, OS X, Linux
CONNECTIVITY
Digital Inputs
USB, TOSLINK, and Coaxial S/PDIF
DAC Line-Output
RCA
EL Amp
EL Amp combines a powerful headphone amplifier with a comfortable knob, housed in a precision machined chassis. Enjoy seamless transitions between your powered speakers and headphones.
AMPLIFIER PERFORMANCE
+/- 0.1dB
THD+N 1kHz, 150 Ω
0.0009%
IMD CCIF 19/20kHz 150 Ω
0.0004%
IMD SMPTE 150 Ω
0.0005%
Noise, A-Weighted
-108 dBu
Crosstalk @ 150 Ω
-67 dB
Output Impedance
0.1 Ω
Channel Balance
+/- 0.56 dB
Max Continuous Output, 600Ω
140 mW (9.4VRMS)
Max Continuous Output, 150Ω
505 mW
Max Continuous Output, 32Ω
1.1 W
Peak Output Power, 32Ω
1.5W
CONNECTIVITY
Headphone Output
6.35mm (1/4")
Analog Input
RCA
Line-Output
RCA
The Element
We designed The Element to simplify your desktop audio experience. Element's powerful headphone amp, ultra clean USB DAC, and graceful switch are all housed in a precision machined chassis with a comfortable knob. Enjoy seamless transitions between your powered speakers and headphones.
+/- 0.1dB
THD+N 1kHz, 150 Ω
0.0009%
0.0004%
IMD SMPTE 150 Ω
0.0005%
Noise, A-Weighted
-108 dBu
Crosstalk @ 150 Ω
-67 dB
Output Impedance
0.1 Ω
Channel Balance
+/- 0.56 dB
140 mW (9.4VRMS)
505 mW
1.1 W
1.5W
DAC PERFORMANCE
+/- 0.15dB
THD+N 100 Hz -0.15 dBFS
0.0023%
THD+N 20 Hz -0.15 dBFS
0.0016%
THD+N 10 kHz -0.15 dBFS
0.0019%
0.0011%
0.0012%
Noise A-Weighted dBu 24/96
-102 dBu
>112 dB
Linearity Error -90 dBFS 24/96
-0.02 dB
-100 dB
-113 dB
2.10 VRMS
DATA SUPPORT
Interface
USB, Audio Class 1
Native OS Support
Audio Formats
16/44, 16/48, 16/88.2, 16/96,
24/44, 24/48, 24/96
CONNECTIVITY
Headphone Output
6.35mm (1/4")
Analog Input
RCA
DAC Line-Output
RCA
Digital Input
USB
Re: JDS Labs "Element" Line
Unread post #2 by Gojakla » Mon Nov 28, 2016 2:34 pm
Element Line_01.jpg (236.85 KiB) Viewed 3094 times
Element Line_02.jpg (138.04 KiB) Viewed 3094 times
Element Line_03.jpg (340.14 KiB) Viewed 3094 times
Element Line_04.jpg (178.24 KiB) Viewed 3094 times
Unread post #3 by Chris1967 » Mon Nov 28, 2016 2:55 pm
Πολύ καλή εταιρία, ποιοτικά προϊόντα και καλό value. Έχω αγοράσει από αυτούς στο παρελθόν τον περίφημο τους c-moy σε κουτάκι από μέντες, το ODAC και το Objective Amp. Παλιές αλλά πολύ ευχάριστες αναμνήσεις.
Τα νέα του προϊόντα φαίνονται πού όμορφα και ηχητικά μαντεύω ότι θα παίζουν πολύ καλά για τα χρήματα τους, συν ότι είναι στολίδια για το γραφείο/θέση εργασίας.
Unread post #4 by Gojakla » Mon Nov 28, 2016 3:02 pm
Θα συμφωνήσω απολύτως.
Έχω και εγώ αγοράσει το ODac αλλά και τον ενισχυτή O2.
Η καινούργια σειρά έχει αναβαθμιστεί παααρα πολύ αισθητικά (και αν διακρίνω απο τις φώτος και σε ποιότητα κατασκευής) και μου μοιάζει κελεπουράκι για σετάπ γραφείου.
Ο ενισχυτής ήταν ικανός να οδηγήσει αξιοπρεπώς μια αρκετά μεγάλη γκάμα ακουστικών με χαρακτηριστική άνεση.
Εγώ χαζεύω καιρό ψάχνοντας μια λύση για dac στο γραφείο και το EL Dac -που πλέον φοράει ΑΚΜ που αρέσκομαι- φαντάζει πολύ καλή επιλογή.
Τιμές:
El Dac: $279.00
El Amp: $279.00
The Element: $349.00
Unread post #5 by Dr Pan K » Sat Dec 03, 2016 10:25 am
Τελικά μάθαμε τι απέγινε ο NwAvGuy?
