PS Audio Stellar Gain Cell DAC
Unread post #1 by Gojakla » Fri Mar 17, 2017 11:43 am
00_Stellar Gain Cell Dac Intro.jpg (151.6 KiB) Viewed 6237 times
Official Link
OVERVIEW
Even the best DACs in the world benefit from a zero-loss analog preamp. That fact was the basis of the Stellar Gain Cell design imperative. Combine a cutting edge DAC’s output with a no compromise analog preamplifier. A unique combination of a gorgeous full-featured digital to analog converter and state of the art analog amplification. Add any analog or digital source to Stellar’s input, a power amp and speakers to its output, and music filled with rich textures and toe-tapping energy surprise and delight even the most critical Audiophile.
01_Stellar Gain Cell Dac Quote.jpg (129.8 KiB) Viewed 6237 times
FEATURES
Analog Preamplifier
One balanced analog input
Three single ended analog inputs
Analog Gain Cell stage
Fully balanced input to output
Balanced XLR analog output
Single ended RCA analog output
Direct coupled without any capacitors in output signal path
Digital To Analog Converter
Four digital inputs
I2S input
Digital Lens technology
Three user selectable digital filters
Compatible with PS Audio DMP for SACD playback in DSD
DSD direct through I2S
192kHz asynchronous coax and TOSLINK inputs
192kHz asynchronous USB
Single and double rate DSD
CPLD input (FPGA) lowers jitter, waveshapes, reduces propagation delay
Native mode standard
No added Sample Rate Conversion
High current class A hybrid output stage
Passive output filter lowers transient distortion
High bandwidth output stage -3dB 60kHz
Low jitter clocks
High Current oversized analog power supply
7 voltage regulators
High speed power supply diodes
Massive 15,000 mFd low ESR capacitors
ESS Hyperstream
02_Stellar Gain Cell Dac.jpg (138.15 KiB) Viewed 6237 times
03_Stellar Gain Cell Dac.jpg (150.19 KiB) Viewed 6237 times
04_Stellar Gain Cell Dac.jpg (138.1 KiB) Viewed 6237 times
05_ Stellar Gain Cell Dac.jpg (204.45 KiB) Viewed 6237 times
06_Stellar Gain Cell Dac.jpg (284.43 KiB) Viewed 6237 times
Price: $1.699
Re: PS Audio Stellar Gain Cell DAC
Unread post #2 by Dr Pan K » Fri Mar 17, 2017 11:48 am
Πολύ ενδιαφέρον! Αυτό και ένα ζευγάρι ενεργά ηχεία και είσαι κομπλέ. Θα ήμουν περίεργος να το ακουσω.
Unread post #3 by Gojakla » Fri Mar 17, 2017 11:50 am
To Sabre με "χαλάει" λιγουλάκι αλλά ποιός δεν θα ήθελε να το ακούσει?
farflung
Unread post #4 by farflung » Fri Mar 17, 2017 3:28 pm
Οντως ενδιαφερον και το Fully balanced input to output με εξιταρει.
Στην λιστα αμεσα και η τιμουλα λογικη.
Unread post #5 by Gojakla » Fri Mar 17, 2017 3:39 pm
Η τιμη ειναι πραγματι ακρως δελεαστικη.
farflung
Unread post #6 by farflung » Fri Mar 17, 2017 3:44 pm
ποιος τα πουλαει?
η ηχοδομη?
Leonidas
Contact:
Unread post #7 by Leonidas » Fri Mar 17, 2017 6:43 pm
Καλησπερα σε ολους,
Νεος εδω, παλαιος στο αθλημα/χομπι. Το συγκεκριμενο μηχανημα της PS Audio το εχω ακουσει πριν περιπου 8 μηνες οταν ειχα παει Αμερικη για ενα συνεδριο. Το ακουσα στημενο σε δυο διαφορετικα συστηματα, το ενα πανω σε ενεργα ηχεια και το αλλο πανω σε τελικο της ιδιας εταιριας με ηχεια Avalon Acoustics IDEA. Και στις δυο περιπτωσεις εξαιρετικο αποτελεσμα.
Εχω και παρομοιο setup στο χωρο μου με τελικο της PS Audio GCA-250 και πηγη/προενισχυτης το BLADELIUS EMBLA MEMORY PLAYER. Τα ηχεια εναι αυτα που αναφερα πιο πανω.
Οσο για το ποιος εισαγει την PS Audio στη χωρα μας ειναι ο Εβαγγελος Λαμπρου με την εταιρια Projecting & Sounding art
Site: www.projecting-art.com
Ειναι στην Ηλιουπολη σε ομορφο χωρο και εχουν σχεδον ολα τα PS σε στοκ.
Οποιος βρεθει στα νοτια προαστια και κανει κεφι ακροαση του συστηματος στο χωρο μου που αναφερθηκα ειναι more than welcome.
Υπαρχουν και αλλα συστηματα στο χωρο μου οπως και ακουστικα της εταιριας Kennerton(yes the Russian brand).
Leonidas.
Unread post #8 by Dr Pan K » Fri Mar 17, 2017 7:04 pm
Τνχ για το feedback Λεωνίδα. Θα είχε ενδιαφέρον αν το ακούγαμε στην επερχόμενη ακρόαση δίπλα και στα άλλα DAC της κατηγορίας.
Leonidas
Contact:
Unread post #9 by Leonidas » Fri Mar 17, 2017 7:33 pm
Τιμή μου Παναγιώτη. Θα εχεις ενημέρωση απο τον αντιπρόσωπο πιστεύω άμεσα!
Unread post #10 by Gojakla » Fri Mar 17, 2017 11:45 pm
Καταπληκτικη εξελιξη. Ευχαριστουμε.
