Grado Epoch & Aeon cartridges
Unread post #1 by Dr Pan K » Fri Jul 28, 2017 10:30 pm
H Grado αποφάσισε να παίξει τα ρέστα της λανσαροντας δυο νεες κεφαλες με τιμη 6 και 12.000 $ αντίστοιχα.
The Epoch and Aeon, which see final assembly by John Grado himself on his workbench, are two cartridges that offer exceptional reproduction of vocals and instruments, with superlative tonal balance, dynamics, imaging, and realism. Grado's coil winding techniques, which have been honed throughout the decades, have let them achieve exact unison between the four coils in each phono cartridge. This allows for a precise balance between channels and accurate stereo imaging. Each Grado is wound with the finest properly sized and annealed 24-karat solid gold wire, which is the ultimate conductor for the transmission of the music from your record.
All of the internal magnetic circuit parts are Swiss screw machined or molded metal, which have tolerances on the order of the best Swiss-made watches. The specially designed diamond stylus, for the first time in a Grado, is mounted on a sapphire cantilever that connects to the stylus generating system. The Epoch and Aeon feature a unique system that has the lowest effective moving mass of any cartridge, while Grado's patented Flux-Bridger generator design creates a superior balance throughout the full frequency spectrum with superb resolution and clarity, which produces an overall truer picture of the music. This is all nestled inside a cocobolo wooden housing.
Με λίγα λόγια και για πρώτη φορά στην ιστορία κυκλοφορούν κεφαλές moving iron, παραλλαγή των γνωστών μας και ιδιαίτερα φτηνών ΜΜ σε τιμές που κοντράρουν στα ίσια τις κατά πολύ πιο δύσκολο να κατασκευαστούν MC. Τι διαφορετικό έχουν αυτές οι δύο Grado σε σχέση με τα άλλα μοντέλα της εταιρίας του Brooklyn? Τίποτα που να δικαιολογεί την τιμή. Θα τσιμπάνε άραγε hum όπως όλες οι άλλες Grado αν τοποθετηθούν κοντά σε κινητήρα ή μετασχηματιστή ? Πιθανό..
Μας δουλεύουν ψιλό γαζί οι διάφοροι κατασκευαστές του high end και σου λέει ο Grado γιατί όχι και εγώ που έχω και το heritage? Το μόνο σίγουρο. Άντε και καλές ακροάσεις
Speedking
Contact:
Re: Grado Epoch & Aeon cartridges
Unread post #2 by Speedking » Wed Nov 08, 2017 6:12 pm
Θα συμφωνησω στο οτι ειναι (παν-)ακριβη οπως αρκετες αλλες της αγορας αλλα ποτε δεν καταλαβα πως δικαιολογουν τις εξοφρενικες τιμες...
Κατασκευαστηκα ομως δεν μπορω να πω οτι οι ΜΙ ειναι παραλλαγη μια "φθηνης" ΜΜ μιας και ειναι διαφορετικη τασκευη αλλα ουτε θα πω πως η κατασκευη μιας ΜC ειναι ειναι τραγικα δυσκολοτερη. Το θεμα και στις 3 περιπτωσεις κεφαλων ειναι η προσοχη κατασκευης και η επιλογη υλικων που θα χρησημοποιηθουν .
Μην ξεχναμε οτι ο Joseph Grado σχεδιασαι την Stereo Moving Coil κεφαλη την οποια χρησημοποιησε για συντομο χρονικο διαστημα μιας και πιστευε οτι η βελτιωση της περιοριζοταν μηχανικα!
Unread post #3 by Dr Pan K » Wed Nov 08, 2017 7:01 pm
Κατασκευαστικά οι διαφορές ανάμεσα σε ΜΜ και ΜΙ είναι πολύ λίγες και σε καμία περίπτωση δεν δικαιολογούν την τιμη. Ιστορικά μάλιστα οι ΜΙ είχαν πρακτικά τις ίδιες τιμές με τις πιο φτηνές ΜΜ.
Παραπέμπω στο άρθρο του
Electronic design http://www.electronicdesign.com/compone ... turntables
Από εκεί και πέρα αυτό που εντυπωσιάζει είναι ότι ο Grado για πρώτη φορά λάνσαρε τόσο ακριβές κεφαλές , την τιμή των οποίων δικαιολογεί με "εξωτικά υλικα". Δλδ κατ' εμέ δεν δικαιολογεί με τίποτα.
Speedking
Contact:
Unread post #4 by Speedking » Wed Nov 08, 2017 10:31 pm
Τι σε κανει να πιστευεις ότι η MC κεφαλη είναι πιο ακριβη κατασκευαστηκα σε σημειο που να δικαιολογει το κοστος αγορας της?
Μου αρεσουν οι Grado και από αναλυση και από μουσικοτητα του ηχου αλλα και τεχνολογικα αφου τις θεωρω σαν την "χρυση τομη", τις εχω ακουσει σχεδόν ολες (εκτος την τελευταια σειρα2) αλλα και παλι καποιες τις θεωρω υπερβολικα ακριβες!
ΥΓ... Στο αρθρο εχει καποια λαθη, Η Grado Statement Reference είναι ΜΙ και τα χαρακτηρηστηκασ της είναι 2Ωμ αντισταση και 2mH επαγωγικη αντασταση!
Unread post #5 by Dr Pan K » Wed Nov 08, 2017 10:49 pm
Οτι ειναι πιο δύσκολο να κατασκευαστεί μια MC ειναι γεγονός γιατι η διαδικασία δεν μπορει να αυτοματοποιηθεί οπως με τις ΜΜ, πολλα πρέπει να γίνουν στο χερι. Οι ΜΜ ειναι ακριβές οταν πρέπει να στηθεί εκ νεου μια γραμμή παραγωγής, απαξ αυτη γινει η τιμη πέφτει γιατι μετα μιλάμε για μαζική παραγωγή με λιγότερα εργατικά. Αυτος ειναι και ο λογος που η ΑΤ παράγει το μεγαλύτερο ποσοστο των ΟΕΜ ΜΜ για τριτους (βλεπε Clearaudio κτλ). Τις υπολοιπες τις παραγει η Nagaoka (βλεπε Goldring κτλ). Απο εκει και περα και οι MC ειναι αδικαιολόγητα ακριβές, το κόστος των οποίων πολλές φορές εξαρτάται απο καθαρα ασήμαντους παράγοντες οπως το κέλυφος κάποιων Koetsu.
Speedking
Contact:
Unread post #6 by Speedking » Wed Nov 08, 2017 11:01 pm
...και το κελυφος καποιων Grado .... αν και αυτο εχει καποια βασει με τους συντονισμούς του κάθε υλικου.
Νομιζω ότι το μονο που πρεπει να γινει στο χερι είναι τα τυλίγματα αλλα και παλι για καποιον που εχει "εκπαιδευτεί" σε αυτό θα του είναι ρουτινα! ...εννοείται και η κοληση του στελεχους/ακιδας αλλα κι αυτο γινεται σε ολες τις περιπτώσεις!
Unread post #7 by Dr Pan K » Wed Nov 08, 2017 11:17 pm
To στέλεχος με την ακίδα ειναι το πλεον ζόρικο. Η ακιδα απο διαμάντι (σπανια κατι αλλο) πρεπει να γυαλιστει απο ιδιαιτερα εξειδικευμένο εργοστάσιο και στον κοσμο ολοκληρο το know how το εχουν 2-3 στην Ιαπωνια, ενας στην Ελβετια και λιγοι αλλοι που ομως μπορουν να παραξουν μονο απλα προφιλ. Παράδειγμα το Replicant της Ortofon που δεν ειναι βέβαια προϊόν της Ortofon αλλα του Geiger (o οποιος προμηθεύει πρακτικά ολους τους μη Ιαπωνες).
Το θεμα με τους συντονισμούς ισχυει αλλα πουθενα δεν ειναι γραμμένο οτι το κοράλλι ή o όνυχας παίζουν καλύτερα απο το ξυλο ή το πλαστικό. Απλά κοστίζουν πιο πολυ και δείχνουν "κατσε καλα" οπως λεει και ο Chris.
Κάποιο κόστος έχουν και καποιοι rare magnets στις MC αλλα οπως και να εχει η τιμη και παλι δεν δικαιολογείτε.
Για να τα λεμε ολα, η Grado δεν ειναι ο μονος που "ξύπνησε" τελευταία. Και η Soundsmith του φίλου μου Ledermann εχει βγαλει κάποιες moving cross με τιμές στον θεό..
Ακριβή αλλα ιδιαίτερα δύσκολη στην κατασκευή (και εύθραυστη) ειναι η AT 1000 ART καθώς και η αντιστοιχη Tzar (με το πηνίο στο μπροστά μερος του cantilever). Grado στα 10Κ δεν μου παει κάτω, λυπάμαι.
Speedking
Contact:
Unread post #8 by Speedking » Thu Nov 09, 2017 1:13 am
Πολυ θε ηθελα να δω πως κατασκευαζουν τις ακιδες παντως..
Το θεμα των υλικων εχει να κανει με την συχνοτητα συντονισμου και την αποσβεση ταλαντωσεων που δεν δημιουργουν "συγχιση" στο ακουστικο σημα και ακούγεται καθαροτερο!
Speedking
Contact:
Unread post #9 by Speedking » Thu Nov 09, 2017 9:35 pm
Αυτή είναι η κατω οψη της epoch!
Παρατηρησα επισης ότι εχει τα ιδια επιχρυσα μερη με την Statement και Statement1 !
(Προσοχη όμως, η καινουρια Statement2 ΔΕΝ εχει χρυσα πηνια πλεον και ουτε τα επιχρυσα μερη!)
Χωρίς τίτλο.jpg (75.05 KiB) Viewed 5529 times
Speedking
Contact:
Unread post #10 by Speedking » Mon Mar 19, 2018 3:46 pm
H πλακα είναι ότι τελευταια ενας γνωστος μου δοκιμασε τη Grado Statement1 διπλα σε μια Koetsu Rosewood Platinum και η Koetsu εφαγε χωμα! Αποτι μου ειπε σε γενικες γραμμες επαιξε πιο καθαρα και σταθερα σε δυσκολα περασματα που η koetsu δεν τα καταφερε ενώ παραλληλα ο ηχος της ηταν πιο γεματος και πιο ζωντανος!
Η Grado ηταν πανω σε έναν SME ενώ η Koetsu σε έναν παραλληλο της ClearAudio αν θυμαμαι καλα!
Η τελικη δοκιμασια θα γινει με την Grado στον παραλληλο!
